2017 impala - Chevy Impala Forums
  • 1 Post By TeeRev
post #1 of (permalink) Old 08-14-2018 Thread Starter
Tyvon Derrick's Avatar
2017 impala
My car keep cutting off at any time and will start rite back up what's the issue
Tyvon Derrick is offline
post #2 of (permalink) Old 08-14-2018
TeeRev's Avatar
Quoted: 124 Post(s)
Are you talking about the automatic stop/start in the 4 cylinder engines? GM introduced that I believe in 2015, where the engine would cut off automatically under certain conditions to save gas. Is that what you're talking about maybe?
The manual for your 2017 says this:
If equipped with the 2.5L L4 engine, the vehicle has a fuel saving stop/start system to shut off the engine to help conserve fuel.
Auto Engine Stop/Start
When the brakes are applied and the vehicle is at a complete stop, the engine may turn off. When stopped, the tachometer displays AUTO STOP.
When the brake pedal is released or the accelerator pedal pushed, the engine will restart.
Auto stop may be deactivated if:
. A minimum vehicle speed is not reached.
. The engine or transmission is not at the required operating temperature.
. The outside temperature is not in the required operating range, typically below -10 C (14 F) or above 50 C (122 F).
. The shift lever is in any gear other than D (Drive).
. The battery has been recently disconnected.
. The battery charge is low.
. The interior comfort level has not reached the required level for the climate control system or defog settings. Use the eco (green indicator on) air conditioning mode for better efficiency.
. The auto stop time is greater than two minutes.
If that's what you're experiencing, it's completely normal operation. I don't think you can turn it off, but I'm not sure on that.
Hope this helps.
(PS: Admin, please move thread to right forum to allow for potentially more help, thanks!)
ICUBB likes this.
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
LED headlights / fog lights
Stant locking gas cap
GM molded splash guards
McGard locks
Last edited by TeeRev; 08-14-2018 at 10:50 AM. Reason: Added in info from owner's manual
TeeRev is offline
2017 Impala 1LT rear parking sensor V00D00 Chevy Impala 9th Gen Discussion 9 03-12-2018 05:23 PM
2017 Impala Premier Hochee Chevy Impala Discussion 7 03-06-2018 04:32 PM
iPhone cable - 2017 impala ogonzz Audio, Video, and Electronics 2 02-07-2018 08:10 AM
9th Gen, 2017 Impala LTZ - Sub amp weird issue sc85 Audio, Video, and Electronics 2 12-04-2017 05:04 PM
2015 2016 2017 2018 chevrolet impala parking sensor 2014 chevy impala pdc oem RSS Bot Impala Diecast Toys Cars on eBay 0 09-11-2017 06:40 AM
