Quoted: 124 Post(s)
FWIW, the AFM on GM engines uses oil to engage the lifters which then prevent the intake and exhaust valves from opening, so the cylinder compresses spent exhaust gas over and over again, kind of like a gas spring.
Which stands to reason, if there is an oil pressure sensor fault, the AFM would become disabled. I have heard and read that the wrong viscosity oil can cause this very issue.
If that isn't the issue, I know a few years ago two members here had his AFM stop working all of a sudden, then shortly after started throwing the P0523 code. Took it to a dealer, they swapped out the oil pressure sensor and everything started working again.
Hope this helps!
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
LED headlights / fog lights
Stant locking gas cap
GM molded splash guards
McGard locks
