2014+ impala Bose stereo system bypass and upgrade - Chevy Impala Forums
 8Likes
post #1 of (permalink) Old 03-09-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
Cool 2014+ impala Bose stereo system bypass and upgrade
Hello all,
It seems there's not a lot of information on the web about upgrading the stereo system in these cars. Until recently there were really no options other than tapping into existing after amp wires to do anything. However I thought I'd share some part numbers and descriptors to help you guys out who may be looking. And make some suggestions, fair warning though, any stereo upgrading will be costly because of the unique devices needed to make it sound good. so here it goes.
To those who want to upgrade the stereo head unit they do now make a kit for our cars, Locating one on the other hand will be tough as they are not available online as you will have to go to a local car audio shop to order one, same goes for amp bypass wiring.
You can view the kits available by going to Metra Online | Welcome to Metra Auto Parts Online Warehouse and simply punch in your year and model of car.
I personally have the bose centerpoint system, and actually really like the scrolling up screen so keeping the head unit stock is cool with me. So in my situation, I wanted to upgrade the mids highs and add bass. Go with the metra kit, AX-DSP-MOST1, this bypasses the factory amplifier all together and gives you RCA's to plug amps into. It also comes with a dsp (digital signal processor) so you can do time alignment and a nice EQ for tweeking the mids and highs.
I just requested to order one of these so in the mean time i tapped into the woofers in the trunk and used that for bass signal to run my subs. I used an audio control LC7i line driver adaptor to convert to RCA'S and it works like a charm (considering im using an amplified line)
JUST MAKE SURE if you go this route, that you are getting a Bass signal off the speakers you are tapping, the rear deck speakers i found to be the best for this. However there are 2 sets of wires running into these stock rear deck speakers, you need to tap into the bottom wires, the top ones produce mids/high sound and you wont get any good bass from there.
I ran a 1/0 awg wire OFC (OXYGEN FREE COPPER) for powering my amplifier, (rockford fosgate 2500 bd cp), Powering 2-t1 12" subs, the car sounds great with just this upgrade alone
I also made a power remote turn on wire for my line driver and amp, you can tap into the fuse panel on the left side of the steering wheel located behind the little compartment door, I used a 'mini fuse circuit tap' and was able to pull an ac turn on wire from there.
Most all of the factory tapping stuff, other than the remote on wire, is in the trunk, if you need to locate the factory amplifier, its on the passenger side behind the carpet, all the way against the body wall, its silver, and has a green plug and black plug into it. I have tested these lines and have found out what they are, i have a diagram too if someone wants it.
Hope this helps
nickwingnut13 likes this.
Car audio specialist.
tjhenry77 is online now
The Following 2 Users Say Thank You to tjhenry77 For This Useful Post:
nickwingnut13 (03-21-2018)
post #2 of (permalink) Old 03-22-2018
nickwingnut13's Avatar
Quoted: 15 Post(s)
Curious, you still on the stock alt with the big 3?
I'm currently running ~1800wrms (kappa K4, T1000-1 bdcp) with stock electrical up front and, surprisingly, no dimming whatsoever yet. Going to run my big 3 once it warms up a bit here and possibly get an alt too if I need it
nickwingnut13 is offline
post #3 of (permalink) Old 03-27-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
Yes i am for now, but my amp is so powerful when i really turn it up the dimming still occurs. I found a 370 amp alternator online for $699 that will put out over 250 amps at idle. but the big 3 help IMMENSELY for sure!!
You can see photos of my stuff in my garage (click on my avatar photo to see)
post #4 of (permalink) Old 03-29-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
OK!!! so after a ton of digging I found this, REALLY damn expensive but only thing currently available. I'm going to wait for the metra piece to come out. but you guys that cannot wait here ya go
https://navtv.com/products/NTV-KIT838/m650-gm.html ($850 OUCH!!)
this will bypass your factory amplifier and you can get clean signal to your aftermarket stuff
post #5 of (permalink) Old 03-29-2018
Quoted: 15 Post(s)
Haha yeah I bet, that amp you have is no joke.
Yeah i saw this the other day myself, wish they had it before I did all my stuff a couple years ago now. Heard it has exceptional SQ.
I did do a little research myself though on that Metra Kit as I'm still debating throwing a better radio in-
Metra claims this is all you need if you have the 4.2 inch radio like myself:
- 99-3024b dash kit
- GMOS-MOST-02 wiring harness
- 40-eu55 antenna adapter
- 44-ec48 antenna extension
- ASWC-1 steering wheel retention interface
However, when I put my car in on Crutchfield, it says installing a radio is still not recommended because there's still some kind of issue with the Climate controls. They even called me back after I emailed them asking if the site was updated with the release of the dash kit; they said, for some reason, they still don't recommend the kit after they tried it out because of Climate control issues.
So looks like I will let someone else be the guinea pig and report back on if all the harnesses and kit works, lol. Plus, in my opinion, that dash kit looks like trash since it sticks out so far from the factory bezel. If I were to do mine, I think I'd hack up the housing behind the radio to do it like the guy did on Youtube (
) and at least get the thing to sit almost flush and make my own bezel.
post #6 of (permalink) Old 03-29-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
I have the mylink system 8 scene so Im in a better position to keep my HU. As for you, Id look at the pioneer 7201 or 8201 nex model if your looking to change up. They have the ability to adapt to your heating controls within the vehicle. Not sure what interfaces u would need.
But I also dont think the heater controls are ran thur the radio, just displayed, the dials I believe work all that below.
I guess to test it. Pull the stereo and unhook it, then fire up the car and turn on your heater controls. If they work. NO PROBLEM then!!
post #7 of (permalink) Old 04-01-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
Its been released!!!
AX-DSP-MOST1 from metra
Which is $450 cheaper than the nav tv unit.
For a refresher. This will completely bypass the factory amp, and give you a clean full range signal for running aftermarket amplifiers.
Mines been ordered. I will post pics/vids when I have installed and upgraded and how to use it. And give a review.
post #8 of (permalink) Old 04-03-2018
Angus576's Avatar
Quoted: 61 Post(s)
Looks way too complicated
Angus576 is offline
post #9 of (permalink) Old 04-03-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
For those not into car audio it does look that way. But it is a great piece for us that are upgrading everything and keeping the stock head unit.
post #10 of (permalink) Old 04-04-2018
Quoted: 15 Post(s)
I'll be anxiously waiting lol. My commute for work is about to get 2-3x longer and I NEED a clean signal. This 4 inch radio is very dirty! (not in a good way)
post #11 of (permalink) Old 04-04-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
Is your 4 stereo system ran witha Bose amp??
post #12 of (permalink) Old 04-04-2018
Quoted: 15 Post(s)
Possibly? I can take a look tomorrow, but it had the most basic audio package I know that for sure (6 speakers; 1 for each door and 2 in front dash) . So definitely going to be a bit different than yours, but hopefully still be compatible.
Pretty sure I've almost completely bypassed the amp as it is, if not completely, so fingers crossed..
post #13 of (permalink) Old 04-04-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
Im not familiar with your layout, but if I had that cheesy set up, Id replace the radio all together lol
post #14 of (permalink) Old 04-04-2018 Thread Starter
tjhenry77's Avatar
Quoted: 50 Post(s)
Sorry that was rude to say, but I would look into radio replacement.
Metra has a kit coming out soon for your dash
Part number 99-3024B is the part number
My friend that owns an audio shop said end of this month is when its to be released.
If u go that route u wont need the dsp unit
post #15 of (permalink) Old 04-04-2018
Quoted: 15 Post(s)
Yeah I honestly might go that route. Like I said, the signal from this thing is DIRTY, it distorts at about 60% of volume. Getting anxious to jump on something here in a few weeks as I'm going to have to double or triple my commute time and I want to enjoy it
