is there any reason an oil extractor wont work? - Chevy Impala Forums
 3Likes
post #1 of (permalink) Old 02-04-2018 Thread Starter
luckydriver's Avatar
Quoted: 87 Post(s)
i used an oil extractor on another car a few months ago. so now it was my car's turn. 14 impala.
i never changed the filter from the top before so did that first. then i wanted to warm up the car so the oil moved more freely. when i got out of the car after the temp got up to about 100. there was oil all over the place. apparently i tightened it too much and the filter gasket was smashed. id say the puddle was about 4 ft in diameter
i put on a new filter and then tried sucking the oil out again figuring there was a bit more left. no dice. to make sure the ppump was working, i put it in some old drain oil (at 30 degrees F outside now) and the oil pumped just fine
so my conslution was that the oil pan was empty. so i sprayed down my belt and stuff with brake clean to get the oil off and i put in 3 qts of oil to see how much it came up. then i put in the oil pump and no oil came out at all. i dont get it?
i got a reading on the stick so took the car outside over fresh snow. not a drop of oil made the snow black so i know the filter is on right
i'm letting the car sit 30 min then checking the level. but i guess i did an oil change? i did chck the oil before i did anything today and there was still a reading on the stick but i was down to 0 on the meter for a week. i do all hiway driving. i guess the worse that happen is i have half new and half old oil. i guess in theory i can try the pump on the car now that i know theres at least 4 new qts in . but i there any reason why the extractor wouldnt work on this car?
188K on 2014 Blue Ray Metallic 2LTZ with 19s and nav. sadly new trans at 140K. Used to own 1995 DCM SS with only 260K!
luckydriver is offline
post #2 of (permalink) Old 02-04-2018 Thread Starter
Quoted: 87 Post(s)
i checked and the level is above the last dot so it's a little full but ill burn that off on the highway. no fresh leaks on the garage floor after car running about 15 minutes. so thats good. i did not hook up the extractor to see if i could suck any fresh oil out. but given the amount i put in i think there was 1 to 2 qts left in the car when i was trying to suck more out. i thought this would be a good way to do an oil change without jacking up the car but i guess not
post #3 of (permalink) Old 04-29-2018 Thread Starter
Quoted: 87 Post(s)
this didnt work again. why cant we put a tube down the dipstick..this is annoying. i was trying to avoid jacking up the car 10 times a year between this and rotation lol. must be something at the bottom blocking tube
post #4 of (permalink) Old 04-29-2018
ICUBB's Avatar
Quoted: 109 Post(s)
I buy my oil I want to use and filter I want to use then bring it to my local mechanic who charges 20 bucks to do the change. For 20 bucks I cannot even imagine going through the headaches. To me it seems you are making it much more difficult than it ever should be.
Fred9505 likes this.
Just a resident noob.
ICUBB is offline
post #5 of (permalink) Old 04-29-2018
Quoted: 932 Post(s)
Spend the $30 on one of these and make it so much easier to change your own oil...
**Internal Linking (Threads)
I could have my oil changed in the time it takes to drive to a garage to do it for me.
post #6 of (permalink) Old 04-29-2018 Thread Starter
Quoted: 87 Post(s)
the goal was not to have jack the car up though i admit the bolt is PITA and i wouldnt mind replacing it. there must be a slot at the bottom of the dipstick that the hose doesnt go down far enough. super annoying to have to jack it up. especially in the cold winter months.
post #7 of (permalink) Old 04-29-2018
Bowtie396's Avatar
Quoted: 43 Post(s)
Is it possable that the tube is bottoming out on the bottom of the pan and blocking the tube ?
I use a Fumoto valve, very similar to the ValvoMax setup, no tools, just drain into a jug, replace filter and done.
Bowtie396 is offline
post #8 of (permalink) Old 04-29-2018 Thread Starter
Quoted: 87 Post(s)
ive tried just having it up a tad.
post #9 of (permalink) Old 04-29-2018
Quoted: 932 Post(s)
I'm not sure about the 9th gens, but with the 8th gen, I'm pretty sure that I'll be able to just reach under the car and connect the hose without jacking up the car at all with that device...
OR... you could always just use car ramps to avoid having to jack up the car...
12 lt likes this.
post #10 of (permalink) Old 04-30-2018
1954 Chevy's Avatar
Quoted: 21 Post(s)
I don't have any suggestions about the oil extraction, but I think the 3 or 4 qts on the floor was due to the old filter gasket being stuck to the filter mount. It's happened to me 3 or 4 times at least in the last 50 years or so. It makes the new filter's gasket looks like it was smashed or deformed. It'll happen to anybody that changes a lot of oil. Only way to prevent it is look at the filter mount or wipe it off good before installing the new one.
1954 Chevy is offline
post #11 of (permalink) Old 05-01-2018 Thread Starter
Quoted: 87 Post(s)
with our low front end would that work? i have to angle the car every day at bottom of my driveway so i dont knock out the dam underneath
also ive never used ramps but unsure if woudl work in my garage. i have just enough room to walk around the car and not a lot of extra space . its hard to explain but i have a slope at my garage door that goes down the driveway. literally have to gun it enough to get in my garage up and over the sloped lip as i reverse, but not so hard as to go crazy fast and hit the cabinets in the back. pulling in the garage is not an option because of how things are setup there with angles etc
and i dont wanna do work on the driveway but thats the only option i could see with ramps. id have to meditate on that. but i do hate jacking up the car. are ramps considered more stable than jackstands?
i still cant believe theres something in the dipstick that prevents this tiny hose from bottoming out. i guess no one here has taken the engine apart to see something like this yet.
post #12 of (permalink) Old 05-01-2018 Thread Starter
Quoted: 87 Post(s)
opinions on these?
https://www.walmart.com/ip/RhinoGear...&wl13=&veh=sem
they dont look like my dads ramps lol. (stolen from buick commercial)
would make it so much easier if i could do it in my garage
post #13 of (permalink) Old 06-29-2018 Thread Starter
Quoted: 87 Post(s)
almost oil change time again. i really wish could just suck it out of the engine..sigh
so has anyone used ramps with our cars
post #14 of (permalink) Old 06-29-2018
Bowtie396's Avatar
Quoted: 43 Post(s)
What is wrong with a simple floor jack, I just did a oil change on mine, it took me all of about 25 minutes.
post #15 of (permalink) Old 06-29-2018 Thread Starter
Quoted: 87 Post(s)
i hate jacking up this car and crawling under to put jack stands. especially in winter its not fun. if i didnt have to jack it up to rotate the tires i wouldnt
Oil leaked dry now 2006 Impala is running hot wcexpat12 Chevy Impala 8th Gen Discussion 3 03-17-2019 08:29 PM
Remote start disabled P0521 Mr312712 Chevy Impala 8th Gen Discussion 17 03-13-2019 09:01 AM
Low Oil Pressure Warning coloradofjr Chevy Impala 8th Gen Discussion 1 07-28-2018 06:34 PM
Oil filter adapter gasket leak Jdg757 Chevy Impala Discussion 2 04-26-2018 07:23 AM
Not happy with Wix oil filters!!! WickedGoat Chevy Impala 8th Gen Discussion 48 01-10-2018 08:32 AM
