Codes P0171 & P0174 - Page 2 - Chevy Impala Forums
 2Likes
post #16 of (permalink) Old 10-17-2018
Smelvis's Avatar
Just wanted to say thanks for this thread. Google search led me here and when I popped the hood the intake boot was torn.
Smelvis is offline
post #17 of (permalink) Old 10-18-2018
hatzie's Avatar
Quoted: 149 Post(s)
Unacceptable on a vehicle that's only a few years old.
My 1977 VW Rabbit CIS Fuel Injection intake boots are literally 42 years old... Build date is 10/76. I've owned the car since early 1981 or late 1980 when I bought it for salvage with over 1/4 million miles. While I did swap a nearly new 84 GTI 1.8L engine from a burned down car into the chassis to replace the badly worn out 1.6L. 250K ws a lot of miles in 1980... Lots of things that should've lasted didn't last very long but it hasn't needed new intake boots.
2009 Impala SS
hatzie is offline
post #18 of (permalink) Old 01-09-2019
virginiathibodeaux's Avatar
Hay I have a 2016 Chevy impala and the check engine is on. I had it check and it is pulling code po442, po174, and po496 and I have no clue what these are. Can someone help me on this. It is hard to get it started after putting gas in and has died on me when sitting at lights or about to die on me. Please someone help me on this. Thank you
virginiathibodeaux is offline
post #19 of (permalink) Old 01-09-2019
Quoted: 928 Post(s)
Have you checked the air intake hose (the rubber-like thing between the air filter box and the throttle body)? I've been reading a lot of reports of that host basically falling apart on the 9th gens - even on newer, low-milage vehciles. Check that for tears, etc. And I completely agree with @hatzie here - it's ridiculous that this is even an issue for such a simple part that has been used forever on every car...
jtrosky is online now
post #20 of (permalink) Old 01-09-2019
Bowtie396's Avatar
The P0442 and PO496 are Evaporative Emission Control codes. Based on the fact that it is hard to start after fueling it is most likely the Canister Purge Solenoid. The P0174 is probably a result of the other two codes. Take it to the dealer, this should fall under the Emissions Warranty.
Bowtie396 is offline
post #21 of (permalink) Old 01-09-2019
Quoted: 928 Post(s)
My bad - I mistakenly thought that the poster was talking about the same codes that the OP was talking about (since they posted in this thread), which is why I mentioned the air intake boot (since that is what solved the OP's issue). Upon looking closer, I see that two of the three codes they are talking about are completely different than the codes that this thread is about. :-)
That being said, I do still recommend that all 9th gen owners check their air intake boot periodically, just so they can identify that issue before it actually becomes a problem (and maybe even get it replaced under warranty while the warrnty is still good). It's obvious that there is an issue with the material GM used for the air intake boot.
post #22 of (permalink) Old 01-10-2019
Thank yall. Will check on this.
post #23 of (permalink) Old 01-12-2019
Quoted: 928 Post(s)
Please come back and post when you do figure out the issue - that is *so* beneficial to other forum members, but unfortunately, most of the time, it doens't seem to happen.
kbz1960 likes this.
Having some rough idle issues as well as throwing some o2 sensor codes any advice? cutlass1972 Chevy Impala 9th Gen Discussion 11 04-09-2019 03:15 PM
P0411 and P0420 Codes jchabalie Mechanical and Electrical Problems 1 03-03-2019 01:26 PM
Un known fault codes BillGsa 8th Gen Engine Performance 5 01-11-2018 05:37 PM
Codes P0171 and P0174 blue2lt Automotive Discussion 1 01-04-2018 02:43 PM
3.8L crank but no start p0171 p0300 p0100 [** SOLVED **] nilloc93 Chevy Impala 7th Gen Discussion 20 09-02-2017 05:58 AM
