Oil consumption 3.6 - Chevy Impala Forums
 3Likes
post #1 of (permalink) Old 12-24-2017 Thread Starter
cutlass455's Avatar
Quoted: 4 Post(s)
Smile Oil consumption 3.6
Hi, was wondering if other 3.6 engines are using oil,as mine does just around 3k a quart. Dealer says its normal,but i think its ridiculous to add two quarts between changes.Have 39 k on it and noticed the loss starting around 30k. My verano did the same and the dealer did nothing. Never used a drop with the 2.4. untill around 60k.now it also uses around a quart every 3k. What gives, GM claims they wont do anything unless its around 2k and under. What a joke.
cutlass455 is offline
post #2 of (permalink) Old 12-24-2017
Quoted: 214 Post(s)
I have a 2014 Impala 2LTZ - purchased new with the 3.6 engine. It replaced a 2012 LTZ with the 3.6 engine.
The 2012 model did not use any oil. It now has about 38,xxx miles on it.
The 2014 model uses about 1/2 quart in about 3,000 miles. It now has 29,xxx miles on it. It is driven in mostly suburban or semi-rural areas and we live in the Midwest with below zero winters and 90+ summers.
I have had the oil changed at the dealer on the 2014 since new (came with 2-years free maintenance), but have changed the oil myself probably twice using synthetic. The dealer uses Dexos 1 semi-synthetic. The dealer was initially using the WRONG Delco oil filter (PF-48 instead of PF63E). I do not know if that incorrect oil filter has had a bearing on the minimal oil consumption.
My only advice would be to keep a close eye on the oil level and document any amounts that you add. You did not mention what year vehicle you have or how many miles are on the engine. Is the vehicle still covered under the GM power train warranty?
post #3 of (permalink) Old 12-24-2017
Quoted: 239 Post(s)
Similar experience here with dealer using the pf48 filter. Had also used the same filter myself on the last two oil changes I did myself before learning here that gm had issued a tech bulletin on the proper filter. With over 138,000 miles the 3.6 in our 2012 is not using any oil between changes(knocking on wood). We go between 5000-6000 on changes or when the olm shows around 30 percent life remaining.
With that few miles agree with the above, should still be under warranty, would be demanding that something be done to correct the issue because that is too much oil being lost or burned between changes.
post #4 of (permalink) Old 12-27-2017
Angus576's Avatar
Quoted: 61 Post(s)
I don't use much oil but I am using Full Synthetic which seems to last longer. I had the dealer do the last change because they were running an unbeatable special and that was a couple weeks ago. Says next change in June. The Oil life monitor is set for 3k so don't go by that unless you want to change every 3k. Synthetic oil can go 5-6k and will probably need a quart before that time. I'm at 42k miles on my 2015.
Angus576 is offline
post #5 of (permalink) Old 12-27-2017
Quoted: 239 Post(s)
Are saying you are using a quart every change? Kinda surprised if that is the case with that low of miles. Be interested in hearing more about those folks burning oil with such low mileage in the 3.6's as to how they are driving.
Maybe maven or any other gm tech could chime in here from a mechanic standpoint. These cars imo with that low of miles should not be burning or losing oil.
post #6 of (permalink) Old 12-27-2017
greed's Avatar
Quoted: 5 Post(s)
I go through about a quart of 5-30 Mobil 1 in 5,000 miles. Dealer says that is in spec. Dealer says 1qt in 2,000 miles is excessive. I don't remember what the FSM says. It is what I would consider excessive. I had a 72 Buick GS with the 350 that would go through 1 qt in about 2 tanks of fuel. I put a different PCV valve in that had a higher vacuum rating. That stopped the oil usage. I wonder if that could be part of the problem with these 3.6's?
greed is offline
post #7 of (permalink) Old 12-30-2017 Thread Starter
cutlass455's Avatar
Quoted: 4 Post(s)
PS my crap box is a 2015 impala 2LT
post #8 of (permalink) Old 12-31-2017
Carbide's Avatar
Quoted: 161 Post(s)
I think there is something to be said for strictly following the requirements and recommendations for correct oil and fuel use on the direct injection GM engines.
I use only a full synthetic oil, Mobil 1 EP 5W30, from WallyWorld, and Top Tier fuel, from Costco, to keep costs down, and I don't notice people who religiously follow these recommendations have that many problems.
Avoiding these issues is the key, once you have them, cures are not to be had.
Carbide is offline
post #9 of (permalink) Old 12-31-2017
greed's Avatar
Quoted: 5 Post(s)
I've always run Mobil 1 5-30, currently Mobil 1 5-30 EP and top tier fuel. I still have what I consider excessive oil consumption.
greed is offline
post #10 of (permalink) Old 12-31-2017
greed's Avatar
Quoted: 5 Post(s)
I just checked the oil. At just under 2,000 miles on this OCI, the oil level is at the next lower raised dot in the crosshatch below the raised dot at the full line. Probably not enough consumption to be very concerned about, but I've never had any engine that uses this amount of oil without leaks.
greed is offline
post #11 of (permalink) Old 01-01-2018
Rambro99's Avatar
My 15 LTZ with 22000 mi and nothing but Mobil 1 every 5000 mi and napa gold filter uses no oil at all I also use top tier fuel and a bottel of Techron every couple thousand mi.
Rambro99 is offline
post #12 of (permalink) Old 01-05-2018
Maven76's Avatar
Quoted: 80 Post(s)
My car has seen WOT at least once a day since day one (14 2LT) and religiously use Mobil1EP or Castrol Edge at about 4500miles. Never seen more than 1/2qt low, typically about 8oz
That said, every engine is different and GM spec is in fact >1qt/2000miles. If youre using <1qt/2000miles GM will not authorize repairs.
Short trips in cold weather are really bad for this engine and can lead to PCV system icing and excessive oil consumption. So does cheap or non-spec oil, its been my experience that non top-tier, and low octane fuel usage exaggerate any issues as well.
All the modern GM engines use low tension piston rings which allows more oil consumption compared to traditional ring packages.
GM World Class Technician
Im just here for the cookies
Maven76 is offline
post #13 of (permalink) Old 01-06-2018
Jerry1's Avatar
Quoted: 4 Post(s)
So, can the PVC system be de-iced/repaired/cleaned out . . .?
If cheap or non-spec oil has been used, can using full synthetic improve or fix the oil consumption?
Same with top-tier fuel. If not used in the past, can switching improve the situation?
Reason I ask is that I bought my car used and have no way of knowing how it was driven or maintained. I think it was maintained by the dealer because it was a lease car (2yr/20,000 miles), but I have no way of knowing driving habits or type of gas used.
Jerry1 is offline
post #14 of (permalink) Old 01-08-2018
Maven76's Avatar
Quoted: 80 Post(s)
Basically yes to all, if volatile cheap oil was being used, a high quality oil will reduce consumption, same goes for fuel use, and cleaning the PCV system if thats the cause.
Maven76 is offline
post #15 of (permalink) Old 01-18-2018
Dave_N's Avatar
Quoted: 64 Post(s)
Only use full synthetic oil in these engines.
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline
Remote start disabled P0521 Mr312712 Chevy Impala 8th Gen Discussion 17 03-13-2019 08:01 AM
2008 Impala 5.3 burning oil with after market warranty MountainDue 2006-2013 Impala Reviews 7 02-08-2019 09:31 AM
Low Oil Pressure Warning coloradofjr Chevy Impala 8th Gen Discussion 1 07-28-2018 05:34 PM
is there any reason an oil extractor wont work? luckydriver Chevy Impala 9th Gen Discussion 29 07-05-2018 12:57 PM
Oil Drain Plug sheared off (3.6 LFX) rodya234 Chevy Impala 8th Gen Discussion 18 03-12-2018 09:45 AM
