2014 Line output converter help asap!!! - Chevy Impala Forums
post #1 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
I just bought a fully loaded 2014 new body style impala and i want to put in some subs but I'm having trouble with the line output converter. I just need help getting started at the factory amp!
JaelenK is offline
post #2 of (permalink) Old 09-09-2017
Bvaleri's Avatar
You will need an lc7i to do a good install.
Bvaleri is offline
post #3 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
://www.sonicelectronix.com this is what the audio shop by my place gave me. They said it will work fine. Also dumb question, but do you have a diagram for 11 centerpoint system? I'm not sure if splice all speakers?
JaelenK is offline
post #4 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
It's access mloc 720
JaelenK is offline
post #5 of (permalink) Old 09-09-2017
Bvaleri's Avatar
Your link didn't work just look up audio control lc7i. If you don't install one Bluetooth won't work right. I do not have a diagram for the writing unfortunately. That part should work for you and maybe check YouTube for some install tips. I had someone professionally do mine because I redid everything audio wise and did a 5 channel amp and arc audio speakers throughout with a idq12 sub. Plenty of bass and extremely loud on the music.
If you got a few minutes look at my post on air ride and see if you can help me out thanks.
Bvaleri is offline
post #6 of (permalink) Old 09-09-2017
Bvaleri's Avatar
I found the one you bought. That will work if all your doing is adding a sub.
Bvaleri is offline
post #7 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
Yeah I just want to put in the sub. So do I only splice the rear subwoofer speaker one the factory amp? Sorry I just have everything I need for the install, but if I go to the shop I have to buy all new stuff, being 200 bucks...
JaelenK is offline
post #8 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
Also I read your post on the airlift kit, unfortunately my knowledge is very limited, hence just trouble installing subs lol. The only air ride i know anything about is on my kenworth lol
JaelenK is offline
post #9 of (permalink) Old 09-09-2017
Bvaleri's Avatar
you aren't using a new amp or anything just splicing into the old one? Also, even if your not looking at buying an air ride you could help by filling out the thing on airlift performance website if you want.
Bvaleri is offline
post #10 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
Okay, I have two diamond d3 12s with two mtx amps mtx rt2200 and rt2400. Would i need two of these locs?? That's what I'm trying to install and not sure how to go about it. Also, I will fill one out here in about 30 minutes as soon as I'm home from this shop.
JaelenK is offline
post #11 of (permalink) Old 09-09-2017
Bvaleri's Avatar
I don't think two would work you would need one that has multiple outs like an lc7i. You will still have to wire like a traditional set up to the battery ground antenna etc the point of the lc7i is to use the factory head unit not the amp. There are no aftermarket head units for the impala or at least they were no around when I was looking. You aren't really using the factory amp at all except to power what was already there. Here is a link to the part, but don't buy it on that site if you get on. https://www.crutchfield.com/p_161LC7...m&awug=9029734
I am unsure if you can use two of what you have, but it may work either way they are doing the same thing you don't really need anything with the factory amp.
Bvaleri is offline
post #12 of (permalink) Old 09-09-2017
Bvaleri's Avatar
The point of both products is to give you extra rca hook ups for your added amps. Doesn't look like you could only use one amp for what you have.
Bvaleri is offline
post #13 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
Okay so then I will just run them off one amp. So what all do i have to do just to get the subs running with the one amp? Just cut the wires to the rear subs and replace it with the loc? Sorry I may need a step by step instruction, I'm not really understanding haha.
JaelenK is offline
post #14 of (permalink) Old 09-09-2017 Thread Starter
JaelenK's Avatar
Quoted: 29 Post(s)
So I could only power one woofer and one amp on this?
JaelenK is offline
post #15 of (permalink) Old 09-09-2017
Bvaleri's Avatar
You need to wire one of your amps. The subs are irrelevant to the item we are talking about, they will wire to the amp as usual. You need to run your power from the battery to the trunk. I assume that's where your placing the amp. Find a place in the trunk to hook up your ground wire as well. After that run the antenna wire up to a fuse that is always on when the car is running like the rear power outlet or something. Then splice into the rear 6x9 wires with the mloc then connect your rca from the amp to that. I was a little off on what I thought you had. Here is a video that will show you a little better than I can explain over forum. https://m.youtube.com/watch?v=FN1NodXLR5w
Bvaleri is offline
2010 Impala -- Line output converter producing loud signal after key is turned off? Captain McFunk Audio, Video, and Electronics 2 10-07-2017 06:33 AM
Fuel line repair on Impala but no space to use Tubing cutter john5246 Chevy Impala 7th Gen Discussion 4 08-23-2017 06:55 AM
