Led headlights for 2016 lt - Page 6 - Chevy Impala Forums
 6Likes
post #76 of (permalink) Old 09-29-2018
2016 2LT's Avatar
Quoted: 6 Post(s)
Originally Posted by ICUBB View Post
No, my kit was just the ballast and bulbs. Just double check all your connections, 1 might be reversed.
tried again today, no dice. They come on fine until the car gets turned on... Double and triple checked the connections. Gues I will try leds or buy new dust covers and try regular bulbs. Thanks again for all the info. Really appreciated it.
2016 2LT is offline
post #77 of (permalink) Old 09-29-2018
2016 Impala LTZ's Avatar
Quoted: 25 Post(s)
If your headlights are also your daytime running lights (DLR) you will need a relay kit for these to work correctly. To prove that is the problem turn off your DRL before you start the car and then turn on the headlights with the switch while the car is running. If they work you will need the relay kit that gets 12 volts from the battery. When your DRL are on you are getting less then 12 volts to the headlights and that messes up the ballast for the HID lights. When you turn on the headlights by the switch that sends 12 volts to the ballast.
I had the same problem with my Chevy Cruze and the relay kit solved the problem. Hopefully this helps you.
John
ICUBB and 2016 2LT like this.
2016 Impala LTZ is offline
The Following User Says Thank You to 2016 Impala LTZ For This Useful Post:
2016 2LT (09-29-2018)
post #78 of (permalink) Old 09-29-2018
2016 2LT's Avatar
Quoted: 6 Post(s)
John
awesome info, I will get that ordered up and try it out! Thanks for the info!
2016 2LT is offline
post #79 of (permalink) Old 10-06-2018
Mikey7436's Avatar
Quoted: 9 Post(s)
Originally Posted by njzehr View Post
VLEDS has their new Micro LED unit available. I installed them about 2 weeks ago. They fit inside the dust cover no drilling or cutting required, can be ordered in 5k or 6k and carry a multi-year warranty. Purchase soon and you'll get their scaling labor day discount. No need for their DRL voltage converter or warning light canceler. Order their 9012 kit and "plug and play" that simple. Im glad I waited until there was a solid LED unit available and didn't drill holes in my covers to fit outdated HID technology. Their 6k LED units match nearly perfectly with the factory LTZ DRL kit on my 14 2LT. Give VLEDS a serious look if you want to upgrade your halogen bulbs to LED technology.
MICRO LED HEADLIGHT 5K / 6K 9012 - 9012 - LED Headlights - Shop Products
The problem I have is even with the dust covers on over my leds I still get condensation. How do you prevent that?
Mikey7436 is offline
post #80 of (permalink) Old 10-22-2018
2016 2LT's Avatar
Quoted: 6 Post(s)
John
That did the trick! Got the lights all setup and happy as can be. Thanks for the info!
ICUBB likes this.
2016 2LT is offline
post #81 of (permalink) Old 10-22-2018
2016 2LT's Avatar
Quoted: 6 Post(s)
They are HID so they do get hot but not melt the headlamp hot. As for mounting I will try to take a picture and post it but right on the side of the light. The picture will describe it better.
Did you have any issues with condensation? Its like a rain-forest in each of my headlights. Its dry as a popcorn fart here but looks like a fresh shower inside the headlights...
2016 2LT is offline
post #82 of (permalink) Old 10-23-2018
ICUBB's Avatar
Quoted: 109 Post(s)
I never had any condensation issues before some idiot backed up into me and I had to replace the right headlight, now that one gets a wee bit along the lower edge. From what I can gather from research that I did is the seams may not be perfect and the only way to fix it would be remove the headlight and bake it in an oven.
Just a resident noob.
ICUBB is offline
The Following 2 Users Say Thank You to ICUBB For This Useful Post:
2016 2LT (10-23-2018)
post #83 of (permalink) Old 10-23-2018
2016 2LT's Avatar
Quoted: 6 Post(s)
Nice, Ill have to think that one over. Ill do some looking at baking the headlights. Thanks for the info.
2016 2LT is offline
post #84 of (permalink) Old 10-23-2018
2016 2LT's Avatar
Quoted: 6 Post(s)
Im done, they look nice but now I've got the relay buzzing like a angry bee. Feels like an electric shaver. Just going to replace the dust covers, and get the brightest halogens I can and go that route. Wasted enough time and money on this.
2016 2LT is offline
Black LED 4x6 Rectangular Projector CREE LED Headlights High Low Beam DRL Lamp RSS Bot Impala Diecast Toys Cars on eBay 0 11-23-2018 09:00 AM
2018 LED headlights T-revs61 Chevy Impala 9th Gen Discussion 6 05-21-2018 06:11 PM
Headlights upgrade, LED or HID? Jomaba4308 Chevy Impala 9th Gen Discussion 1 05-01-2018 12:05 PM
4PCS LED Headlights For Peterbilt Rectangular Headlights (Pack of 4) 357 379 378 RSS Bot Impala Diecast Toys Cars on eBay 0 07-29-2017 06:40 AM
LED headlights, sale IceMachine Private For Sale Classifieds 11 07-24-2017 02:26 PM
