Driver Door doesn't always lock and unlock - Chevy Impala Forums
 3Likes
post #1 of (permalink) Old 08-22-2017 Thread Starter
Replacement's Avatar
Quoted: 7 Post(s)
Question Driver Door doesn't always lock and unlock
Anyone experience similar issues with their locks not locking or unlocking when door button or remote button are pressed?
It doesn't always happen, but when it does, I have to manually lock it.
Hermes: Sorry, I spent all day putting my office in order. Now I got to go home and relax the traditional Jamaican way: A glass of warm milk and good night sleep.
Fry: Jamaican? I thought you were some kinda outer-space potato man.
Replacement is offline
post #2 of (permalink) Old 08-22-2017
reubenswinks's Avatar
Quoted: 93 Post(s)
Is this the first signs that the 9th gen have door lock actuator problems like 8th? That would be unfortunate.
reubenswinks is offline
post #3 of (permalink) Old 08-22-2017
Angus576's Avatar
Quoted: 61 Post(s)
First time I ever heard of this
Angus576 is offline
post #4 of (permalink) Old 08-22-2017
Quoted: 353 Post(s)
My first instinct is that it's either the driver's side lock switch, or the wires going to. The driver's door gets opened/closed most often, and is thus more susceptible to the wires being damaged. The frequent flexing can cause chafing of the insulation and breaks in the copper. Either a shorted or opened wire might be intermittently causing your problem. That is, the same problem could be causing both the switches and the remote to not work.
I would start by pulling back the accordion rubber in the door jamb, and inspecting for broken and chafed wires. If you can get a drawing, you would want to focus on the wires for the locks - that is, find the color callouts in the drawing and look for those wires.
If the wiring looks good, next I'd remove the switch and inspect it. That may require removing the door trim.
post #5 of (permalink) Old 08-22-2017
Quoted: 927 Post(s)
The 8th gens have door lock actuator problems? I honestly have heard of many failures... HVAC actuators - definitely, door lock actuators - not so much....
jtrosky is online now
post #6 of (permalink) Old 08-22-2017
Quoted: 93 Post(s)
I had two go bad. There are numerous threads where multiple people had the issue. The OEM parts are stupid expensive too.
https://www.impalaforums.com/chevy-im...actuators.html
https://www.impalaforums.com/chevy-im...d-on-08-a.html
https://www.impalaforums.com/chevy-im...-actuator.html
https://www.impalaforums.com/chevy-im...ck-at-all.html
It goes on...but you get the picture. I would say it is a known issue. Not sure if 9th gen use the same parts or not.
post #7 of (permalink) Old 08-22-2017
Quoted: 927 Post(s)
I'm certainly not saying that there haven't been any failures, but I haven't heard about the issue all that often. With as many 8th gens as there are out there, there are going to be failures - but the lock actuator failures just don't seem to be all that common to me. For example, 2 out of the 4 threads you linked to were from 2013 - 4 years ago. I'm sure that there are other threads - and maybe I'm wrong, but I personally haven't see an unusually high number of posts about this issue. Who knows, maybe I just block them out with the hopes that if I ignore the reports, it wont happen to me! :-)
Now 8th gen transmission issues and HVAC actuator issues - now those are what I consider to be "common" issues! :-)
That being said, I did modify my 2012 settings (via the DIC) so that only the drivers door locks and unlocks with the first press of the key fob buttons) - since I'm usually the only one getting in the car, I figured why have the other 3 locks doing work for no reason. :-) My wife hates it though - every time I turn the car off, my door unlocks automatically and hers doesn't. :-)
post #8 of (permalink) Old 08-22-2017
Quoted: 353 Post(s)
It seems like I've put one of these in my 2007 Pontiac G6, my 1997 F-150, and maybe one of the four w-bodies we have. That is, the Impalas don't strike me as being any more susceptible to bad lock actuators.
I will say the things are expensive! Seems like the last one I bought was over 100 bucks.
post #9 of (permalink) Old 08-22-2017
impaler's Avatar
Quoted: 216 Post(s)
No problems with the door locks on our 15 Impala
2015 2LT
Convenience pkg
Advanced Safety pkg
Sunroof
Suntek CXP 50/35 tint
impaler is offline
post #10 of (permalink) Old 08-22-2017
1970cs's Avatar
Quoted: 39 Post(s)
14 with 50K. No issues here!
Pat
1970cs is offline
post #11 of (permalink) Old 08-31-2017 Thread Starter
Quoted: 7 Post(s)
Seems to be not working at all anymore. I bought the car used from a dealer, any chance they will fix at no cost? I am guessing I will have to pay for it, but someone bet me that the dealer would.
post #12 of (permalink) Old 08-31-2017
Quoted: 927 Post(s)
IF you are still within the 3 year/36k mile bumper-to-bumper warranty, you can take the car back to ANY chevy dealer and they will fix it for free. If you are not within the bumper-to-bumper warranty, then no, they won't fix it for free...
post #13 of (permalink) Old 08-31-2017
njzehr's Avatar
Check TSB #PI1018A
The dealer will have 20+ run around reasons for why it doesn't always work when you press the buttons lol i've read literally hundreds of service bulletins and tech tips stating findings that almost any signal can and potentially will interfere with the keyless remote of all makes and models, anything from a home/business WIFI signal and near by cell phone towers to there being too many chevrolet or like make vehicles parked in the vicinity...and everything in between. See the attached TSB claming USB charging interference.
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=188903
Also see TSB: # PIT5119C
Essentially the key lock cylinders can stick open ever so slightly when removing key blade from said cylinder, causing the PCM to think the key is still in the vehicle disabling keyless control. Per TSB lubricate all door lock cylinders and ignition lock cylinder with lubricant spray...and cross your fingers. (Okay I added that last part)
plano-doug and nionzeiss like this.
njzehr is offline
post #14 of (permalink) Old 09-01-2017 Thread Starter
Quoted: 7 Post(s)
Well damn, I think I have 36,400 or so now, this started before then. Do they ever have any wiggle room?
post #15 of (permalink) Old 09-01-2017 Thread Starter
Quoted: 7 Post(s)
Originally Posted by njzehr View Post
Check TSB #PI1018A
It happens even if I use the lock/unlock button on the door. All other doors lock/unlock. I can only get it to unlock if I pull the door handle on the inside.
Car Door Key Lost Lock Out Emergency Open Unlock Tool Inflatable Air Pump Kit RSS Bot Impala Diecast Toys Cars on eBay 0 12-15-2018 12:35 AM
10Pcs Universal Car Lock Out Emergency Kit Door Opening Key Tool Kit Easy Unlock RSS Bot Impala Diecast Toys Cars on eBay 0 09-22-2018 06:40 AM
10 Pcs Car Lock out keys Emergency Glossy Silver Unlock Door Open Tool Kit RSS Bot Impala Diecast Toys Cars on eBay 0 08-06-2018 08:00 PM
Car Door Open Tool Key Lock Out Emergency Tools Kit Unlock Inflatable Air Pump RSS Bot Impala Diecast Toys Cars on eBay 0 08-06-2018 06:10 PM
06 Imp SS doors unlock, but not lock Scrappy Chevy Impala 8th Gen Discussion 6 03-19-2018 04:36 PM
