2015 LTZ Water In Trunk - Page 2 - Chevy Impala Forums
 2Likes
post #16 of (permalink) Old 04-17-2016
Dikbag's Avatar
My 15' had water in the trunk when I bought it also. I discovered that this large grommet for wire was out of place and the smaller one below it was missing. I could pour water and see it coming in there.
Dikbag is offline
The Following 2 Users Say Thank You to Dikbag For This Useful Post:
1999 White C5 Coupe (04-17-2016), TigerPaw (04-17-2016)
post #17 of (permalink) Old 04-18-2016
Cleatus's Avatar
kinda reminds me of those memes..."you had ONE job to do..."
Cleatus is offline
post #18 of (permalink) Old 10-07-2018
shaymus47's Avatar
Did you have a smell? Because I had a leak thru the taillight which the dealer fixed but they couldn't get the smell out. Any ideas
shaymus47 is offline
post #19 of (permalink) Old 10-07-2018
Jomaba4308's Avatar
Quoted: 17 Post(s)
I'm a car retailer for a car dealership and our strongest odor eliminator is Ardex Vehicle Hygienist which I don't think is available retail but it's essentially a chlorine dioxide bomb. Mix it up, set it in the area, close it up and let it sit for a couple hours. I also suggest letting it air out open for another couple hours and let the chlorine smell dissipate a little. Once the chlorine smell fully dissipates, the smell will be gone.
When Ardex sold us the 1st bomb, he guaranteed the smell would come out or he would come clean it himself.
If you don't want the chlorine smell then baking soda is usually a good option but I can't guarantee it will eliminate the smell.
Sent from my VS995 using Tapatalk
Jomaba4308 is offline
The Following 2 Users Say Thank You to Jomaba4308 For This Useful Post:
shaymus47 (10-08-2018)
post #20 of (permalink) Old 03-03-2019
graves's Avatar
2015 chevy Impala LTZ trunk leak
I too have this make ans model which was also a returned lease with low miles and nearly new condition. I noticed a weird odor. Upon investigation I found almost 5 inches of water standing in the wheel well. My entire carpets were soaked. We took it to our Chevy dealer because of course I have a 6 yr bumper to bumper extended warranty. They claimed no knowledge of this problem in 2015. Of course the warranty does not cover leaks? WTF?? So they spent 3 hrs tore the entire back end apart, sealed some screw holes and rescrewed them. Well yesterday I looked because i never pt the carpet back and theres 2-3 more inches of water. I will go back as this is a defect and they will fix it under warranty as it appears to be a manufacturing issue. Glad I found your post!
T Graves
kbz1960 likes this.
graves is offline
post #21 of (permalink) Old 03-03-2019
kbz1960's Avatar
Quoted: 22 Post(s)
T Graves
Good luck! Hope they do!
kbz1960 is offline
post #22 of (permalink) Old 03-04-2019
jmaotto's Avatar
I had the same problem with my 2014. I drilled a 1/4 inch hole in the floor of the trunk near the spare tire. No more water in the trunk.
jmaotto is offline
post #23 of (permalink) Old 03-04-2019
ICUBB's Avatar
Quoted: 108 Post(s)
I guess if you are not under warranty and cannot afford the fix this is a reasonable solution but a hole could rust and when the water was coming into my trunk it was passing over a bunch of electrical connectors on it's way in.
Just a resident noob.
ICUBB is offline
post #24 of (permalink) Old 03-21-2019
LTZ in VA's Avatar
Another Swimming Pool in the Trunk
This past weekend I happened to grab something out of the trunk and I noticed it was damp. Oddly enough, I had just seen the issue discussed on this forum, so with dread I popped the cover to the spare tire area and yes, water in the well.
Fortunately, I caught it before mold set in, but this is ridiculous. Seals failing on a non-moving part in such a short period of time is clearly a design/manufacturing defect. Addressing it for the 2014, but not the 2015 when the same seals are used is clearly evidence that GM does not give a damn.
Up until last week, I loved this car. Could not rave enough about how GM got it right - a beautiful, comfortable and reliable car. NEXT DAY, check engine light is on with a "minor emissions leak". WTH - does everything break at once and is this ride just getting started?
LTZ in VA is offline
post #25 of (permalink) Old 03-22-2019
apguy's Avatar
Quoted: 11 Post(s)
I was in the same mindset. We found a used ltz and my wife and I were both happy with it. Beautiful car. Haven't even owned it a year and now things are starting to fail and I'm wondering if we made the right call. Evidently these new cars are not engineered to make it to 100k miles. I'll keep driving the car it replaced that used to be my wife's daily driver. Toyota Camry with 225k miles and no major maintenance except oil changes, brakes, and batteries.
When you make a car to last you build a customer base, when you build a car cheap to be expendable you lose long time GM owners like myself.
apguy is offline
post #26 of (permalink) Old 03-22-2019
Quoted: 928 Post(s)
My personal method of buying cars is to wait until many years after any major redeisgn - after it's been "refined" for many years.
For example, I didn't buy an 8th gen Impala until the 2012 MY (6 years after major redesign) - and I didn't buy a Dodge Challenger until the 2018 MY (10 years after major redesign). That is just the last two examples. I tend to do the same thing with engines - I tend to prefer "older" engines that have been around for a while and have a proven reliability record. Engines like the GM 3800, GM 3.6L and the Dodge 3.6L Pentastar.
I *did* buy a first model-year Buick LaCrosse - but that was only becuase it had the GM 3800 Series engine, which was a bulletproof engine. I did still suffer some other first-model-year issues with the car though - and was a good reminder not to do that again (although, overall it was still a very reliable car).
That being said, when you do this, you'll never have the "latest thing" - but you will have a reliable car. :-)
kbz1960 likes this.
jtrosky is online now
water on passenger floor 2015 impala ltz tgibson0510 Chevy Impala Discussion 2 04-30-2019 06:45 AM
2015 Impala LTZ OEM 20" wheel paint code? bunkerhill Chevy Impala 9th Gen Discussion 2 04-22-2019 01:43 PM
2016 impala lt water in trunk Angela Whitten Glenn Chevy Impala Discussion 0 03-11-2019 03:54 PM
Water in trunk MirrorBlack Chevy Impala 9th Gen Discussion 13 09-30-2018 01:05 PM
Water leaked in trunk no audio steven3181 Chevy Impala 9th Gen Discussion 34 06-24-2018 06:53 PM
