LFX Spark plugs, who's done it?? - Page 2 - Chevy Impala Forums
 6Likes
post #16 of (permalink) Old 04-07-2015
Ryfly05's Avatar
Originally Posted by fatrabbit View Post
Chrislind2, kd7ctv and tehhax- I hope you all know the original poster was asking about the LFX or the 3.6L DOHC found in all 2012+ impala, not the 3.5L and 3.9L. The push rod engines are simple to do a tune up on. You don't even need the W-body ratchet either though it does make life easier lol
The LFX is a little different though, the plastic intake is molded to cover over the rear bank and makes it impossible for you to clear out the cylinder #3 and #5 coil packs, you can snake out cylinder #1 coil pack though.
I guess the laugh is on you Chislind2 for not being able to read the post correctly, I do this for a living/work at a professional shop.
Yep and the factory service manual says to remove the manifold also.
Daily: 2013 Imp LTZ
Drag: 2006 Pontiac GTO - Intake only 13.4 @ 106 MPH
Bike: 2006 GSX-R 1000 - Road course machine!
My YouTube Channel - https://www.youtube.com/user/Ryfly05
Ryfly05 is offline
The Following User Says Thank You to Ryfly05 For This Useful Post:
LS1Heli (04-09-2015)
post #17 of (permalink) Old 04-07-2015
chrislind2's Avatar
Sorry fatrabbit
I was assuming things and that gets people in trouble. It's amazing how different the years and models can be. Being an old timer we used to work on cars that mainly only varied between manufacturers and an individual company rarely made changes that amounted to much unless they came out with a new model. I apologize for insinuating you did not know what you were talking about.
chrislind2 is offline
post #18 of (permalink) Old 04-07-2015
fatrabbit's Avatar
chrislind2- it's all good, no hard feelings lol
I miss 3.5/3.9 platform, for the most part pretty much everything on that motor is easy to get too and replace. The newer LFX engine is a tall/wide motor and it makes things more challenging to get too, when you change out the spark plugs your going to want to order the gasket set #126459 and that will come with the gasket for the spacer/intake gaskets/throttle body gasket. I paid $19.02 but that was with my discount, list price is $21.13.
2012 Impala LT(fleet)
Modifications: GMPP front slotted rotors, 35% window tint all around and all weather package
2010 Impala LT(fleet)- [email protected] on 8/5/14(totaled)
Modifications: 3.9L(LGD) swapped, 3.69 FDR, GMPP ride handling package, 35% window tint all around, modified gas pedal, all weather package and tuned by Overkill Motorsports
fatrabbit is offline
post #19 of (permalink) Old 04-09-2015
MarkTN's Avatar
Quoted: 18 Post(s)
I can't believe you have to do all of this to change the rear spark plugs.Another jewel in the crown for GM engineering.Its like the plastic shroud over the top of the engine.To remove it you have to take off the oil filler cap so junk can fall down in it as you take it off.The shroud fits over other removeable caps but not the one for oil.Oh,and I am referring to the 3.6L engine starting in 2012.
MarkTN is offline
post #20 of (permalink) Old 04-09-2015
Quoted: 194 Post(s)
^ Leave it off....
post #21 of (permalink) Old 04-09-2015
kd7ctv's Avatar
It's job security, so maybe you won't want to do it and will take it to the dealer and pay them...lol
kd7ctv is offline
post #22 of (permalink) Old 04-09-2015
volume's Avatar
i look at the rear spark plugs there space to pull the coil and remove the spark plug whit out taking the intake twist and pull (that is not dirt that is pollen)
ID:	93154   Click image for larger version
ID:	93162   Click image for larger version
ID:	93170   Click image for larger version
ID:	93178   Click image for larger version
volume is offline
The Following User Says Thank You to volume For This Useful Post:
post #23 of (permalink) Old 04-09-2015
fatrabbit's Avatar
There's not room though, I already went though this with my 2012 Impala 4 months ago...
There's no way to pull out the coils without removing the intake, you can get the cylinder #1 coil out but you won't be able to snake out cylinder coils #3 and #5. The coils are long and go deep into the cylinder head, you have to pull them straight up to even be able to wiggle them out and that's why the intake must come off.
You also have to be mindful that the coils have a spring that reaches the spark plug and the last thing you want to risk is damaging the spring, it's much less of a headache to just remove the intake. It's 8 bolts right up top and and if I recall 3 quick connect hoses, it won't kill you lol
The Following 3 Users Say Thank You to fatrabbit For This Useful Post:
coloradofjr (05-25-2015), LS1Heli (04-09-2015), volume (04-09-2015)
post #24 of (permalink) Old 04-09-2015
volume's Avatar
Well if you going to take the intake out anyway clean the valve
volume is offline
post #25 of (permalink) Old 04-09-2015 Thread Starter
LS1Heli's Avatar
Thanks for the replies gents.
The 3.5L and 3.9L w/ 4spd are complete and utter jokes compared to the LFX and 6spd transmission...trust me, I've had all three (2006, 2009, 2013). With E85, a K&N intake, Vmaxx spiral TB, and Magnaflow CB, my 0-60 is < 6 secs. A bigger joke than those two? The 3.4L turd in my old 2004.
Back to the plugs, taking the intake off won't be a problem, but finding torque sequence will cost me because you have to get a service manual. Haynes and all those guys only go up to 2011. I wouldn't mind taking it off, I actually want to so I can see what is going on there. I assume this is an air only intake and doesn't have liquid ports..
And thanks for the pictures, because that is what I was seeing with my eye. If you never have changed plugs on a DOHC engine, you would understand like fatrabbit said. They go very deep into the head.
LS1Heli is offline
post #26 of (permalink) Old 04-09-2015
Ryfly05's Avatar
According to alldata which is the same as the factory service manual, torque spec for the intake bolts are 25Nm or 18 Ft/Lbs. No more excuses
If you don't want to spend $200 for the printed factory manuals, alldatadiy.com has the same info on a subscription basis. I got a code for 2 years access for less than 15 bucks. Id be happy to give it to anyone that pms me. Best money on your car you'll ever spend for the diy'ers.
Daily: 2013 Imp LTZ
Ryfly05 is offline
The Following 4 Users Say Thank You to Ryfly05 For This Useful Post:
coloradofjr (05-25-2015), fatrabbit (04-09-2015), LS1Heli (04-10-2015), volume (04-09-2015)
post #27 of (permalink) Old 04-10-2015
Ryfly05's Avatar
Just wanted to clear up some confusion about my last post. I've gotten some PM's asking for my own subscription to AllData. That wasn't what I was offering. I'm offering a coupon code for your own subscription for 2 years access for less than 15 bucks, which is an awesome deal and a must-have if you do your own work on your car! Thanks.
Ryan
Daily: 2013 Imp LTZ
Ryfly05 is offline
post #28 of (permalink) Old 04-15-2015
M@ven's Avatar
Quoted: 4 Post(s)
edit
post #29 of (permalink) Old 04-16-2015
2007Imp850's Avatar
Quoted: 59 Post(s)
I hate to muck up this thread with questions but, Instead of paying the shop damn near $400 to do plugs and wires, I'd love to be able to do it myself and save a bunch of money. So on the older 3.5s(2007) I DONT need to pull the engine forward? I should be able to get to the plugs without moving the engine forward?
2014 Limited Impala LT
2007Imp850 is offline
post #30 of (permalink) Old 04-16-2015
yzf125's Avatar
Quoted: 7 Post(s)
Thats correct, I just did my 2010 Impala with the 3.5 and I only had to remove that plastic cover on top and you have to remove the coil block on the rear pass side by the alternator. There is 4 10mm bolts holding that on. take the plug wires off the coil block and disconnect the wire harness to it. ( wires and coil block are numbered so it wont get messed up ) If not make sure you label them.
You dont need a universal either,
2015 Chevy Impala Limited 3.6 - 2001 Chevy Impala 3.4
yzf125 is offline
How difficult is it to replace the rear spark plugs in a 06 Imp SS? Scrappy Autocare and Maintenance 18 03-23-2019 05:54 PM
5.3 Wrong Spark Plugs Mr312712 Chevy Impala 8th Gen Discussion 4 09-25-2018 08:04 AM
Rear spark plugs 2014+ LFX 1994Vmax Chevy Impala 9th Gen Discussion 4 02-03-2018 09:28 AM
'08 Impala SS Spark Plugs RUNSwithSCISSORS Chevy Impala 9th Gen Discussion 5 01-27-2018 09:33 AM
AC Delco Spark Plug 45TS in Original Box set 8 Spark Plugs 5613246 RSS Bot Impala Diecast Toys Cars on eBay 0 08-29-2017 10:00 AM
