Do you know for a fact that distributing THIS manual is illegal?
It says no where on any of the PDF's anything about copyright or do not distribute. It only says on some of the images courtesy of GM.
Many of the vehicle specific forums I frequent have a PDF of the factory service manual available for free download. The Dodge forum I spend a lot of time even made the damn thing a sticky.
^^ So this is just a "factory service manual"? Gotcha I thought you were talking a repair manual like haynes, etc. Those likely have copyright protection
I have a 2006 Chevy Impala. I paid $2500 this past summer at Pep Boys for A/C repair since it had stopped cooling. Before that repair the car was fine. Since this expensive repair I have had to jumpstart the battery every week to 2 weeks. I bought a new battery less than 2 months ago. And still have to jumpstart every week to 2 weeks. The alternator has been tested twice with a reliable testor & tests fine. Nothing is being left on to kill the battery. In fact the car starts fine each day in between jumpstarts. Also, the power locks started malfunctioning after the a/c repair. Only the driver door lock responds & the other 3 don't. However after each jumpstart or with new battery installation the other 3 doors involuntarily unlock. Of course then I have to manually go around & relock them & they do not respond again until jumpstart. I realize I will need to take the Impala in for repair again but am not likely to return to Pep Boys as another expensive repair there would lead to a more expensive repair in a few months. Any thoughts on what the source of this problem could be
and where to take the car?
Don't bother with Fleabay unless it's for laughs. The manual mafia has em listed for $285. The set I just saw was well loved... It wouldn't meet ABE Books Fair condition. More like Binding Copies... I wouldn't pay over $100 for that set in that condition but they'll eventually get some rube to do it.
^ arkan768, atf change is easy-peasy on the '12/'13's. Much like an eng. oil change. On the bottom of the tranny, drivers side, locate the 11mm drain plug. Place a clean/empty drain pan below and remove. Funnel contents into an empty 5 qt. oil jug with a side sightglass. Replace the measured amount with new Dexron VI atf. I use Supertech Dexron VI from Wallyworld @ $4.27/qt. Takes ~4-5 qts. Don't even have to jack up the car. Filter/screen is not serviceable. Tranny has to be removed and case cracked open for that.
thats what I am thinking as well.
just never had to deal with this transaxle, with internal magnetic filter. i just hit 50k and the fluid already a bit discolored and smelly.
I think the manual states 100k mile ATF changes, but most people here seem to agree that it should be changed every 50k at a minimum. Don't worry about the filter in the trans - it's not meant to be changed - dealerships don't change it either. It's designed so that it never needs changed (supposedly, anyway).
Luckily, there is a drain plug, so the ATF fluid changes are very easy....
Is it possible to get a copy. I have 06 impala SS and need to drop the engine pan to replace O-ring. My email is Leeej@hotmail.com. Many thanks ahead !
Status
Not open for further replies.
You have insufficient privileges to reply here.
