Repair manual - Page 2 - Chevy Impala Forums
 3Likes
post #16 of (permalink) Old 04-30-2015
anewlevel0419's Avatar
Awesome
anewlevel0419 is offline
post #17 of (permalink) Old 04-30-2015
sending pm
post #18 of (permalink) Old 04-30-2015
gt52842's Avatar
repair manual
Originally Posted by TONEPAQ View Post
So I bought a digital copy for my 2006 (should be the same for all several years)
It covers all engine types and is very detailed and very thorough. If anyone needs a copy let me know.
I would like to get a copy to help while working on my 2007 SS. My work E-Mail is [email protected] , and thank you for your time, Respectfully, Gary Thompson.
gt52842 is offline
post #19 of (permalink) Old 06-16-2015
arkan768's Avatar
Hello there, if I am planning on transmission work such as oil change, is there a part about a trans for 2012 v6 model?
2013 Impala LT v6 301hp front-wheeled fury.
arkan768 is offline
post #20 of (permalink) Old 06-17-2015
Quoted: 171 Post(s)
^ arkan768, atf change is easy-peasy on the '12/'13's. Much like an eng. oil change. On the bottom of the tranny, drivers side, locate the 11mm drain plug. Place a clean/empty drain pan below and remove. Funnel contents into an empty 5 qt. oil jug with a side sightglass. Replace the measured amount with new Dexron VI atf. I use Supertech Dexron VI from Wallyworld @ $4.27/qt. Takes ~4-5 qts. Don't even have to jack up the car. Filter/screen is not serviceable. Tranny has to be removed and case cracked open for that.
sheila is online now
The Following User Says Thank You to sheila For This Useful Post:
arkan768 (06-17-2015)
post #21 of (permalink) Old 06-17-2015
arkan768's Avatar
so in order to service the filter, you need to drop the tranny?
arkan768 is offline
post #22 of (permalink) Old 06-17-2015
Quoted: 171 Post(s)
....and crack open the case. No need to worry about the filter/screen. GM claims it's "lifetime", lol.
post #23 of (permalink) Old 06-18-2015
arkan768's Avatar
cool, although after going through the manual it doesnt describe anything about atf changes, only engine oil/
and it says specifically to service it only at the dealer, does it mean that they drop the tranny at the dealers?
arkan768 is offline
post #24 of (permalink) Old 06-18-2015
Quoted: 171 Post(s)
You're overthinking this, lol. I'd recommend the drain/fill procedure ea. 30k mi.
post #25 of (permalink) Old 06-18-2015
arkan768's Avatar
thats what I am thinking as well.
just never had to deal with this transaxle, with internal magnetic filter. i just hit 50k and the fluid already a bit discolored and smelly.
arkan768 is offline
post #26 of (permalink) Old 06-18-2015
Quoted: 930 Post(s)
I think the manual states 100k mile ATF changes, but most people here seem to agree that it should be changed every 50k at a minimum. Don't worry about the filter in the trans - it's not meant to be changed - dealerships don't change it either. It's designed so that it never needs changed (supposedly, anyway).
Luckily, there is a drain plug, so the ATF fluid changes are very easy....
post #27 of (permalink) Old 06-18-2015
arkan768's Avatar
surely appears so. thx for the help.
arkan768 is offline
post #28 of (permalink) Old 12-27-2015
Techhead1's Avatar
Cool
Are you selling the manual? I have a 2007 Impala and need more detail than a Chilton/Haynes manual.
Techhead1 is offline
post #29 of (permalink) Old 11-08-2016
Zeus01's Avatar
I'm in need of a manual for my 07 impala. I just bought this impala and discovered the cel has been disabled not sure how yet, I'm still needing to pull out the cluster to see. Any help would be great.
Zeus01 is offline
post #30 of (permalink) Old 04-13-2017
Size_Atx02's Avatar
Quoted: 14 Post(s)
I could use it if you still have it, or if not where can I get a copy? Thanks a bunch.
Size_Atx02 is offline
2002 Repair Manual datgrlyouenvy Autocare and Maintenance 1 03-05-2018 08:33 AM
Best 1963 Chevy Repair Shop Manual 63 Impala Bel Air Biscayne Chevrolet Wagon RSS Bot Impala Diecast Toys Cars on eBay 0 09-21-2017 06:10 PM
Best 1962 Chevy Repair Shop Manual 62 Impala Bel Air Biscayne Wagon Chevrolet RSS Bot Impala Diecast Toys Cars on eBay 0 09-21-2017 06:10 PM
Repair Manual Haynes 24047 fits 06-11 Chevrolet Impala RSS Bot Impala Diecast Toys Cars on eBay 0 09-11-2017 02:30 AM
1968-83 CHEVY Bel Air Biscayne Brookwood Caprice Impala Kingswood repair manual RSS Bot Impala Diecast Toys Cars on eBay 0 07-29-2017 09:40 AM
