Lost A/C - bad ECM?! - Chevy Impala Forums
 8Likes
  • 2 Post By Sammy
  • 2 Post By John Craker
  • 2 Post By 12 lt
  • 2 Post By sheila
post #1 of (permalink) Old 08-04-2019 Thread Starter
John Craker's Avatar
Unhappy Lost A/C - bad ECM?!
'06 5.3L (E40 ECM of course).
Just wondering if this has happened to anyone else.
Scan tool reads 0psi on the high pressure sensor. Manifold gauge hanging there reads about 45psi. Changed the sensor with a spare, no change. Has +5 and ground at the connector. Confirmed continuity from the sensor connector, right back to pin 26 on the ECM. Saw lots of mouse nests and piss near/under/around the ECM, so pulled it and took it apart (FYI - don't do this!) to make sure nothing got inside. Still has a good connection right to the PCB.
I'm down to.... replace the ECM!! :O
I've ordered another - see how it works I guess.
John Craker is offline
post #2 of (permalink) Old 08-04-2019
Sammy's Avatar
My 06 3.9 had intermittent AC not working aways back.
Turns out it was the ambient air sensor at the hood latch. My wife just happened to notice the outside air temp display on the dash was 22 degrees when it was actually 90 some degrees out. Replaced the sensor for five bucks and all is well.
plano-doug and Tesla like this.
Sammy is offline
post #3 of (permalink) Old 08-04-2019
hatzie's Avatar
Quoted: 150 Post(s)
Are you sure sure sure the wires and terminals from and to the ECM are not damaged by the mouse urine?
2009 Impala SS
hatzie is offline
post #4 of (permalink) Old 08-05-2019 Thread Starter
Unfortunately, yes. Checked from the connector, right to the backside of the ECM on it's PCB.
post #5 of (permalink) Old 08-05-2019
hatzie's Avatar
Quoted: 150 Post(s)
The compressor connector to the terminals on the ECM... I hope
2009 Impala SS
hatzie is offline
post #6 of (permalink) Old 1 Day Ago Thread Starter
Forgot to follow up on this....
New ECM, finally got my PC to talk to one of my interfaces that would talk to the car through TIS2000 (that was a 2 week battle unto itself). Reflashed new/used ECM.
Still didn't work. Rechecked sensor, rechecked all wiring.
Pulled schrader valve to make sure it wasn't clogged. Recharged AC.
Hooked Tech2 up (had been using a few of my other diag tools before). Seems that IT KNOWS of a DTC that the other ones didn't!
Cleared code - AC works.
And of course, all the days I was without it, it was in the high 20's (C). Now it works, we're supposed to have a high of.... 12.
Quoted: 168 Post(s)
What was the code?
Quoted: 232 Post(s)
Not with the impala, but have had issues with the pcm(powertrain control module) on our 08 durango that has caused all kinds of issues, including the ac not working and the dash/gauges acting crazy. Computer glitches can cause all kinds of intermittent problems and throw codes that have you tracking down a problem that is not the true issue. We had been having an mds(active fuel management) issue with our durango as well that I am almost certain is related to faulty pcm. Moisture seems to bring on strange erratic behavior from the pcm with our situation.
As to the mice damage, have had plenty of issues with damage from those rotten things. Recently had a 2 wire connector to a relay for our honda 4 wheeler that was chewed and shorted. Spent too much time tracing down that problem. I hate mice.
hatzie and sheila like this.
Quoted: 168 Post(s)
^+1. I hate meeses to pieces. Kill 'em all, lol!
hatzie and kbz1960 like this.
post #10 of (permalink) Old 1 Hour Ago
hatzie's Avatar
Quoted: 150 Post(s)
I add peppermint oil to the soap injector for rinsing things in the engine bay down. The rodents seem to find other places to be.
El Gato helps as well...
2009 Impala SS
hatzie is offline
