2014 Impala Limited LTZ 3.6l engine shudders then dies - Chevy Impala Forums
 9Likes
  • 4 Post By 1999 White C5 Coupe
  • 4 Post By skvo67
  • 1 Post By sonjaab
post #1 of (permalink) Old 07-28-2019 Thread Starter
skvo67's Avatar
Quoted: 7 Post(s)
I have a 2014 w/ 102k on it and it started shuddering at low RPM then died on me the other day. No codes and would start right back up then die again. Fortunately I was close enough to home to coast in. Parked it next to the garage and it started right up again in the morning. I've tried several searches on here and come up with nothing. Any ideas would be welcome.
skvo67 is offline
post #2 of (permalink) Old 07-28-2019
Quoted: 209 Post(s)
I’d bet the inside of your throttle body bore, and the edge of the butterfly valve is covered with “crud” - and dirty. This would prevent the necessary airflow at idle, causing the engine to stall.
Remove the throttle body air intake hose and examine the inside. If it is not shiny and clean, you will have to clean it.
Buy some spray throttle body cleaner (not carburetor cleaner - can damage oxygen sensors), and liberally spray the inside of the throttle body (cold engine and engine off), until the cleaner runs out clean. You’ll have to place number towels or paper towels under the throttle body to catch the run-off. The cleaner is very flammable - use caution.
You have an electronic throttle body - not a mechanical one. As such, don’t reach inside and move the butterfly valve with your hands or a tool. This could damage the control.
Also check the condition of your engine air filter.
plano-doug, sheila, 12 lt and 1 others like this.
post #3 of (permalink) Old 07-30-2019 Thread Starter
skvo67's Avatar
Quoted: 7 Post(s)
Did some more research and I found several threads on other forums that said the same thing. Took the throttle body off and cleaned the crap out of it. The air cleaner, K&N, was fine but I cleaned it just in case. Car seems to be running fine now. Thanks for the quick reply
skvo67 is offline
post #4 of (permalink) Old 08-05-2019
sonjaab's Avatar
Quoted: 21 Post(s)
You have a K&N filter?
Thats causing your problem.
sonjaab is offline
