Thinking of purchasing a 2012 or 2013 Impala LTZ - Page 5 - Chevy Impala Forums
 38Likes
post #61 of (permalink) Old 06-16-2019
Quoted: 240 Post(s)
Originally Posted by Derkach99 View Post
One other question i have is with the TPMS sensors in the tires how long do they last? Any reliability issues?
No issues with the sensors in our 2012.(knock on wood)
post #62 of (permalink) Old 06-16-2019
WickedGoat's Avatar
Quoted: 141 Post(s)
I think my car was put into service some time in 2013 and mine are still the factory pieces. I have done one set of tires so far and have not had any issues. In fact, the dealership didn't even try to sell me the TPMS maintenance. Without looking, I'll bet a set of 4 can be had cheaply on Ebay or RockAuto.
2014 Chevy Impala LTZ Limited
- 5% Window Tint, Rosen GM1210 Stereo, Polk Audio Components and 6x9s, Pioneer, Kenwood amps and sub, Addco Rear Sway Bar, ZZP Strut Tower Braces, LED fogs and low beams, back up and interior lighting, SS dash, stereo and shifter trim.
2004 Pontiac GTO
- Quicksilver on Black 6 speed, garage queen
2004 GMC Yukon SLT
- The reliable back up... can't part ways with it!
2016 GMC Acadia Denali
- Quicksilver on Black, AWD, rear DVD, 2/2/3, nice...
WickedGoat is offline
post #63 of (permalink) Old 06-17-2019
VladThe's Avatar
Quoted: 30 Post(s)
I don't find the TPMS to be particularly useful 99.9% of the time. I guess if there were a problem that went unnoticed it would be nice to get the alert (One time I have riden on low tires and had to pay to replace because the tire was not noticed and patched in time).
Looking at the cost to replace being too high for the value I get from the TPMS, I wonder if there is a way to just turn off the TPMS warning system entirely if/when it fails?
sheila and kbz1960 like this.
VladThe is offline
post #64 of (permalink) Old 06-17-2019
kbz1960's Avatar
Quoted: 26 Post(s)
Would be nice to know but I'm doubting it.
kbz1960 is offline
post #65 of (permalink) Old 06-17-2019
RossoRacer's Avatar
Quoted: 9 Post(s)
Is yours the kind that shows individual tire pressures or just gives a warning light when one of the tires is a little low? Either is available in many vehicles, or at least was 9 years ago, and my Patriot has the single warning light. My tires usually get a little low anyway because I don't keep up with them like I should, but they still keep a decent bit of air in them. When I last had the tires in my Jeep changed, the sensors were falling apart and I needed something to hold the air in. I couldn't afford new sensors, so they just slapped in standard valves. The side effect to this? That low tire light blinks for a few minutes when I first start the vehicle, then stays solid the rest of the drive, letting me know it can't find a sensor. Not the cleanest dash look, but I didn't have to shell out for sensors either.
For God so loved the world that He gave His only begotten Son, that all who believe in Him might not perish but have everlasting life. -John 3:16
Also, 'Merica. Yee Yee.
RossoRacer is offline
post #66 of (permalink) Old 06-19-2019 Thread Starter
Derkach99's Avatar
Quoted: 13 Post(s)
What do you guys think of the fog lights on the LTZ's
Derkach99 is offline
post #67 of (permalink) Old 06-19-2019
Quoted: 254 Post(s)
in my experience fog lamps look nice but don't add much light except within 10 feet of the car. if you had an impala without fogs and wanted to add fogs, i think it is possible to do so but it takes more work than you might think. wiring kits, brackets, cutting the existing bumper if you don't get the correct bumper with the cutouts already in place, and even possibly having to reprogram the body control module to make them work properly.
if you want them, it is easier to pick a car that has them from the factory than to install them later one.
i have them in my silverado LTZ and 99% of the time forget to turn them on at all.
Joes74challenger is offline
post #68 of (permalink) Old 06-20-2019 Thread Starter
Derkach99's Avatar
Quoted: 13 Post(s)
What are you recent experiences in doing the H9 mod for your headlights?
post #69 of (permalink) Old 06-21-2019
WickedGoat's Avatar
Quoted: 141 Post(s)
I like the fog lamps especially where I travel in low lit areas at times. Every little bit helps. And I will tell you to just go LED on the low beams and fogs and call it good. High beams are optional, but I think you will be happier with LEDs. I just did mine and am happy with them.
2004 Pontiac GTO
2004 GMC Yukon SLT
post #70 of (permalink) Old 06-22-2019 Thread Starter
Derkach99's Avatar
Quoted: 13 Post(s)
I have always thought about going that route with my Aurora but I didn't want to trial and error with them in terms in dependability and fitment and the cost as well as the fact halogen housings are not meant to accommodate them properly, I went with the HIR mod in my Aurora but i realize in the Impala i can't do that. What led kits do you use and did it require modification?
post #71 of (permalink) Old 06-22-2019
WickedGoat's Avatar
Quoted: 141 Post(s)
I just went through a little bit of trial and error. Luckily, I only went through 2 sets of bulbs, with the 2nd set being the winner. Read all about it here...
https://www.impalaforums.com/chevy-i...foglights.html
2004 Pontiac GTO
2004 GMC Yukon SLT
post #72 of (permalink) Old 06-22-2019 Thread Starter
Derkach99's Avatar
Quoted: 13 Post(s)
I have read that article, my my understanding you had to modify the headlight housing to make those lights fit correct?
post #73 of (permalink) Old 07-14-2019 Thread Starter
Derkach99's Avatar
Quoted: 13 Post(s)
Well I am back again, unfortunately the black Impala sold a few weeks back but I found another in like new condition that just arrived at a dealership near me. They want about 15k CAD for it but i want to knock them down a few thousand. I took her for a test drive a few days ago and wow so smooth and powerful. There website has no pictures yet but I took a few after my test dive, it has a black interior but with tan seats and armrest. Let me know what you think.
https://www.marynurse.com/VehicleDet...-ON/3466785553
https://www.dropbox.com/s/lqos53sz9a...3_HDR.jpg?dl=0
https://www.dropbox.com/s/o0l4qtolaw...5_HDR.jpg?dl=0
post #74 of (permalink) Old 07-14-2019
WickedGoat's Avatar
Quoted: 141 Post(s)
I didn't have to modify the housings with either set. The first set just wasn't a good fit with its design. The 2nd set, from BPS lighting, was much better for a couple of reasons... shape of the bulb was similar to a stock halogen and direct plug in to the bulb instead of into a wire that runs into the bulb. The first set of bulbs had radio interference issues also. The BPS bulbs are much better for the 8th gen Impala in my opinion if you are looking for true plug and play with no modifications. The two year warranty is cool too.
2004 Pontiac GTO
2004 GMC Yukon SLT
post #75 of (permalink) Old 07-14-2019
WickedGoat's Avatar
Quoted: 141 Post(s)
$14,990 Canadian is $11,500 USD... so in my opinion they can come down some in price, don't know about the few thousand you were thinking, but I think at least 1500 to 2000 lower would be good. I know this much... the 8th gen Impalas don't sit long on dealer lots around here. I would say go for it if you like the color combo and it is mechanically sound. I would offer 3000 less and negotiate accordingly.
2004 Pontiac GTO
2004 GMC Yukon SLT
