Pls Help Diagnose Misfire - Page 2 - Chevy Impala Forums
 12Likes
post #16 of (permalink) Old 06-21-2019
sidemouse's Avatar
Quoted: 14 Post(s)
Originally Posted by DonH View Post
Thank you Sidemouse and Hatzie. As noted in the original post, I did replace the plugs with the same iridium plugs. Existing plugs were original. I did swap the #3 wire with another and still saw #3 misfire on mode 6 data, only at idle. At 1000rpm or greater it does not misfire. Go figure.
Thanks all and keep the ideas coming.
I just wanted to add, my 2007 does a little stumbling at idle too, it will be running and then like a hiccup... I presume it's a misfire but it's not constant and like you it's only at idle, also my CEL comes on and then goes back off... I have replaced plugs and wires and also the MAF sensor and throttle body, new air filter so if it's in the injectors and so long this is all it does I'm going with the old "if it ain't broke don't fix it."
I have been running tank after tank of premium fuel (93 octane) through it to see if that cleans it up any.
But like I said if that's as bad as it gets I'm not fixing it.
Also for reference I used standard copper core spark plugs gapped to .030
Those will run a good 40,000 miles before needing regapped / replacing.
What I have learned is gap erosion is roughly .005 per 5-10k miles.
I do believe the 'proper' gap for Impalas is .040 but with .030 that's another 10k miles I get out of it before erosion takes its toll.
Granted some folks don't care for that job so Platinums are good for 50k, double plats 75-80k and Iridium's are good for 100k or more.
Gap erosion is strongest with softer metals.
Single platinum still suffers strongest erosion on the soft metal end, thus lasting about 1.5x that of standard plugs.
Double platinum should last 2x as long as standard plugs.
And iridium being the strongest metal, 3-4 times as long.
Those figures are estimates based on my own experience, your mileage may vary.
sidemouse is offline
post #17 of (permalink) Old 06-23-2019
carnau's Avatar
Quoted: 23 Post(s)
You're right. The gap is 0.040.
Spark Plug Gap
1.02 mm
0.040 in
Most of the time when you have a stumble at idle it is doe to the injectors. We have a time with the injectors on these engines causing multiple codes once it gets bad enough.
I don't know if you have a scanner where you can do a Fuel injector balance test. But if you do on these injectors cold, you want to see more than 60psi of drop and hot above 57psi. Anything under that will start causing fuel trim code, a cold idle code or even possible a misfire.
But I am right there with you, If it's not broken (setting a DTC) Don't fix it. lol
GM Master Technician 20 Years Experience.
Automotive Instructor at Williamsburg College
ASE Certified
My DIY Auto Repair Videos
www.youtube.com/cdarnau
carnau is offline
Misfire after replacing oil pressure sensor on 07 LTZ Bobo1516 Autocare and Maintenance 0 03-03-2019 05:06 PM
2000 3.8 series 2 misfire. I'm in need of some input please screwlegg Chevy Impala 7th Gen Discussion 3 12-07-2018 11:47 AM
Intermittent misfire and lean fuel jdeville 9th Gen Engine Performance 0 04-30-2018 01:22 AM
Misfire #4 cylinder Bigbubble95 Chevy Impala 8th Gen Discussion 8 01-03-2018 04:51 AM
