Remote start disabled P0521 - Page 2 - Chevy Impala Forums
 3Likes
post #16 of (permalink) Old 03-06-2019
hatzie's Avatar
Quoted: 154 Post(s)
Originally Posted by Mr312712 View Post
Been really cold here the past few days. Was 9 degrees this morning and I remote started It and came out to It ticking quite loudly and I Immediately pushed the button to shut It off. Got In and pulled up oil pressure on the tuner and started It back up and It didn't even have 10 PSI. Idling up to 2k brought It to normal pressure. The ticking didn't go away until I actually drove away, revving In park did nothing for the ticking. I'm hoping the ticking was the heads as the bottom end gets oil first. As I was about to pull out It started losing pressure again dropping below 10 and I shut It down until cars passed and when I started driving It was fine. Why did It not shut down, Idk. But I'm questioning could It possibly be the oil pump? When I started driving I pulled over up the street and let It Idle and It had 40+ PSI Idling and the engine was still cold. It's just that Initial cold start when It doesn't have any. Thanks.
It could be the oil pump or just the pickup O-Ring has really gone away on you.
The LS oil pumps are driven off the crank snout so you'll have to pull the timing cover to change it.
Google how to pre-fill the oil pump. Not sure if the LS4 is the same as the RWD LS motors or not so it would be a good idear to find instructions that are LS4 specific.
2009 Impala SS
hatzie is online now
post #17 of (permalink) Old 03-11-2019 Thread Starter
Mr312712's Avatar
Quoted: 14 Post(s)
Went to a shop to get an estimate and was quoted $560.00 for 7 hours of labor. And that's with me supplying the oil pan gasket, o ring and oil and filter. So I guess not so bad. My alternator died Saturday so I just replaced that today twice. First one lasted an hour and the second one Is going good for now.
Mr312712 is offline
post #18 of (permalink) Old 03-13-2019
hatzie's Avatar
Quoted: 154 Post(s)
Be sure to use the 12643081 oil pan gasket. Even if you don't have oil consumption issues this is the part to use.
Check with GM for a service history. If the oil consumption TSB has already been performed on your car the updated oil pan gasket is riveted to the LS4 oil pan rails and it's re-usable.
Price an oil pump swap too... Get a stock pressure and volume Melling M355 for the LS4.
2009 Impala SS
Remote Start Duration Majozak Audio, Video, and Electronics 2 02-10-2019 01:48 PM
2013 Chev Impala LT Fleet pbm1204 Automotive Discussion 4 11-23-2018 05:44 PM
remote start 08cngimpala Chevy Impala 9th Gen Discussion 8 04-28-2018 02:31 PM
Remote start didn't want to work this morning TeeRev Chevy Impala 8th Gen Discussion 12 12-14-2017 11:46 AM
gps starter disabler, remote start, What do I do ? noimaD Mechanical and Electrical Problems 11 11-28-2017 07:17 AM
