Help - 2006 SS with code P0300 - Mechanic says I need a new engine - Chevy Impala Forums
 14Likes
  • 1 Post By 12 lt
  • 2 Post By reubenswinks
  • 1 Post By Z71
  • 4 Post By Patty2730
  • 3 Post By hatzie
  • 1 Post By carnau
  • 1 Post By mdubyk
  • 1 Post By HOTLAP
post #1 of (permalink) Old 01-03-2019 Thread Starter
Patty2730's Avatar
Quoted: 5 Post(s)
The check engine light came on so I had Autozone check the code while I was buying wipers. They said it was code P0300 which usually means a bad spark plug. I took it to a local shop to get the plugs changed and they called me the next day with the following information:
Cyl 1 Skipping.
Engine Pulling Vacuum in Crank Case
No compression on CYL 1. Probably has sticking valve or stuck/broken piston. Needs new engine. Estimated cost $6000.
The car runs fine except for a very slight, almost unnoticeable "stutter" when you first start the car. No knocking or pinging. No lack of power or overheating.
SHould I take it to another shop and get a second opinion or is this a common thing?
Patty2730 is offline
post #2 of (permalink) Old 01-03-2019
Quoted: 338 Post(s)
Cyl 1 Skipping.
On the LS4, cylinders 1, 4, 6, and 7 comprise the active fuel management system. I suspect your cylinder #1 problem is AFM related, such as a lifter gone bad.
I can't tell you the cost of repair, but I'd like to think you could get the AFM lifters replaced for well under 6k. That said, according to my factory manual, you have to pull the heads to swap lifters, which is well beyond the usual for cam-in-block Chevy small-blocks of the past, so that will add cost - it's quite a bit more than just pulling the intake.
I'm facing the same thing on mine, but for now, it's parked waiting for me to get around to it
plano-doug is online now
post #3 of (permalink) Old 01-03-2019
Quoted: 228 Post(s)
A broken piston you would definitely notice an issue with the car's performance. Yep, wouldn't hurt to get another opinion. Would not tell them what the first mechanic said until after they diagnose it.
hatzie likes this.
12 lt is online now
post #4 of (permalink) Old 01-04-2019
reubenswinks's Avatar
Quoted: 89 Post(s)
Cyl 1 Skipping.
P0300 is a random misfire code. I would expect if you had zero compression on cylinder 1 you would have P0301. I would be very suspicious of the first diagnosis.
If you are a little handy, and want to potentially save money and not have to pay another diagnostic fee elsewhere, you could check compression yourself.
Buy something like this
Cylinder 1 I believe is front bank and on the passenger side (someone correct me if I'm wrong) so it should be easy to get to. Technically you are supposed to pull the plugs on all cylinders to test compression, but I wouldn't bother. It will quickly tell you if there is zero compression on your cylinder.
reubenswinks is offline
post #5 of (permalink) Old 01-04-2019
rjayl's Avatar
Quoted: 27 Post(s)
The short answer is yes.
rjayl is offline
post #6 of (permalink) Old 01-08-2019
Z71
Z71's Avatar
Quoted: 15 Post(s)
A cylinder compression and leak down tests should be done to assess the condition of the engine.
I agree that this issue is almost certainly AFM lifter related. AFM is the main reason why I never bought an Impala SS. I read about way too many failures of the AFM system on 2007+ Chevy trucks.
Z71 is offline
post #7 of (permalink) Old 6 Days Ago Thread Starter
Patty2730's Avatar
Quoted: 5 Post(s)
Been meaning to come back and update this post with the results. Had the spark plugs changed. The error code went away. Been running great for the past several months.
Thanks to everyone who replied!
plano-doug, hatzie, sheila and 1 others like this.
The Following 2 Users Say Thank You to Patty2730 For This Useful Post:
12 lt (3 Days Ago)
post #8 of (permalink) Old 5 Days Ago
hatzie's Avatar
Quoted: 145 Post(s)
Thanks for the after action report.
Always a good idear to step back and look at the basics.
I think I'd stay away from the guy that wanted to rebuild your engine.
carnau, 12 lt and kbz1960 like this.
2009 Impala SS
hatzie is offline
post #9 of (permalink) Old 4 Days Ago
carnau's Avatar
Quoted: 23 Post(s)
A 2006 5.3 does not have active fuel management. It started in 2007.
GM Master Technician 20 Years Experience.
Automotive Instructor at Williamsburg College
ASE Certified
My DIY Auto Repair Videos
www.youtube.com/cdarnau
carnau is offline
post #10 of (permalink) Old 3 Days Ago
hammerjack67's Avatar
My '06 SS has DOD. Is that different from AFM?
hammerjack67 is offline
post #11 of (permalink) Old 3 Days Ago
Quoted: 228 Post(s)
Good to hear you got it straight and was not a major issue.
Thanks for reporting back, sure this will help someone in the future.
Could not agree more. Amazing how some will try to take advantage of others.
12 lt is online now
AdamLyth's Avatar
Nice post. . .
AdamLyth is offline
mdubyk's Avatar
Quoted: 15 Post(s)
Sounds like you need a new mechanic.
mdubyk is offline
post #14 of (permalink) Old 2 Hours Ago
HOTLAP's Avatar
Quoted: 17 Post(s)
I'd be inclined to stop by this shop and inform the owner/manager, it may just be a bad shop or it could be a good shop with a bad mechanic and the owner should know about your experience. I'd do it just to see what their reaction is.
2013 LT
HOTLAP is offline
06' Impala SS engine cranks but not start p0335 code Stan SS Chevy Impala Discussion 0 05-08-2019 07:22 PM
2006 SS AC Compressor Shot Mikerad89 Chevy Impala 9th Gen Discussion 0 07-19-2018 10:58 PM
SS Rant Yanis07Imp Chevy Impala 8th Gen Discussion 9 02-13-2018 04:10 PM
2006 Impala SS Cranks But Won't Start After Changing Engine fridaysresale7 Automotive Discussion 4 09-18-2017 11:50 PM
