Engine unable to align with frame while replacing engine mount - Chevy Impala Forums
 3Likes
  • 1 Post By Davec2008
  • 1 Post By 1970cs
  • 1 Post By James06
post #1 of (permalink) Old 12-16-2018 Thread Starter
James06's Avatar
I'm trying to replace the passenger side lower engine mount in my 2006 Impala. I get the old mount out and put the new mount in. However, the engine moved a half inch to the front when I jack it up. Now with the mount bolted to the engine, I can't align it with the holder on the frame.
Thinking lowering the engine might move it back, I also tried to put the mount on the frame before fastening it to the engine. Then when I lower the engine, the engine still sits on the mount bracket with about a half inch offset.
Does anyone know how I can move the engine a bit backwards to align it correctly? Thanks in advance!
James06 is offline
post #2 of (permalink) Old 12-17-2018
Davec2008's Avatar
Quoted: 7 Post(s)
I had the same problem with my 2004 Monte Carlo SS. did you use an engine hoist to raise the engine? If so just move the pivot point on the chain a couple of links so the top of the engine tilts toward the front, then the motor mount will point closer to the firewall. Be sure you bolt the mount to the motor first, if you lower the motor onto the mount already in the frame there's no way to get the bolts aligned with the holes in the engine.
Dave
Just picked up a 2008 Impala LT after my 2004 Monte Carlo SS died.
Davec2008 is offline
post #3 of (permalink) Old 12-17-2018 Thread Starter
James06's Avatar
Unfortunately, I don't have an engine hoist. I'm using a jack to raise the engine. I'm now trying to move it by rotating the jack. But it's really painful because my driveway is not perfectly even.
James06 is offline
post #4 of (permalink) Old 12-18-2018
Davec2008's Avatar
Quoted: 7 Post(s)
Good luck, you might be able to use a long board wedged in front of the engine to try and pry it back, but not sure if that would work. Might need a couple of strong friends to push it back as you lower the jack.
post #5 of (permalink) Old 12-19-2018
1970cs's Avatar
Quoted: 41 Post(s)
If you have a good anchor point, try a ratchet strap.
Pat
1970cs is offline
post #6 of (permalink) Old 12-24-2018 Thread Starter
James06's Avatar
Thank you very much for your suggestions!
I eventually get it done. I jacked it up and then pushed the jack while rotating it. I learned the lesson that never jack up things on a uneven floor. My driveway is rough with a small slope. It took me a huge effort to push it a tiny bit. Eventually, I bought some wood board to stack under the jack to make it both smooth and level. It became a whole lot easier after that. Hope my experience would help some one in the future.
James06 is offline
Engine mount SynDave Chevy Impala 7th Gen Discussion 0 04-27-2018 12:32 PM
Engine Mount 31-2243 HD Compatible Westar EM-2284 Engine Mount, Front RSS Bot Impala Diecast Toys Cars on eBay 0 08-31-2017 03:10 AM
Engine Mount 31-2243 HD Compatible Westar EM-2284 Engine Mount, Front RSS Bot Impala Diecast Toys Cars on eBay 0 08-23-2017 04:10 AM
