ABS Nightmare - Chevy Impala Forums
 7Likes
post #1 of (permalink) Old 08-06-2018 Thread Starter
TeeRev's Avatar
Quoted: 124 Post(s)
ABS Nightmare
So...
Way back when, I was having an ABS on left-turn problem. ABS code read C0035, left front. Going off of the forum's advice, I checked my wires and harness. Turns out they were fine, and the problem lay within the hub itself.
So, I changed out my left front wheel hub, and it was fine for about a week. Then the ABS light came back on (without the ABS on left turn problem) so I plugged in my reader again, and this time it said C0040, right front.
Checked the wires, and it was fine, so I changed out the front right wheel hub. Problem went away for a good six months. It was great.
NOW IT'S BACK!
ABS cuts in randomly, left and right turns. No set pattern, really. Now my ABS light is one, and it reads C0090, right rear #1 circuit malfunction.
Does anybody have any idea why my ABS modules are going out one at a time? Or, how to fix a C0090? I really don't want to keep changing out wheel hub after wheel hub lol.
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
LED headlights / fog lights
Stant locking gas cap
GM molded splash guards
McGard locks
TeeRev is offline
post #2 of (permalink) Old 08-06-2018
Quoted: 927 Post(s)
I guess it's possible that your rear hub just happened to fail... the hubs on these cars are known to fail often - so it's probably just coincidence...
post #3 of (permalink) Old 08-06-2018 Thread Starter
TeeRev's Avatar
Quoted: 124 Post(s)
That is indeed a possibility, and is probably what has happened... but man, what did I do in my previous life to have three of four wheel hubs go out within six or seven months, one at a time?! Talk about bad luck... Not to mention my oil pressure sending unit went out a couple of weeks ago... *rant*
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
McGard locks
TeeRev is offline
post #4 of (permalink) Old 08-06-2018
Quoted: 927 Post(s)
Look at the bright side - you're getting them all out of the way at once (hell, I'd be tempted to just replace *both* rear hubs at the same time). And they're all basically the same age this way. :-)
post #5 of (permalink) Old 08-06-2018
Quoted: 232 Post(s)
Are the actual hubs or bearings bad on those you replaced? Or, is there something else going on?
Have replaced the passenger side twice and the driver side once on our 2012. Have not to my knowledge had any codes pop up for them though. Dunno if the hubs are of a poor design or what the deal is, but yeah they fail. We did get 140,000 miles out of the original on our driver side and probably could have gone a few thousand miles more on it.
post #6 of (permalink) Old 08-07-2018 Thread Starter
TeeRev's Avatar
Quoted: 124 Post(s)
Well, I couldn't find any issues with the wiring at that time (I'll say why I have it bolded in a bit) and I went to an actual shop to get a second opinion and they agreed that it was the hub. After changing out the hubs, the problem went away, so I was happy.
@12 lt I waited until the ABS light / TC light came on for each case, so I could figure out exactly which hub was going bad, that's how I got the codes.
Now it's back... here's the thing. Yesterday it was throwing a C0900 code, for the right rear ABS circuit. Today it's throwing a C0035 again, front left ABS circuit and no C0900. It's jumping around. I'm so confused. Could a bad wire cause the problem to jump around?
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
McGard locks
TeeRev is offline
post #7 of (permalink) Old 08-07-2018
Quoted: 927 Post(s)
Hmm, that's really strange. Not sure if there is a common wire that could throw codes for different hubs like that. Maybe a failing ABS controller? But that is assuming that there is a separate computer for ABS? Or maybe it's just part of the ECM? Not really sure.
Hopefully someone that actually knows what they are talking about chimes in, becasue I'm just guessing at this point!! ;-)
post #8 of (permalink) Old 08-07-2018
Quoted: 232 Post(s)
Shorts or wiring issues can cause all kind of intermittent headaches. No clue if in your case the wiring is the problem or not. If you had a shop that gave a free estimate that could tell you definitively that yes the hub is bad, that would definitely be helpful. I would probably try to at least check the hub myself at the very least. I guess a question I am wondering about now is why we never had any abs/tc lights come on when ours have gone bad. I mean it was bad enough on passenger side I could feel it in the wheel in curves and I could hear it. Dunno if my wife had lights come on and did not tell me, she usually is pretty good about telling me when any cel comes on. Out of curiosity now I guess I am gonna have to scan our car and see if it has any stored abs codes.
The service advisor at the dealership on our first bad hub basically told me that these cars are susceptible to pothole hits and even suggested our having a gravel drive would contribute to a hub going bad.
As to the hubs going out, how many miles and what kind of roads? It may just be that you were lucky to not have to change any before this point. All in how you chose to look at it I guess. Had replaced 3, all on the front, on our 2012 by the time we were around 140,000 miles. Have not as of yet had to replace either of the backs(knock on wood), but sure the time is coming. My wife hit a pot hole hard enough to bend a back rim back around 85,000 miles, but to my knowledge as of yet that hub has not given any issues, close to if not a little over 150,000 miles on the car now.
post #9 of (permalink) Old 08-07-2018 Thread Starter
TeeRev's Avatar
Quoted: 124 Post(s)
@12 lt
It's an 08, 111k or so. Roads aren't bad, mostly city / highway driving, very few rural roads or gravel.
Here's my theory on why there are no codes or ABS/TC lights. It happened to me too, where there would be no codes stored in the system while my car was doing the ABS-on-turn thing. I could be wrong, but here's what I think. The car actually doesn't think the sensor is going crazy. The computer genuinely thinks that the car is losing traction based on the signal from the ABS system. It doesn't know that the ABS signal is actually in error, until the ABS sensor actually gives way. That's why it doesn't throw a ABS/TC light or ABS code. Or in your case, it's still receiving what it believes to be a good signal from the ABS module in your bad wheel hub, and thus didn't set an ABS code. That's my opinion, anyway.
The ABS/TC light went away on my way to work... so now I'm even more confused. I just want it fixed now I was gonna drive about 10 hours to VA for a wedding in a few weeks... Hopefully I'll get it sorted before then. I'm not overly keen on driving that distance without ABS or TC.
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
McGard locks
TeeRev is offline
post #10 of (permalink) Old 08-09-2018 Thread Starter
TeeRev's Avatar
Quoted: 124 Post(s)
Well, the ABS light went away for a day or so, and now it's back.
Plugged in my handy dandy ABS code reader, and it's pulling four codes now, which is a little concerning.
Current / MIL: C0035 (Left front ABS circuit)
History: U0101 (Lost communication with transmission module)
U0145 (Lost communication with body control module)
C0561 (System disabled information stored)
Please note; there were no OBDII check engine codes stored, these are all purely ABS. Could my EBCM be going out? I sincerely hope not...
Does anyone have any tips or ideas?
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
McGard locks
TeeRev is offline
post #11 of (permalink) Old 08-09-2018
Quoted: 232 Post(s)
Is the bcm a common component with all those codes? If so I would guess you either have an issue with wiring going to the bcm or the bcm itself causing it to throw these codes. As much as I hate dealing with shops, might be something to have to have a shop diagnose. I would be doing some calling around locally if it were mine, competent brake shops or try to talk with a mechanic at a dealership. Maybe pm Maven, best as I recall he is a certified gm technician.
post #12 of (permalink) Old 08-09-2018
Quoted: 163 Post(s)
^ And/or Bart77...
post #13 of (permalink) Old 08-09-2018 Thread Starter
TeeRev's Avatar
Quoted: 124 Post(s)
Yeah, I agree. My girlfriend's father was a GM tech with his own shop, and he's been trying to help me out. But he lives a couple hours away, and it's hard to go back and forth.
As a result, I made an appointment to have my Impala brought in to a shop on Monday... I agree that it comes to a point where more skilled hands than I have are going to be needed.
Damn if that's going to stop me from trying to solve it in the meanwhile! I'm just dreading the bill is all...
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
McGard locks
TeeRev is offline
post #14 of (permalink) Old 08-09-2018
Quoted: 232 Post(s)
Yeah, no kidding, too bad there is not a way to check these modules. Good luck, hope you are able to figure it out without taking it to a shop.
post #15 of (permalink) Old 08-12-2018
Silvermeteor's Avatar
My 2013 LT started warning Stabilitrak Error when I was turning hard left to park in our tight driveway. Found an ABS code C0035, right front. Only around 85K miles. Put it up with it until preparing for a 3000 mile trip, then worried it might do bad things at highway speeds. Got a mechanic to replace the hub and do the left as well and rule them out. Next day, same thing C0035. We took the trip. While en route, figured the cable had to be the problem, so ordered pigtail assembly replacements for both. Did the left first, saw no issues. Then the right, where on exposing the twisted pair I immediately saw the broken conductor inside the insulation at the place where the cable assembly was secured to the control arm. Wire tie must have been too tight so it flexed at that point with every turn. No more problems 4000 miles later. See light spot on blue wire in center of photo.
Last edited by Silvermeteor; 08-12-2018 at 07:50 PM. Reason: Photo not attaching with drag and drop, sorry...
Silvermeteor is offline
Trac Light, ABS, Service Trac system light came on then car started stuttering TheTired20Yearold Chevy Impala 7th Gen Discussion 2 08-04-2018 11:45 PM
ABS light on BruceY30 Chevy Impala 7th Gen Discussion 17 07-05-2018 08:35 AM
ABS & Traction Control Lights, and weird sound danfarmer30 Chevy Impala 8th Gen Discussion 2 11-21-2017 08:02 AM
abs issue mes882 Chevy Impala 7th Gen Discussion 2 10-22-2017 04:34 PM
