2008 LS Service Airbag Warning - Chevy Impala Forums
 2Likes
  • 1 Post By Guardian
post #1 of (permalink) Old 06-17-2018 Thread Starter
Guardian's Avatar
2008 Impala LT Service Airbag Warning
Purchased a 2008 Impala 3.5 LT Flex for my son. Fixed a few various issues but the last remaining one is a service airbag warning in the display. Iíve checked all the connections and have pulled the seat, carpet, and trim to check the fuse block connections and wiring.
From what I can tell is if I sit in the passenger it recognizes the seatbelt latching but the abs light in the center dash never shows the passenger seat as occupied / airbag on. Iím leaning towards the bladder type sensor in the seat being the fault and not signaling presence in the seat. It would appear this would involve tearing the seat apart and replacing the bladder / sensor.
My scan tool is not capable of reading the airbag system so I am considering an upgrade to a better scanner. I also donít have a wiring schematic yet. Iím concerned about taking it to a dealer due to cost but in the long run it might be better. Has anyone experienced this issue and been able to confirm this as a problem? An alternative thought would be to buy a full seat from the locate boneyard and replace it entirely.
Any thoughts or suggestions?
Guardian is offline
post #2 of (permalink) Old 06-19-2018 Thread Starter
Guardian's Avatar
Is there no one that can offer any suggestions on this?
Guardian is offline
post #3 of (permalink) Old 06-19-2018
mdubyk's Avatar
Quoted: 17 Post(s)
I found schematics for the Passenger Presence System and Seat Belts. IM me and I can send them to you.
mdubyk is offline
The Following 2 Users Say Thank You to mdubyk For This Useful Post:
Guardian (06-19-2018)
post #4 of (permalink) Old 06-19-2018 Thread Starter
Guardian's Avatar
Are the schematics different from the ones you attached? Those give me a place to start for sure. New scanner will be here today so hoping I can resolve this after that.
Thank you for your help so far.
Guardian is offline
post #5 of (permalink) Old 06-19-2018
Quoted: 251 Post(s)
i had an airbag light go off on my 2010 for over a year. then after a suggestion here i applied die-electric grease on the yellow connectors under the front seats. problem solved for me. i know you said you checked the connections but maybe take a second look? this was a common issue with several people.
Joes74challenger is offline
The Following User Says Thank You to Joes74challenger For This Useful Post:
post #6 of (permalink) Old 06-19-2018 Thread Starter
Guardian's Avatar
Iíll look at them again once I look at the codes. I did have them unplugged and put a small amount or dielectric grease on the terminals. Unfortunately it did not fix / remove the error. However, I have read where these codes can be set by lack of battery power and in this case the battery failed or was just old by it helped to kill the alternator. I have remedied those issues as well as a few others. Iím hoping once I can clear the code it will be gone. Thereís no way to remove the code without the scanner. Im thinking that even if a connection problem existed and was fixed at the connections that it wonít simply turn off the warning.
My main concern is to have the codes gone. We are an emission state and the car is plugged into the network. It will not pass.
Iím my mind, the code and the dash light in the middle of the dash, are two different things possibly. The pps, unless the sensor is shorted, shouldnít care less if anyone is in the seat other than it wonít turn the airbag on. Iím somewhat good mechanically and electrically but donít deal with these everyday. Iím trying to rule out the simple stuff (read cheaper) to see if I can resolve or identify the issue. I can replace the seat sensor or whatever if needed as long as I can identify the true cause. If I canít, the solution is to go down the dealer path and Iíve not been overly impressed with their skills around here never mind the expense.
Guardian is offline
post #7 of (permalink) Old 06-19-2018
mdubyk's Avatar
Quoted: 17 Post(s)
[IMG class=inlineimg]/images/ImpalaForums_toucan/smilies/tango_face_smile.png[/IMG]
The schematics are the same ones. My view of the attachment thumbnails didn't look right. I thought they didn't upload.
mdubyk is offline
post #8 of (permalink) Old 06-19-2018 Thread Starter
Guardian's Avatar
I wanted to update this as I go along. I scanned the vehicle today and there were 9 codes set in the airbag system. After clearing them I still had one code that would not clear. This code was the B0083 that indicates the front sensor has an issue. After looking at the sensors I noticed black tape had been added and decided to pull the indicated sensor off the vehicle. I assume both have the same issue or will given the condition of the first.
This is what I know so far. Given age of the vehicle we will attempt used replacements if nothing more than to correct the current issue. If they fail after then we can replace with new at a later time. Will follow up if this fixes the current issue or not.
Yeah I seem to be having some issues with the way images work here but thanks. Any help on this is appreciated and we seem to be making a small bit of progress so far.
Joes74challenger likes this.
Guardian is offline
post #9 of (permalink) Old 06-23-2018
mdubyk's Avatar
Quoted: 17 Post(s)
[QUOTE=Guardian;3634817]I wanted to update this as I go along. I scanned the vehicle today and there were 9 codes set in the airbag system. After clearing them I still had one code that would not clear. This code was the B0083 that indicates the front sensor has an issue. After looking at the sensors I noticed black tape had been added and decided to pull the indicated sensor off the vehicle. I assume both have the same issue or will given the condition of the first.
Any progress with this issue? Have you cleaned up the pin and socket, applied dielectric grease and tried reusing the sensor?
mdubyk is offline
post #10 of (permalink) Old 06-24-2018 Thread Starter
Guardian's Avatar
[quote=mdubyk;3635395]
Went to the local junkyard and got both sensors from a 2010 Impala. Cut off the leads from the 2010 about 18 inches back from the sensors and spliced / soldered them into the 2008. Cleaned everything up prior to install and added dielectric grease to the connectors and mounting bolts. Put everything back together and the code is gone but cleared out the set code with the scan tool afterwards to verify. All good on that end.
Now, oil pressure sender is leaking and several brake items to replace / fix. Sure do love the rust belt...
Guardian is offline
2008 Chevrolet Impala LS RSS Bot eBay Cars For Sale: Impala 0 03-28-2019 06:51 PM
2014 - 2017 chevy impala ls lt ltz driver-s wheel air-bag oem new style airbag RSS Bot Impala Diecast Toys Cars on eBay 0 10-08-2018 07:10 PM
2008 Chevrolet Impala LS RSS Bot eBay Cars For Sale: Impala 0 05-25-2018 03:21 PM
Details for the 2008 MY Impala (LS, LT, LTZ, SS) TeeRev Chevy Impala 8th Gen Discussion 1 08-14-2017 10:12 AM
06-15 Chevy Monte Carlo Impala driver airbag Oem 2006 2007 2008 2009 2010 2011 RSS Bot Impala Diecast Toys Cars on eBay 0 08-14-2017 09:00 AM
