AC Delco Spark Plugs - Install Instructions? - Chevy Impala Forums
 16Likes
post #1 of (permalink) Old 05-10-2018 Thread Starter
Chives3300's Avatar
Hi All,
I've searched and searched but haven't found concrete info.
2012 Impala LTZ - 3.6L.
Changing the plugs this weekend with OEM: AC Delco: 41-109.
I'll be able to torque the front plugs, but not the rear due to the intake.
1st question: Gap
- Manual says .043". I'm reading some people on the forums saying .040". Thoughts?
2nd question: Torque
Online I am reading Torque spec: 15 ft/lbs. Correct?
I can torque the front 3, but not the rear due to the intake.
Is everyone just doing the 1/8th turn?
Thanks!
Chives3300 is offline
post #2 of (permalink) Old 05-10-2018 Thread Starter
Chives3300's Avatar
Just realized this should probably be in the maintenance forum - @Admin can you please move over for me?
post #3 of (permalink) Old 05-10-2018
Quoted: 932 Post(s)
Read this entire thread - you can change the rear plugs without removing the intake or anything else. The one member even made a video showing how easy it is near the end of the thread:
https://www.impalaforums.com/chevy-im...done-it-3.html
sheila, 12 lt and Fred9505 like this.
post #4 of (permalink) Old 05-10-2018 Thread Starter
Chives3300's Avatar
@jtrosky - Thanks for the reply! I've actually been through that thread and all over youtube haha.
I was planning on leaving the intake on - more curious what people have been doing to torque down the rear spark plugs?
I figure I could do the front three, gauge the angle on those, and try my best to do the same on the rear? Or has someone successfully gotten a torque wrench back there??
Second question - The manual says .043" gap - but even in that thread you shared people are saying .040. which is it?
post #5 of (permalink) Old 05-10-2018
Quoted: 932 Post(s)
Not sure about the gap - I'll try and check my service manual and see what that says.
To torque the rear spark plugs, I'm assuming you can do it with a torque wrench using some extensions (maybe the kind that "pivot")? I haven't done it yet myself.. I'm sure someone that has done them will chime in shortly though.
post #6 of (permalink) Old 05-10-2018
Quoted: 191 Post(s)
^ Check the owners manual or underhood sticker for plug gap.
post #7 of (permalink) Old 05-10-2018
reubenswinks's Avatar
Quoted: 94 Post(s)
Maybe I'm dumb, but I always just do spark plugs by feel. I suppose you could do the front ones with a torque wrench, and then put the wrench you are gonna use for the back ones on the fronts and feel how much effort it takes to turn it a fraction more. Should get you in the ball park.
sheila, mwilson62000 and 12 lt like this.
reubenswinks is offline
post #8 of (permalink) Old 05-10-2018
Quoted: 191 Post(s)
^+1. At 68, I'm calibrated, lol! Except for tty head bolts!
plano-doug and mwilson62000 like this.
post #9 of (permalink) Old 05-10-2018
Quoted: 220 Post(s)
GM has issued TSBís stating NOT to change the gap on the ACDelco iridium spark plugs, as changing the gap can damage the iridium coating on the tip (it is not solid iridium) and thus damage the plugís longevity.
post #10 of (permalink) Old 05-10-2018
mwilson62000's Avatar
Quoted: 9 Post(s)
Just did mine a couple months back. Itís tight back there, but you do not need to remove intake. Tightened mine by feel also.
2012 LT - Silver Ice Metallic
mwilson62000 is offline
post #11 of (permalink) Old 05-11-2018
MarkTN's Avatar
Quoted: 18 Post(s)
I would suggest a little anti seize on the threads before installation.
MarkTN is offline
post #12 of (permalink) Old 05-11-2018
Quoted: 220 Post(s)
GM service manuals state not to use anti seize compound on the spark plug threads. The ACDelco spark plugs have a special coating on the treads.
post #13 of (permalink) Old 05-11-2018
WickedGoat's Avatar
Quoted: 141 Post(s)
How many miles on your car and how did the plugs look? There is a rebate on AC plugs till the end of this month so I am going to grab some for both the Impala and the Yukon.
2014 Chevy Impala LTZ Limited
- 5% Window Tint, Rosen GM1210 Stereo, Polk Audio Components and 6x9s, Pioneer, Kenwood amps and sub, Addco Rear Sway Bar, ZZP Strut Tower Braces, LED fogs and low beams, back up and interior lighting, SS dash, stereo and shifter trim.
2004 Pontiac GTO
- Quicksilver on Black 6 speed, garage queen
2004 GMC Yukon SLT
- The reliable back up... can't part ways with it!
2016 GMC Acadia Denali
- Quicksilver on Black, AWD, rear DVD, 2/2/3, nice...
WickedGoat is offline
post #14 of (permalink) Old 05-11-2018
Quoted: 191 Post(s)
^ Fwiw, I always dab the plug threads with a 'lil anti-seize and boots with dielectric grease.
Tesla and 2014LTDLTZ like this.
post #15 of (permalink) Old 05-11-2018
Quoted: 240 Post(s)
Yep, this was the thread that got me started here. Came in to thank that user.
I used autolite plugs for mine, gap was called for being .040 and went to tight to feel rather than attempting to use torque wrench. Dialectric for boot, but did not use any antiseize on the threads.
Set (6) ac delco 41-109 iridium spark plugs fits gmc chevy impala cadillac xts RSS Bot Impala Diecast Toys Cars on eBay 0 05-11-2019 06:00 AM
8 pcs AC DELCO 41-110 IRIDIUM SPARK PLUGS 12621258 for Chevrolet GMC Hummer new RSS Bot Impala Diecast Toys Cars on eBay 0 08-20-2018 10:31 PM
AC Delco Spark Plug 45TS in Original Box set 8 Spark Plugs 5613246 RSS Bot Impala Diecast Toys Cars on eBay 0 08-29-2017 10:00 AM
AC Delco Spark Plug 45TS in Original Box set 8 Spark Plugs 5613246 RSS Bot Impala Diecast Toys Cars on eBay 0 08-15-2017 03:00 PM
Set of 6 ac delco 41-940 platinum spark plugs 19244474 RSS Bot Impala Diecast Toys Cars on eBay 0 08-05-2017 09:30 AM
