AC Delco Spark Plugs - Install Instructions? - Page 2 - Chevy Impala Forums
 16Likes
post #16 of (permalink) Old 05-11-2018
mwilson62000's Avatar
Quoted: 9 Post(s)
Originally Posted by WickedGoat View Post
How many miles on your car and how did the plugs look? There is a rebate on AC plugs till the end of this month so I am going to grab some for both the Impala and the Yukon.
I was about at 90k. Plugs didn’t look that bad, not too “burnt”. Glad I went ahead and did them though. Also, I always use just a bit of anti-seize on plugs.
2012 LT - Silver Ice Metallic
mwilson62000 is offline
The Following User Says Thank You to mwilson62000 For This Useful Post:
WickedGoat (05-11-2018)
post #17 of (permalink) Old 05-11-2018
Tesla's Avatar
Quoted: 69 Post(s)
For those, like myself, who like a little more detail, here's an 8-minute in-depth video ...
Cheers!
T-
2016 Impala Limited LTZ
Tesla is offline
post #18 of (permalink) Old 05-11-2018
mdubyk's Avatar
Quoted: 17 Post(s)
@Tesla: Great video!
mdubyk is offline
post #19 of (permalink) Old 05-11-2018
Quoted: 163 Post(s)
^+1 on the great video! Only things I'd add: Dab of never-seize on the plug threads, dielectric grease applied inside the boots with a small screwdriver or cotton swab and instead of dropping the new gapped plugs down in the plug hole, I insert them into a scrap piece of 3/8" hose and gently position and start them by hand with the hose attached. When plug is started, hose will stop or slip. Pull hose off and tighten with ratchet, extension and plug socket.
WickedGoat likes this.
post #20 of (permalink) Old 05-11-2018
Fred9505's Avatar
Quoted: 46 Post(s)
a short piece of 3/8" hose and insert the plug cap into the hose and then hand thread those plugs into the aluminum heads. Engine must be cold.
Fred9505 is offline
post #21 of (permalink) Old 05-12-2018
Quoted: 163 Post(s)
^ That's what she said, lol!!!
post #22 of (permalink) Old 05-12-2018
Tesla's Avatar
Quoted: 69 Post(s)
I'm with you there, Sheila. A little dielectric grease, inside the boots not only improves performance, but also helps prevent the boots from sticking to the plugs next time they need changing. And I consider a bit of anti-seize an absolute must when threading steel into aluminum. Great for brass-to-steel fittings too, so I use it on my outside hose bibs to prevent the brass hose connectors from seizing to the bibs.
However, there's one thing about using anti-seize that everyone should be aware. Torque specs are almost invariably listed as "dry" numbers, and an adjustment is required for fasteners that are tightened "wet." I've seen 50% offered as the general rule of thumb for the torque reduction, but that seems excessive to me. I usually reduce the torque by 30%, and have never had an issue.
Originally Posted by Fred9505 View Post
... Engine must be cold.
Another great point, Fred!
Always let those aluminum heads cool down a little before pulling the old plugs. Aluminum has a higher coefficient of expansion than steel, so you risk buggering up the threads if you remove the plugs while the head is still really hot.
Cheers!
T-
Tesla is offline
post #23 of (permalink) Old 05-12-2018
SAAN's Avatar
Quoted: 15 Post(s)
My Impala idles like crap evry since I changed the rear 3 plugs a few months ago. I didnt remove the manifold, so Im wondering if there is now a small hose in one of the rubber hoses back by the plugs, but everything looks and feels fine.
I Bought a new plug and put it in the outer cylinder closes to the brake booster and no change, moved that plug to the middle and no change and swapped the #1 plug with the middle plug and no change. Only thing I didnt do was use dielectric grease when changing, but I have reseated the coil packs back there too, so im at a loss now of whats causing this, as my scan tool is not sowing any misfires, so im guessing O2 or a PITA vacuum leak somewhere.
SAAN is offline
post #24 of (permalink) Old 05-12-2018
Tesla's Avatar
Quoted: 69 Post(s)
You're sure you installed the right plugs? If so, you could have knocked a vacuum hose loose, which is allowing unmetered air into the system. You may be able to track it down fairly quickly by spraying some carb cleaner around back there and listening for the idle speed to increase.
Cheers!
T-
Tesla is offline
post #25 of (permalink) Old 05-29-2018 Thread Starter
Chives3300's Avatar
Tackled the plugs yesterday. Wish I would have taken pics of them to share! Not too rough of shape after 100k miles.
I was a little concerned with oil in one of the plug wells.. read a TSB about porous heads causing oil to leak in the spark plug well. Hoping this isn't the case here. It's not throwing any codes so I'll keep driving!
Also surprised that the factory plugs weren't gapped to spec. Measured them all at .038" where as the manual states .043". I cautiously gaped mine to .043".
I was able to sneak in a torque wrench on the rear plugs, using a 6" and a 3?" Extension. Got all 6 torqued without removing the intake manifold.
Running great after the change.
Thanks again crew!
Chives3300 is offline
post #26 of (permalink) Old 05-30-2018
Quoted: 163 Post(s)
^ Does this engine have the plug well rubber o-ring seals in the cam cover? If so, may need replaced. With Fords, they come included with a cam cover gasket set.
Set (6) ac delco 41-109 iridium spark plugs fits gmc chevy impala cadillac xts RSS Bot Impala Diecast Toys Cars on eBay 0 05-11-2019 05:00 AM
8 pcs AC DELCO 41-110 IRIDIUM SPARK PLUGS 12621258 for Chevrolet GMC Hummer new RSS Bot Impala Diecast Toys Cars on eBay 0 08-20-2018 09:31 PM
AC Delco Spark Plug 45TS in Original Box set 8 Spark Plugs 5613246 RSS Bot Impala Diecast Toys Cars on eBay 0 08-29-2017 09:00 AM
AC Delco Spark Plug 45TS in Original Box set 8 Spark Plugs 5613246 RSS Bot Impala Diecast Toys Cars on eBay 0 08-15-2017 02:00 PM
Set of 6 ac delco 41-940 platinum spark plugs 19244474 RSS Bot Impala Diecast Toys Cars on eBay 0 08-05-2017 08:30 AM
