Engine Noise - 2009 Chevy Impala LT - Chevy Impala Forums
post #1 of (permalink) Old 04-16-2018 Thread Starter
tkimball8's Avatar
This morning my Chevy Impala started making a higher pitched whiny-grinding sound, like a belt was doing something funky). The sound is only present when revving the engine, accelerating, depressing the gas pedal... Sound is still there while in park stationary while revving the engine.
tkimball8 is offline
post #2 of (permalink) Old 04-16-2018
reubenswinks's Avatar
Quoted: 93 Post(s)
Odds are very high that it is a bad bearing on one of the pulleys. First thing I would check is if it changes whether or not the a/c is on just because it is the easiest thing to check. If no change, easiest way to ensure it is bearing related is to remove the belt and briefly run the engine in the same conditions and see if the noise went away. If it goes away, you know it is something driven by the belt. At that point you are best off using a mechanic stethoscope to figure out which one is making the noise. If you dont have one, while the belt is off you can also spin each of the pulleys by hand, feeling to see if any has a grinding feel or noise to it. The should spin smoothly. Check idler pulleys and tensioner as well. If taking the belt off makes no difference, there is something going on inside the engine which may be harder to diagnose by yourself.
reubenswinks is offline
post #3 of (permalink) Old 04-16-2018
TeeRev's Avatar
Quoted: 124 Post(s)
+1 Definitely sounds like a bad pulley bearing.
If you don't have a mechanics stethoscope, a long screwdriver works just as well. Just be *super* careful. That's what I used to determine my tensioner was going bad.
08 Impala LTZ
Rosen DS-GM1010-P11
Rosen DP-1088
Ultragauge MX 1.3
Dynomax 3" tips
30% Llumar tint
SS grille
LED headlights / fog lights
Stant locking gas cap
GM molded splash guards
McGard locks
TeeRev is offline
post #4 of (permalink) Old 04-16-2018
Quoted: 171 Post(s)
Fwiw, Harbor Freight Tools sells mechanics stethoscopes for ~$5.
2013 impala lt odd noise jerrypepe 8th Gen Drivetrain 4 3 Weeks Ago 01:06 PM
2009 Impala LT 3.5L Starting problem Tyler457 Chevy Impala 8th Gen Discussion 2 01-05-2018 01:59 PM
2016 chevy impala LT limited Rashid63 Appearance 8 10-23-2017 08:46 AM
3 ROW ALUMINUM ENGINE RADIATOR for 59-63 Chevy Impala 1960-1965 Chevy Biscayne RSS Bot Impala Diecast Toys Cars on eBay 0 08-09-2017 06:50 AM
