Parking brake adjustment - Chevy Impala Forums
 6Likes
  • 1 Post By chrislind2
  • 1 Post By Sealclubber
  • 1 Post By Lettermark
  • 1 Post By sheila
  • 2 Post By mdubyk
post #1 of (permalink) Old 03-29-2018 Thread Starter
chrislind2's Avatar
Is there a way to adjust the parking brake without removing the rear disk brake assembly? It looks like the adjuster is like the old brake shoe type brakes and if there is a small window in the backing plate it might be adjustable just like the old drum brakes were. But that would be too easy I suppose.
kamikazeedriver likes this.
chrislind2 is offline
post #2 of (permalink) Old 04-03-2018
Sealclubber's Avatar
Quoted: 4 Post(s)
Almost. Remove the wheel, the T-30 torx screw on the rotor, then the rotor falls off. The adjuster is front and bottom. Use a screwdriver to adjust like drum shoes.
This video should help;
Sealclubber is offline
post #3 of (permalink) Old 04-03-2018
Lettermark's Avatar
Quoted: 4 Post(s)
The parking brake on my 2007 Impala LT went right to the floor. There was resistance from the spring but no ratcheting action. The wire cable was attached and moving with the brake pedal. Oddly, a few days later it returned to normal. Obviously something "fell back into place" but I'm not sure what happened.
Lettermark is offline
kamikazeedriver's Avatar
Quoted: 18 Post(s)
This has just started with me on my 2013 LTZ, 110k miles. The resistance just eased off a few days ago and I know the parking brake isn't engaging. My driveway is a very slight incline and even though I engage the PB, once I take my foot off the regular brake pedal, it does that small lean til the transmission stops it.
Have looked through this thread, and I hope mine goes back to normal because I really don't feel like taking all that mess off.
2013 LTZ
kamikazeedriver is offline
Quoted: 145 Post(s)
^ Your '13 e-brake doesn't have the "drum-in-hat" set-up like earlier years. It simply utilizes the existing caliper/pads with a cable. Probably has a turnbuckle adjustment under the driver side. Dunno if you can adjust it at or around the pedal?
The Following 2 Users Say Thank You to sheila For This Useful Post:
kamikazeedriver (2 Weeks Ago)
Quoted: 18 Post(s)
I really don't know where to begin on that.
Will look around the pedal I reckon.
Might search youtube see if I find something that helps.
2013 LTZ
post #7 of (permalink) Old 1 Week Ago
mdubyk's Avatar
Quoted: 15 Post(s)
Parking Brake Adjustment:
1) Raise and support the vehicle.
2) Check park brake levers on rear calipers. Levers should be against the stops on the caliper housing. If levers are not against stops, check for binding in rear brake cables and position levers against stops.
3) Tighten park brake cable at equalizer until either the left or right lever begins to move off stop.
4) Loosen adjustment at equalizer until the lever which has moved off the stop, as in step 5, is again resting fully against stops. Loosen tension at equalizer until the cables feel slightly loose to the touch. Cables should not sag under their own weight.
5) Operate park brake several times to check adjustment. A firm pedal feel should be obtained by depressing the pedal less than one full stroke.
6) Inspect left and right caliper levers. Both levers must be resting on stops after adjustment of parking brake.
7) Check the operation of the park brake.
To achieve optimal performance ensure cables are not over-tensioned at the equalizer.
sheila and kbz1960 like this.
mdubyk is offline
Parking Brake Adjustment Kc3ihq DIY How To's & Write Up's 0 02-23-2019 01:09 PM
Parking brake snapped PatrickS Chevy Impala 8th Gen Discussion 0 12-20-2018 04:29 PM
Electronic Parking brake won’t disengage steven3181 Chevy Impala 9th Gen Discussion 16 06-12-2018 04:49 PM
Parking brake pad explodes again jso2378 Chevy Impala 8th Gen Discussion 7 05-22-2018 12:25 PM
Accidentally Broke My Parking Brake! :( Jake0811 Chevy Impala 8th Gen Discussion 7 04-20-2018 04:09 PM
