Turn signal woes - Chevy Impala Forums
post #1 of (permalink) Old 01-26-2018 Thread Starter
daytonboi's Avatar
Turn signal woes
My father has a 2011 Chevrolet Impala LT Fleet model it does not have the OnStar or any of those options. Right now the problem is the right hand turn signals do not work front or rear I'm getting power at the fuse block and nothing further than that. One issue that I am seeing is that if I remove the right turn signal fuse the trunk will no longer open I didn't think the trunk and the turn signal were on the same fuse. Am I correct in that assumption or has something been fouled up. He did recently just have a new transmission put into the vehicle but I think the issue predates the transmission swap. I also had done a turn signal mod on here couple years ago where the rear turn signal feeds off the front turn signal so that the brake lights no longer flash for the turn signals I have a separate turn signal setup for the car. I have not checked the wiring in the back as far as the old turn signals to see whether or not it's flashing back there but I do know it is not flashing in the front. I did get it to work one time by removing the fuse and with the flashers on and all the lights came on and when I put the fuse back in it continue to work and then later it stopped. Any help is appreciated.
daytonboi is offline
post #2 of (permalink) Old 01-26-2018 Thread Starter
daytonboi's Avatar
Just checked the rear ts I do have power to the rear just not the fronts
post #3 of (permalink) Old 01-26-2018 Thread Starter
daytonboi's Avatar
Fixed the issue but the fix raised more questions... The interior lights were also out and replacing that fuse allowed the turn signal to work.
post #4 of (permalink) Old 03-30-2018
Size_Atx02's Avatar
Quoted: 14 Post(s)
I had a turn signal problem with the front pass side burning out every time the light was replaced, and eventually didn't work at all. The rear would burn out also at times prematurely. Everyone said it had to be a short, after research found out it was my turn signal switch on my steering wheel and have not had the issue since replacing that. Picked up the replacement from Rock Auto. Hope this helps.
2007 Chevrolet Impala LTZ 2010-present
2004 Chevrolet Cavalier Base 2017-present
1975 Chevrolet Custom Delux sold
Size_Atx02 is offline
Turn signal, trunk release button, electric door locks not working tsophy Chevy Impala 8th Gen Discussion 1 2 Weeks Ago 08:30 AM
Aftermarket Turn Signal Sounds? 2011ImpalaLT Audio, Video, and Electronics 12 05-20-2019 07:53 PM
2000 Impala LS turn signal problem dandyd Chevy Impala 7th Gen Discussion 1 10-15-2018 05:53 PM
Turn Signal Issues StevieJ Chevy Impala 7th Gen Discussion 3 10-27-2017 01:57 PM
1964 Impala SS409 Turn Signal Switch ezyrdrfatboy2010 Mechanical and Electrical Problems 0 08-22-2017 11:52 PM
