Not happy with Wix oil filters!!! - Chevy Impala Forums
 19Likes
post #1 of (permalink) Old 01-01-2018 Thread Starter
WickedGoat's Avatar
Quoted: 142 Post(s)
So... I go outside today in the below freezing weather to fire up my cars... Reason #1 because it has been so cold, near 0 temps and reason #2 , I need to back the GTO out of the garage so that I can get Christmas decorations and totes put back up on the shelves. Much easier to do this with the car out of the way.
So I start the Yukon... Cranks slow but the Optima red top pulls through... I heard a slight pop but didn't think anything of it, but the truck fired up. About a minute later, I come back out of the house with the Impala keys and I see an oil leak under the Yukon. I fire up the Impala and get under the Yukon and see oil leaking from the oil filter... Then I remember the pop... I hope to God that it is the filter that bursted and not the oil filter housing or the block somewhere... But wait, this crap gets better... I see a little puddle under the Impala and guess where it is almost perfectly lined up with? Yep, the oil filter! Open the hood and see it wet around the filter housing. Now I gotta ask... What is the chance that not 1, but 2, Wix oil filters bite the dust on the same day for the same reason?
I am waiting on my neighbor to give me a ride to Walmart so I can grab a 5 quart jug of oil and 2 new oil filters. I am praying that it is the filters. I have never had this happen in my life but I will never be using a Wix product again. After reading so much praise and recommendation for them I decided to try them on these last oil changes... Never again... It is bad enough that I had to go out in the garage to put Christmas away, but now I have to change oil filters and look for possible engine block damage in the process. I will take pictures and post them along with what I find when I get the filters out.
2014 Chevy Impala LTZ Limited
- 5% Window Tint, Rosen GM1210 Stereo, Polk Audio Components and 6x9s, Pioneer, Kenwood amps and sub, Addco Rear Sway Bar, ZZP Strut Tower Braces, LED fogs and low beams, back up and interior lighting, SS dash, stereo and shifter trim.
2004 Pontiac GTO
- Quicksilver on Black 6 speed, garage queen
2004 GMC Yukon SLT
- The reliable back up... can't part ways with it!
2016 GMC Acadia Denali
- Quicksilver on Black, AWD, rear DVD, 2/2/3, nice...
WickedGoat is offline
post #2 of (permalink) Old 01-01-2018
Quoted: 932 Post(s)
Wow - that is *crazy*! I've never had ANY oil filter "pop"/"explode" or even fail for that matter.
That makes absolutely no sense.... Definitely curious as to what you find out - especially because I also have Wix filters! :-)
Please do follow-up when you know what the deal is. I'm assuming that they are different model filters - so I don't even think you could just blame a bad 'batch'.
I've never heard of anything like that before...
I'm curious as the exact model numbers (XP, non-XP, etc).
Also - where did you purchase? After some brief searching, I saw some mention of possible "fakes" on Amazon... No idea if that is really true or not, just that some mentioned the possibility...
It's been down in the single digits here recently and I haven't had any issues. At least not yet (and I sure hope it stays that way!!).
post #3 of (permalink) Old 01-01-2018
Rambro99's Avatar
Yes please let us know I run napa gold filters that they tell me is a wix filter. I have been using them in many vehicles for over 30 years with no problem.
Rambro99 is offline
post #4 of (permalink) Old 01-01-2018 Thread Starter
WickedGoat's Avatar
Quoted: 142 Post(s)
57045XP in the Impala... 3.6 engine
51522XP in the Yukon... 5.3 engine
Got both filters off and swapped out with AC Delco replacements. Inspected oil filter housings and immediate areas of the engines and didn't see any cracks or other abnormalities. Inspected both filters and I can't see anything wrong. Ran both vehicles for 15 minutes after the filter swaps and not a drop of oil from either. Letting them cool down so I can get a decent reading on the dipsticks so I can top them off.
Holy freaking crap it is cold out and this sucks bad. Never had this happen with any brand filter I have ever used, whether it was my car or a shop customer. I know the cold does some weird stuff to cars, but geez, this takes the cake. Got both Wix filters on the shelf... Gonna take a closer look when it warms up. Gonna be low 20's for highs most of the week with lows down to the single digits and maybe negatives.
I read Wix's warranty disclaimer... I may "inform" them of my issues...
2004 Pontiac GTO
2004 GMC Yukon SLT
post #5 of (permalink) Old 01-01-2018
Quoted: 241 Post(s)
So was the leak from the actual filter or around the seal? Would seem unusual to have a leak from one, but two the same morning is pretty crazy.
post #6 of (permalink) Old 01-01-2018
Quoted: 220 Post(s)
post #7 of (permalink) Old 01-01-2018
Quoted: 932 Post(s)
If you search the net, you can find plenty of posts about failed AC-Delco filters too - especially the e-core filters (and not just due to the cold), so I honestly dont believe this has anything to do with the links posted above - especially since the one that failed has nothing to do with an Impala or the 3.6L engine...
I'd love to know what the actual cause of the issue is/was. I hope Wix asks you to send the filters to them for analysis...
post #8 of (permalink) Old 01-01-2018 Thread Starter
WickedGoat's Avatar
Quoted: 142 Post(s)
At this point I can't tell what caused the leak. I did not see any issues with the filter housings on either engine. My guess would be if there was something wrong with the engine, it would have leaked with the new filter. Unless there is a hairline crack in either Wix filter, my guess would be the filter seal. I ran both cars and topped the oil off... No more leaks. Tomorrow will be a test since I have to go to work and my daughter goes back to school, so both cars will be run.
2004 Pontiac GTO
2004 GMC Yukon SLT
post #9 of (permalink) Old 01-01-2018
retiredpauly's Avatar
Quoted: 238 Post(s)
My guess
And its only a guess
But I do have some experience with cold weather and seen this kind of thing before.
The rubber gaskets of both filters probably shrunk and hardened a bit from the cold. Kinda like radiator hoses do and weep a bit of antifreeze when it's FREAKING COLD! (suffering with -40s here now )
Sorry don't mean to yell. But it's cccollldd here too.
I think they blew out past the on ring seals. It's that 1/2 turn past contact that is usually fine until it gets really cold. Another 1/4 turn upon installation will likely stop this from happening again.
That's only a guess though. Never had an issue with Wix filters splitting. Had a defective one once years ago where the can was crimped onto the base, but that was years ago and never seen it since.
Let us know what you find.
retiredpauly is offline
post #10 of (permalink) Old 01-01-2018 Thread Starter
WickedGoat's Avatar
Quoted: 142 Post(s)
Originally Posted by retiredpauly View Post
My guess
This is kinda where I was heading with it... In which case, do I contact Wix and complain to them? They can't control the weather. I'm not one to over tighten an oil filter because I have been the poor SOB that has had to remove Superman installed oil filters. It has been cold here in Missouri... Not -40 though... My thoughts and prayers are with you Pauly! I know I was pissed for having to go out there and fix both cars. I guess better today rather than 7:00 tomorrow morning when I am ready to go to work.
My neighbor that took me to the store said he had a Wix filter do this to him on his Silverado last year in the cold. I don't know... Just never had this happen before. It is what it is I guess.
2004 Pontiac GTO
2004 GMC Yukon SLT
post #11 of (permalink) Old 01-01-2018
Quoted: 220 Post(s)
You and your neighbor had problems with Wix filters on your GM vehicles? That's a clue.
Use the correct ACDelco filters.
post #12 of (permalink) Old 01-01-2018
Quoted: 241 Post(s)
Really probably pretty lucky in all honesty. A lot of folks would have gotten in and driven off and not noticed the leak.
Would also lean towards the cold and possibly the seal/oring being cold and stiff allowing the leak. Dunno much about wix filters or if they man to the oem specs or make a broad filter that fits multiple applications. Only experience I have had with wix was with an old backhoe we got filters for from a napa store.
post #13 of (permalink) Old 01-01-2018
Quoted: 382 Post(s)
This forum has, no doubt, gradually effected a paradigm shift on me.
I used to use Wix filters religiously. I've been told they have the highest quality filters. But I've come to realize that the original equipment maker is always going to have an advantage over the aftermarket/3rd party guy - he's privy to the engineering details - he's the guy whose filter was spec'd in when the motor was designed.
The 3rd party guy may or may not have access to all those details. So his filter that crosses to the OE filter may or may not work as well as the OE filter in that application. I'm sure lots of info is exchanged between the vendors - business works that way - so surely lots of those crosses work just as well as the OE.
But reading the threads here on the topic of oil filters has made it very apparent that using the one spec'd by the car maker is the safest choice. So I've been buying more AC-Delco filters lately (and Motorcraft for my Fords)
plano-doug is online now
TSS (01-02-2018)
post #14 of (permalink) Old 01-01-2018
Quoted: 932 Post(s)
As I research this, I find that this is actually a pretty common issue with all oil filter brands. People install the filter when it's 95F outside and then they notice it leaking during the first really cold day. I guess its due to a combination of the major temperature change and the how tight the filter was. I suppose that some oil filter gaskets are more prone to temperature change issues than others as well.
Personally, I've always tightened my oil filters pretty tight (by hand), so maybe that's why I've never had an issue, but definitely something to think about and watch for - regardless of the oil filter used. I know I'll be checking mine the next time I go out! :-)
post #15 of (permalink) Old 01-01-2018
Ferrari's Avatar
Quoted: 8 Post(s)
Back in the day WIX was a very trusted filter.
I agree with using the recommended AC-Delco filters on your Chevrolet.
Should be a perfect fit, perfect match.
But, sometimes the manufacturers specified filters are superceded with a better substitution.
Original, Stock parts work well on an original stock car (off the showroom floor).
If a part only says it fits, you are generally buying a compromise of price, quality or performance.
If a typical store bought filter is designed for many applications, then it may not be specific to your application.
There are a lot of different filters on the shelf and each manufacturer designs theirs a bit different than the "Other" brands. For instance: Micro, Paper, pleated, ByPass, Thickness of metal, bottom plate, cartridge, plastic...
Also,
Are you using the correct viscosity oil? any additives?
Block heaters might also be a good investment.
were the filters fairly new? Sludge in the engine?.. So many factors.. Thank you for bringing up the issues with WIX. of course, it has more to do with the individual needs of an engine and if those needs are being met. In this instance, we see a failure..
Ferrari is offline
Remote start disabled P0521 Mr312712 Chevy Impala 8th Gen Discussion 17 03-13-2019 09:01 AM
Low Oil Pressure Warning coloradofjr Chevy Impala 8th Gen Discussion 1 07-28-2018 06:34 PM
is there any reason an oil extractor wont work? luckydriver Chevy Impala 9th Gen Discussion 29 07-05-2018 01:57 PM
Oil Filters 2017 Driftwood Autocare and Maintenance 2 02-24-2018 05:31 AM
K&N Oil Filters? Opinions? Joshwike336 Autocare and Maintenance 11 11-05-2017 10:48 AM
