P0014 2012 3.6l - Chevy Impala Forums
 3Likes
  • 1 Post By coloradofjr
post #1 of (permalink) Old 01-12-2017 Thread Starter
coloradofjr's Avatar
P0014 2012 3.6l
I have a 2012 LT fleet with 156,000 miles - mostly highway. I use Mag 1 Dexos oil since I bought the Impala with 22,000 miles and change when the oil life is less than 20% (about 7000 miles - mostly highway). On a recent rip I threw a P0014 code twice. I cleared the code and it has not come back. P0014 is bank 1 exhaust camshaft over advanced. I have searched and decided I want to pull out the exhaust Camshaft Actuator Solenoid Valve and look to see if the screens are plugged. I read the http://alldatadiy.com/ procedure for removing the bank 1 exhaust camshaft actuator solenoid
  • remove the wire connector
  • remove the bolt
  • remove the camshaft actuator solenoid
Looking under the hood, it does not look there is enough room to pull out the solenoid (it is almost 6" long). there does not seem to be enough space between the head and the shock tower.
How do you remove the exhaust camshaft actuator solenoid?
coloradofjr is offline
post #2 of (permalink) Old 01-13-2017
Josh124's Avatar
Quoted: 30 Post(s)
Good question. Can you upload some images showing where it is and what it looks like? Then I'll check on mine to see if I can find a way.
Also note that timing chains on these vehicles can go bad, so that could be causing this code as well.
Josh124 is offline
post #3 of (permalink) Old 01-13-2017 Thread Starter
about 15 sec into this video,
, they remove the bank 1 exhaust camshaft actuator solenoid.
The illustration on this link shows the position https://www.repairprocedures.com/ser...8_2660006.html
I will see if I can get some decent pictures in the morning
post #4 of (permalink) Old 01-13-2017 Thread Starter
post #5 of (permalink) Old 01-14-2017
Josh124's Avatar
Quoted: 30 Post(s)
So I just took a look at mine. If bank one is the one facing the rear of the car, and that part is about 6 inches long. There's no way you can replace that without either removing the engine or finding a way to tilt it pretty severely... If it's the front bank, it'll be cake.
On a side note, I noticed some oil-looking substance about covering part of my engine about 8 inches lower than the cam position solenoids, was wondering if you saw something similar on your's? I'll probably take pictures and create a new thread for that issue sometime later this weekend.
Josh124 is offline
post #6 of (permalink) Old 01-14-2017 Thread Starter
Yes, it is the bank closest to the firewall. The shock tower does reduce the clearance. I measured distance from the face of head to the shock tower to be about 4"
I attached a couple of pictures - one showing the rough space and second showing the solenoid.
Tomorrow, if the weather is OK, I will try to pull it as far to the shock tower as possible and then move toward the front of the car, it *might* just come out. The Amazon detail shows the solenoid as 5.9" in length.
Thanks for you input.
Name:	tape measure front of head to shock tower.jpg
ID:	130561   Click image for larger version
Name:	bank 1 exhaust camshaft actuator solenoid.jpg
post #7 of (permalink) Old 01-14-2017
Josh124's Avatar
Quoted: 30 Post(s)
Well goodluck! Please let us know if it works because chances are someone else will need this information in the future.
Josh124 is offline
post #8 of (permalink) Old 03-05-2017 Thread Starter
It has been many weeks but the P0014 code came back yesterday. I now have 162,000 miles on my Impala.
I changed the right(rear) exhaust camshaft actuator solenoid valve this afternoon. The hardest part was getting the wire connector off the solenoid. I practiced on the front intake solenoid as it very accessible. Once I was able to remove its connector, then I moved to the rear exhaust solenoid.
I found that as I pulled rear exhaust camshaft actuator solenoid out, I had to rotate the wire connector and tip the solenoid until I had enough clearance to remove it. The replacement went in doing the reverse.
The access leave much to be desired but it is very doable. You don't have to remove anything else to gain access. I found a mirror helped line up the replacement so I could install the bolt.
I hope this fixes my P0014 code.
post #9 of (permalink) Old 03-05-2017
Quoted: 932 Post(s)
I'm curious - how is your 2012 running at that many miles (besides this particular issue)? People are always talking about how a catch can is needed on these engines, I'm really curious to get reports from folks with high mileage that don't have catch cans installed (I still say that they are not necessary). Just curious since you have a lot of miles...
Thanks.
Sent from my CW-Hi12 using Tapatalk
jtrosky is online now
post #10 of (permalink) Old 10-05-2019
bigwoodt's Avatar
Hi folks! I have the same issue(p0014) but a different yr(2013) and question. I found no o ring and seemingly no grease where the vvt solenoid seals on the engine. I believe no oring is cool(none with new part)but **do I need to oil the intakes and put lithium grease where it seals?**
It doesn't look snug enough on its own to prevent a future oil leak but I'm also worried the grease could degrade and seep into the oil and cause a problem.
Other than this its been an extremely easy replacement.
bigwoodt is offline
2012 accelerator issue 12 lt Chevy Impala 8th Gen Discussion 41 05-27-2019 06:52 AM
2012 Caprice 9C1 3.6L V6 RWD Police RSS Bot eBay Cars For Sale: Caprice 0 04-30-2019 11:34 PM
2012 Chevrolet Caprice 9C1 3.6L V6 RWD Police RSS Bot eBay Cars For Sale: Caprice 0 03-19-2019 11:40 PM
2012 Low Beam Headlights keep burning out BigTimbo Chevy Impala 8th Gen Discussion 13 12-23-2017 07:12 AM
2012 3.6L Impala RPM surging stopped at light with AC on flymorenow Chevy Impala Discussion 17 09-26-2017 11:42 AM
