air con problem - Chevy Impala Forums
  • 1 Post By kingnutin
post #1 of (permalink) Old 06-12-2013 Thread Starter
countryrunner's Avatar
air con problem
hey guys i am having some problems with the air conditioning with my 03 impala LS. the passenger side will blow cold but the driver side won't. and it does have the dual climate control system. so i am thinking maybe one of the flaps is not working right to let the air through to the driver side? what do you guys think
countryrunner is offline
post #2 of (permalink) Old 06-13-2013
g25racer's Avatar
Could be a vacuum leak. The flapper doors/a/c vents work on vacuum and not actuators like newer cars. Could be a low vacuum. Vacuum line runs around the passenger side (front) shock tower. Inspect the whole line. That or start tearing apart the dash.
Wouldn't be a bad idea to inspect or replace the cabin air filter as well. It's located under the passenger side windshield wiper. Very easy to access and replace.
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
Thunderbolt Spun Cat
ZZP Alternator Power Cable
Wagner Thermoquiet Pads
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Dipped Rims and emblems
JBL GTO 6.5" and 6x9"
Sony MEX-GS600BT
Rockford P3 @ 500rms
g25racer is offline
post #3 of (permalink) Old 06-19-2013 Thread Starter
thanks for the info i will check that out. but today i was playing around with the air con and i noticed that the driver side got colder when i switch the air intake from outside air to circulate air. i think the air got colder because of the increased air flow. and one last question it seems to me that when i got the system on full blast even before i had this problem it seemed that it was not pushing out enough air out of the system. but the blower motor seems like it is working just fine.
post #4 of (permalink) Old 06-19-2013
g25racer's Avatar
Like said before: Inspect/Replace the cabin air filter. Common cause of not enough airflow
2001 Impala LS
TransGO Shift kit
Spectre Cone Filter
KYB Strut Plus (Rr)
L67 Pass Eng Mount
Tinted tail lights
Painted Trim
Sony MEX-GS600BT
g25racer is offline
post #5 of (permalink) Old 06-21-2013 Thread Starter
well just got done checking the cabin air filter and it looks good to me no stuff on it at all so i am guessing its a vacuum line now or maybe the duel climate control is not working right
post #6 of (permalink) Old 06-21-2013
fastcat's Avatar
It could be one of 2 things. Either the freon level is low or the actuator motor is stuck. The blend doors aren't ran off a vacuum, they are opened and closed electronically by the actuator. Grab a hammer and and open your drivers door, look under the dash, on the right of the gas pedal, on the center console you will see a black sensor that is very hard to get to , with I think 3 small bolts in it. Tap that a few times with the hammer and slide your drivers side climate co.troll switch up and down. That should get it back working. Oh yea, have the car started.
When I got my car the heat on the drivers side blew cold but hot on the passenger side. I did the procedure above and my heat worked correctly, and now that its hot my Ac works.
Also the reason the air gets colder when you hit the button is becuase it closes the vent door so no outside air is coming inside your car from outside. So you aren't using the cabin filter anymore when u hit that button. Its just recycling the air that's already in your car. So if the Ac is on the air will be colder, if the heat is on the heat will be hotter.
fastcat is offline
post #7 of (permalink) Old 06-21-2013
Quoted: 6 Post(s)
The 7th gens use vacuum, 8th gens went electric. That's why you have never heard of a 7th gen having the clicking dash issue.
post #8 of (permalink) Old 07-19-2019
Normalin's Avatar
Most likely if you have a leak from the air conditioner then you have a crack in the radiator and under pressure freon flows out.You are lucky if you just need to change the air filter or clean all the air ducts. You can do it yourself or contact an ordinary air conditioning servicing company such as this which is engaged in the repair and support of all types of air conditioners and has many years of expirince and profesional experts in this field .
Normalin is offline
Cold Air Induction won't fix the problem txlegacypaco Chevy Impala 8th Gen Discussion 10 10-18-2018 10:14 AM
2004 Impala LS 3.8L suddenly sucking in air Brenden1138 Chevy Impala 7th Gen Discussion 2 11-15-2017 02:17 PM
A/C Stops blowing air after a while coacice Chevy Impala 7th Gen Discussion 3 11-11-2017 09:33 AM
air conditioner stops working impala_al Chevy Impala 8th Gen Discussion 15 07-25-2017 07:13 AM
