What is this? - Chevy Impala Forums
 3Likes
  • 2 Post By My 2003 Impala
  • 1 Post By J_Mohler
Old 2 Weeks Ago Thread Starter
My 2003 Impala's Avatar
Quoted: 15 Post(s)
What is this?
Was checking the coolant level in my '03, and this whitish/creme colored deposit was on the underside of the radiator cap. a small amount was on the inside of the filler neck, but coolant looked clean. Radiator cap is barely a few weeks old. Do I have something to worry about here?
My 2003 Impala is offline
Old 2 Weeks Ago
Quoted: 220 Post(s)
Someone could have added something to the cooling system (stop leak)?
Short trips in cold weather without a fully warmed engine can cause deposits like this to form as shown.
Quoted: 15 Post(s)
I see no evidence of any stop leak, radiator and coolant tank levels have stayed at normal levels since I have had the car. When I take it out , it's always driven till the car is up to operating temp. I guess I'll just wipe it off and just keep an eye on it
Old 2 Weeks Ago
wz7u's Avatar
Quoted: 5 Post(s)
To me, it looks like it could be oil in the condensate on the radiator cap. If so, you can flush a bit of it out of the COOL radiator by filling the neck with hose water and float it out. My guess there is a gooey, aw ****, residue needing wiped out.
Does the underside of the engine oil fill cap or even the dipstick have any of that milky goo? Peek in the coolant overflow tank while shining a light into it and what does it look like? Oil in your coolant isn't to be ignored.
The only other thing I can think of is Dex-Cool going over to the dark side or maybe some green coolant got topped off into the orange. Good radiator caps are essential with Dex-Cool too. Either way, don't let this thing get ahead of you. Es no bueno.
'03 3.4 with lots of miles, 230k+
wz7u is offline
Old 2 Weeks Ago
J_Mohler's Avatar
Only one real way to find out what's going on...drain, flush, and refill that bad boy and see if the gunk comes back. I've seen similar build up in other cars caused simply by being old fluid that was way overdue for a change. Also I've seen it from people that didn't know they are supposed to use distilled water if they used the concentrate antifreeze. Using tap water all that white chalky mineral deposit stuff that builds up around the faucet now turns into a glob in the car
J_Mohler is offline
Old 2 Weeks Ago
mdubyk's Avatar
Quoted: 28 Post(s)
How many miles do you have and how long have you owned the car?
It could be all that you need is a thorough system flush.
mdubyk is offline
