Windshield wiper issue - Chevy Impala Forums
 2Likes
post #1 of (permalink) Old 10-04-2019 Thread Starter
My 2003 Impala's Avatar
Quoted: 11 Post(s)
Having a problem with the wipers on my 2003. When I had them on today during a heavy rain today, the drivers side blade would gradually get to the point that half of it would hang off the end of the windshield as the wipers moved. What could be the problem? Hasn't done this till today
My 2003 Impala is offline
post #2 of (permalink) Old 10-05-2019
Quoted: 218 Post(s)
The windshield wiper transmission assembly mounted under the cowl could be going bad (it is replaced as an assembly), or the wiper blade could be loose on the wiper transmission stud.
With the wipers turned off, grab the wiper arm and see if it will move, or is rigid on its mount.
If it is loose, you may be able to remove the plastic cap and tighten the nut holding the arm onto the stud.
If tightening the nut does not fix the loose arm, it will have to be replaced. The wiper arm is a press-fit onto the stud, with the wiper arm having a softer metal which cuts its own threads when the new arm is installed (by positioning it correctly, then tightening the nut).
post #3 of (permalink) Old 10-05-2019 Thread Starter
Quoted: 11 Post(s)
I will check it out, thanks
