heater control issue - Page 2 - Chevy Impala Forums
 8Likes
post #16 of (permalink) Old 10-16-2019
mdubyk's Avatar
Quoted: 29 Post(s)
There's a vacuum reservoir tank attached to the back of the HVAC control module. Check it and the lines to the control head for vacuum.
mdubyk is offline
post #17 of (permalink) Old 10-30-2019
mdubyk's Avatar
Quoted: 29 Post(s)
Originally Posted by My 2003 Impala View Post
Originally Posted by mdubyk View Post
2 things to look at:
Is vacuum present at the back of the HVAC control head?
Does the mode knob actually rotate the vacuum switch on the back of the HVAC control head?
I will check it over and see
What did you find?
mdubyk is offline
post #18 of (permalink) Old 4 Weeks Ago Thread Starter
My 2003 Impala's Avatar
Quoted: 15 Post(s)
Haven't had much time to look at it deeper, trying to figure out how to remove the trim panel without breaking it
My 2003 Impala is offline
post #19 of (permalink) Old 2 Weeks Ago Thread Starter
Quoted: 15 Post(s)
Update: Was looking deeper under hood yesterday and found a vacuum line broken. I slipped a piece of hose over it, and now the mode selector works. Just have to fix the blower speed switch as it only works on positions 4 and 5
post #20 of (permalink) Old 2 Weeks Ago
Quoted: 382 Post(s)
Kudos on fixing the vacuum leak.
The speed control issue is usually what's called the blower motor resistor. In some cases, they actually contain resistors; in other cases, it contains a more sophisticated electronic circuit for controlling the fan motor speed. Either way, as long as you get a "blower motor resistor", you should be fine.
Looking on Autozone's website, most of them are around 40 bucks, but there are two outliers: one at 12 bucks and another at 94.
The resistor is located near the fan, up above the passenger's feet, against the firewall.
plano-doug is online now
post #21 of (permalink) Old 2 Weeks Ago Thread Starter
Quoted: 15 Post(s)
Thanks I'll check those out. Fan speeds 1,2,3 are dead, fan only comes on in 4 and 5
post #22 of (permalink) Old 2 Weeks Ago
Quoted: 382 Post(s)
I think it's almost always the resistor. I can't recall anyone with a bad speed switch.
Seems like fan speed control is a problem that goes way back. I've done at least one resistor on one of my Impalas. And my dad's 64 Chrysler had similar issues with its A/C fan, too
post #23 of (permalink) Old 2 Weeks Ago
Quoted: 194 Post(s)
^+1. Again, on my old Fords, underhood vacuum breaks/leaks were common. Think age and engine heat/cold. Also, with a faulty/burnt blower motor resistor, blower fan only worked on high speed(s). Mode (vent) selection was controlled by vacuum, temperature was controlled electrically via the temp blend door actuator motor.
sheila is online now
post #24 of (permalink) Old 2 Weeks Ago
gcrawdad's Avatar
My leak was in the thin black vacuum line from the manifold. It was in the area below the fuse/relay boxes.
Just the facts maam
gcrawdad is offline
