Weird Electrical No start issue 2001 impala - Chevy Impala Forums
post #1 of (permalink) Old 07-15-2019 Thread Starter
michaelb's Avatar
Have a 2001 Impala with a weird issue. Drove fine this morning.
When the key is turned to any position, all kinds of things happen -except for the engine starting... I really don't know how to describe it, so I
Basically, dash lights flickering in and out, gauges keep resetting to minimums, weird buzzing noises coming from the cluster, the center display with mileage and gear select seems faded around the edges.
Any ideas on what this might be? Ignition switch?
michaelb is offline
post #2 of (permalink) Old 07-15-2019
Quoted: 376 Post(s)
When the key is turned to any position, all kinds of things happen -except for the engine starting... I really don't know how to describe it, so I made a video.<snip video>
Sounds like a weak battery to me. When they get low enough, rather than slowly cranking, you get nothing. I did hear some clicking which sometimes also occurs with a weak battery.
You can take the battery to a parts store or Walmart and they will test it for you. While you are at it, inspect the wires on the battery looking for corrosion. It's usually white, powdery crud, or sometimes light blue (from the copper). The corrosion can impede the flow of electricity which has much the same effect as a weak battery.
If someone can help you, you might try jump starting it. If that works, it's pretty much an indicator that a new battery is needed.
post #3 of (permalink) Old 07-15-2019 Thread Starter
michaelb's Avatar
Battery voltage is 12.6, battery is about a year old. Might put a charger on it overnight.
EDIT: I should add the in the first 10 seconds of the video, the key was turned to the acc position, not on or start, and that weird noise is not the radio.
michaelb is offline
post #4 of (permalink) Old 07-15-2019
Quoted: 376 Post(s)
That's the no-load voltage. When you turn the key and current begins to flow, the voltage can very quickly drop below the level necessary to start the car.
If the battery has a bad cell, or there's a bad connection (corroded wire). the added resistance will cause a big voltage drop when the key is turned to crank.
One test you can try is to probe the battery with a voltmeter while someone turns the key. If it drops below ~10 V, that can indicate a bad cell. But most digital meters are too slow for such a test. The old analog meters are better suited for that.
Anyway, if you take the battery to a store and get it tested, they can determine if it has a bad cell.
post #5 of (permalink) Old 07-15-2019 Thread Starter
michaelb's Avatar
Just tried using the fob to lock/unlock it
When I hit lock, horn relay clicks but no horn. Bit of noise from door locks but no locking occurs.
When I hit unlock, just some noise from door locks.
Not sure if this means anything, but it seems unable to lock/sound horn, even though it can turn on AC fans/radio.
michaelb is offline
post #6 of (permalink) Old 07-15-2019
Quoted: 189 Post(s)
^+1 on the getting the battery, alternator and starter load-tested for free at a parts store.
post #7 of (permalink) Old 09-12-2019
LC22222's Avatar
Still having this issue?
LC22222 is offline
post #8 of (permalink) Old 09-13-2019
wz7u's Avatar
Quoted: 5 Post(s)
Bad battery/crap connections. Start there first.
'03 3.4 with lots of miles, 230k+
wz7u is offline
post #9 of (permalink) Old 09-13-2019
!Tommy's Avatar
Quoted: 8 Post(s)
One of the easiest ways to test your battery is to honk the horn. If it barely blows or you hear nothing at all, then more than likely your battery is bad. Since the horn always works whether the car is on or off and does take a good amount of electricity to run it, it will prove if the battery can handle the load or not.
!Tommy is offline
