Throttle Body Heater Delete - Chevy Impala Forums
 2Likes
  • 1 Post By Iceman44
  • 1 Post By 04Imp38
post #1 of (permalink) Old 03-18-2019 Thread Starter
Iceman44's Avatar
Can anyone verify success with this modification? Looking for cleanest solution.
Iceman44 is offline
post #2 of (permalink) Old 03-18-2019
04Imp38's Avatar
Quoted: 237 Post(s)
Yes I have done it on both my 7th Gens.
Use 1/4” NPT female brass plugs.
The lower can almost be tapped the way it is, but it helps to drill the holes out a little.
https://rover.ebay.com/rover/0/0/0?m...2F323405784772
~Joe~
04 Impala LS
Engine: ZZP PCM, ZZP Downpipe, Xcelerator Resonator, Dual Xcelerator Mufflers, 4" Stainless tips, 180° t-stat, Shorter Dogbones, Mount Spacers, Optima Red Top Battery
Interior:
04Imp38 is online now
post #3 of (permalink) Old 03-26-2019 Thread Starter
Iceman44's Avatar
Appreciate your info, did mine a bit different, but end result the same. Noticed some improvement on hot starts and idle. Along with the fenderwell CAI, voltage stabilizer, throttle body heater bypass, numerous sensor replacements, plugs and Taylor 8mm wires, the engine is much happier than when I got it. Catback dual will be next, then PCM upgrade. I cannot stand the tranny dropping into overdrive at 45-50mph in drive.
Thanks.
04Imp38 likes this.
Iceman44 is offline
post #4 of (permalink) Old 03-26-2019
04Imp38's Avatar
Quoted: 237 Post(s)
Thanks.
Sure thing!
I agree about the OD. 55 at the lowest for me when I get a tune. Fortunately I can drive to ZZP and have them dyno it and all that fun stuff.
~Joe~
04 Impala LS
Interior:
post #5 of (permalink) Old 03-26-2019 Thread Starter
Iceman44's Avatar
The shift kit worth the time? I just changed the fluid and filter and am kicking myself in the ass for not putting in a drain plug.
03 Imp Base 3.4l. Smoked headlights/tailights, LEDS, 1 1/2" front wheel spacers, 2" rear wheel spacers, blacked out grille, fender well CAI, throttle body heater delete, rear manifold breather, voltage stabilizer, performance front brakes and more to come.
Iceman44 is offline
post #6 of (permalink) Old 03-26-2019
04Imp38's Avatar
Quoted: 237 Post(s)
Yes absolutely yes. And the Dorman pan with the plug is a must too. While you’re there, do the lube tube retainer as well.
~Joe~
04 Impala LS
Interior:
post #7 of (permalink) Old 03-26-2019
04Imp38's Avatar
Quoted: 237 Post(s)
What setup are you thinking for catback?
~Joe~
04 Impala LS
Interior:
Electronic Throttle Body Assembly for Colorado Impala Trailblazer Envoy Canyon RSS Bot Impala Diecast Toys Cars on eBay 0 04-24-2019 07:20 AM
VMAX ported throttle body. etb4u 9th Gen Engine Performance 3 09-04-2018 09:36 AM
Brown water in throttle body dtsimpala Chevy Impala 8th Gen Discussion 7 08-13-2018 09:41 AM
P2122 Code, Accelerator or Throttle Body? alexhortdog95 8th Gen Engine Performance 19 05-24-2018 06:03 PM
2014-2017 Chevy Chevrolet Impala 2.5L Throttle Body Throttle Valve Assembly OEM RSS Bot Impala Diecast Toys Cars on eBay 0 08-28-2017 11:22 PM
