Throttle seems to be stuck open - Chevy Impala Forums
 6Likes
  • 3 Post By Bill58
  • 1 Post By 12 lt
  • 1 Post By jardows
post #1 of (permalink) Old 03-05-2019 Thread Starter
jardows's Avatar
Been having an issue lately with my 3.8 LS running high RPM's at idle. Without me touching the gas, the car takes off on its own when I let off the brake. I'm thinking that the throttle is stuck open a bit, but it's going to be this weekend before I get a chance to look at it. Any advise on what to look for, or what else it could be before I get my hands dirty?
jardows is offline
post #2 of (permalink) Old 03-05-2019
Bill58's Avatar
Quoted: 44 Post(s)
I would clean inside the throttle body with cleaner and a tooth brush, clean all carbon from the butterfly area. If it still idles high clean the IAC valve.
Bill58 is offline
post #3 of (permalink) Old 03-05-2019
Quoted: 188 Post(s)
In addition to the excellent advice in post #2 , replace the PCV valve, 2 o-rings, and black plastic fitting (ACDelco sells an inexpensive kit, don’t just replace the PCV valve). Use caution and patience when removing the black plastic fitting, and transferring the MAP sensor from the old fitting to the new fitting.
post #4 of (permalink) Old 03-05-2019
Quoted: 223 Post(s)
Before replacing anything I would check the throttle cable at the throttle body and be sure it is not sticking or hanging. Have seen that happen in late 90's model chevy trucks. Have also seen the throttle cable kinked slightly which causes higher idle.
kbz1960 likes this.
jardows's Avatar
So just an update, the issue seemed to go away on it's own. I went ahead and changed the PCV valve and associated parts with the AC Delco kit. After a few months without an issue, it happened again the other day, but hasn't happened since. Once I get some time and it quits raining, I'll look into it some more. Thanks for the tips!
jardows is offline
Quoted: 188 Post(s)
If you haven’t cleaned the inside of the throttle body bore, and the butterfly valve edge, that may be your problem.
Oily, sticky “gunk” builds-up on the bore and the edge of the butterfly valve, and can cause the valve to stick and not return to the idle position (when the gas pedal is released). It can cause a low or rough idle also, and stalling at speed when the gas pedal is released.
A quick look inside the bore should give you an answer. It should be silver and shiny.
07 LS completely dead with key stuck in ignition- Please Help! kumiko26 Chevy Impala 9th Gen Discussion 1 4 Days Ago 08:58 PM
Fuel guage stuck on full Tmachor Restoration Forum 3 05-17-2019 08:01 PM
L26 pellinium to 2000+ Northstar throttle Hunter68 Automotive Discussion 0 08-03-2018 04:47 PM
2007 Impala 3.5 no start, key stuck, stuck in park, [email protected] Automotive Discussion 4 04-04-2018 05:07 PM
Driving Without A Thermostat (Or With A Fail-Safe That's Stuck Open) hg3300 Chevy Impala 7th Gen Discussion 15 12-25-2017 07:13 AM
