Want to install 9C1 oil cooler - Chevy Impala Forums
post #1 of (permalink) Old 07-22-2018 Thread Starter
Brewster's Avatar
Has anyone done this upgrade? From what I've found so far it should fit- and the lines should clear the radiator tank. There seems to be a 'cut out' on the flexible shroud for where the lines pass through to the front.
Thanks for any guidance!
Brewster is offline
post #2 of (permalink) Old 07-30-2018 Thread Starter
Brewster's Avatar
It installed without problem- it cleared radiator tank easily. Just make sure to soak radiator fittings with PB Blaster night before. Ended up cutting lower fitting off - it broke loose - but would not turn in the sleeve that is on it.
Brewster is offline
If I install a transmission cooler what happens in winter when it gets -20 degf. Jackson 8th Gen Drivetrain 11 04-19-2019 03:58 PM
Remote start disabled P0521 Mr312712 Chevy Impala 8th Gen Discussion 17 03-13-2019 08:01 AM
Low Oil Pressure Warning coloradofjr Chevy Impala 8th Gen Discussion 1 07-28-2018 05:34 PM
is there any reason an oil extractor wont work? luckydriver Chevy Impala 9th Gen Discussion 29 07-05-2018 12:57 PM
HELP oil cooler line Majestic9C1 Chevy Impala 8th Gen Discussion 3 10-23-2017 07:06 PM
