Idle high, rough shifting 96 imp - Chevy Impala Forums
post #1 of (permalink) Old 07-23-2016 Thread Starter
Chevyimp's Avatar
Hello everyone,
New guy here, but have always came here for information about my impala.
Thanks for all the inputs and knowledge .
For the pass six months or so I have been experiencing hesitation , "bucking," struggling ONLY when going up hills.Its fine on a straight road. After researching on here some similar situations I came up with a couple of possible culprits- fuel pump, a hose from the fuel tank, and throttle body.I was getting worked done to my car ( not related to the hesitation) I went ahead and had the fuel pump replaced and the hose leading out of the fuel tank checked out fine so I left it alone. replacement of the fuel pump did not correct the hesitation, but did correct my fuel gauge issue. So not a complete fail on replacing the fuel pump. I figured its probably the TB and told my mechanic to leave it alone and that I will clean it or replace it myself. My mechanic advise me that cleaning the TB could have negative outcomes and to not clean it. Since I have always wanted to get the Throttle body bypass done I figured this was my chance to kill two birds with one stone right? ( heres a link to the TB bypass I used.) Throttle Body Bypass Procedure
The throttle body bypass went well one of the hoses was difficult to remove FYI. Now this is were I screwed shat up, I did the best I could cleaning the TB with TB cleaner. I felt I did a good job, but after driving around the hesitation and struggling was even worse and I could hear the TB sticking when accelerating up hills or on a straight road. FYI This is why you listen to your mechanic kids.
After coming on here and researching more about TB fixes I decided to not screw around get a new one along with Throttle position sensor and IAC valve, I figured since this is all bolt on stuff no mechanic would be needed so I went ahead and installed all myself.
After installing a brand new TB, TPS AND IAC VALVE my idle was high as soon I turned the key and went even higher when I hit the gas pedal and stayed high. I had to manually move the acceleration part on the TB to bring it some what back down. After reading reviews about TB I saw some reports of sticking from new TB, I assumed this is the case with my new TB? I went ahead and put my old TB but with the new sensors when I turned on the car this time the idle was high but not as high as it is with the new one. I went for a drive and its just messed up.Transmission takes forever to shift out of 1st and its rough when it does, u can still hear some sticking. Basically at a lost right now any information is greatly appreciated.
Chevyimp is offline
2006 Implal LT 3.9L V6 rough idle rjpeek Mechanical and Electrical Problems 7 08-01-2019 01:44 PM
Having some rough idle issues as well as throwing some o2 sensor codes any advice? cutlass1972 Chevy Impala 9th Gen Discussion 11 04-09-2019 03:15 PM
Occasional rough idle and stall on startup. NO MILs active. tonydaman04 Chevy Impala 7th Gen Discussion 8 03-01-2019 12:05 PM
08 3.9L Rough Idle, Loss of Power uphill No Check Engine swatson7122 8th Gen Drivetrain 8 11-09-2017 07:04 PM
Random High Idle 05Impala3.4 Mechanical and Electrical Problems 4 10-11-2017 09:08 AM
