Hey guys,
My '95 has been acting up lately. Had our first snowstorm here last night, and when I left work, the car seems like it's only running on 6-7 cylinders. Surges really bad at low speed when its warmed up. Has no power at WOT, and rough idle. It is NOT throwing any codes.
Got the car home, checked to see if there was snow around the WP or Opti, it was bone dry. Checked the air box to see if snow had worked its way in there... there was a little moisture. Took it apart, dried it out, cleaned the MAF, cleaned the K&N filter. Every part of my intake sat in the house overnight, just to make sure it was dry.
Started it this morning, was perfectly fine on the cold high idle... as soon as it started to show temperature, it started up again.
I honestly have no idea where to even start. IAC? Injectors? FP Regulator? Fuel pump? PCV? I replaced the Opti, wires, plugs, WP gaskets about 500 miles ago. 86,000 miles.
Thanks for the help!
