one long 91 caprice nightmare. - Page 7 - Chevy Impala Forums
post #91 of (permalink) Old 10-29-2011 Thread Starter
1991chevybetty's Avatar
Originally Posted by 77Impala View Post
Base timing or PCM controlled timing? Base time won't change once you set it unless the timing chain is loose. But you would see that when you are setting the base timing. PCM controlled timing will always be changing due to many factors such as ambient temperature, engine temperatures, humidity, and other factors that the PCM reads through the various sensors.
I'm not sure. The timing mark seems to be in the same place when i check it with the timing light, but when i set it at a good spot it seems to drive worse with every start up. Like one day i'll drive with no hesitation at take off, then the next time i start it theres hesitation and it gets worse with every start. and on top of that the car shifts gears at different points or the rpms go higher before it shifts.
1991chevybetty is offline
post #92 of (permalink) Old 10-29-2011
77Impala's Avatar
Quoted: 16 Post(s)
You may be loosing the transmission. If there is a vacuum modulator on the trans you may want to check and/or replace it. And try a fluid/filter change on it as well.
I believe on yours that the transmission controls the shifts between 1 and 3rd, and that Over Drive and Torque Converter Lockup are the only things controlled by the PCM.
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #93 of (permalink) Old 10-29-2011 Thread Starter
where is the vacuum modulator? Someone else was talking about a vacuum line on the transmission but didnt know where to look.
post #94 of (permalink) Old 10-29-2011 Thread Starter
Does it even have a vacuum modulator since it's a newer car?
post #95 of (permalink) Old 10-29-2011
77Impala's Avatar
Quoted: 16 Post(s)
If it does it should be on the right side closer to the tail shaft of the transmission.
77Impala is offline
post #96 of (permalink) Old 10-31-2011
Quoted: 6 Post(s)
A 91 should have only a TV cable, the computer controls only torque converter lock-up. A vacuum leak or a rich condition may cause the problems you're having.
post #97 of (permalink) Old 04-25-2015
impalas/s's Avatar
if your getting suction in you gas tank wicth is noticeable after driving then taking your gas cap off it could be cooking fuel pumps and the wiring inside the tank.solution replace gas cap and charcoal canister relay located at the top center passenger side of your intake manifold.this happened to my 96 impala s/s and my 95 caprice classic.
impalas/s is offline
post #98 of (permalink) Old 04-25-2015
impalas/s's Avatar
post #99 of (permalink) Old 04-26-2015
That Guy!!
worthirt's Avatar
Quoted: 36 Post(s)
Old thread, really old thread...
1996 Caprice Classic
worthirt is offline
Dave_N's Avatar
Quoted: 64 Post(s)
I wonder if he still has the Caprice after the 4 years that this thread was inactive?
2006 Impala LTZ/SS 3.9 L V6
Magnaflow Catback Exhaust
5" Android Smart Mirror
Overkill Engine Tune!
Dave_N is offline
Caprice impala ss roadmaster 91 92 93 94 95 96 window regulator guides clips RSS Bot Impala Diecast Toys Cars on eBay 0 09-04-2018 10:30 PM
91 96 caprice classic hood ornament emblem lt1 5.7 350 tri y 9c1 RSS Bot Impala Diecast Toys Cars on eBay 0 08-19-2018 03:23 PM
Depo 91 92 93 94-96 chevy impala & caprice smoke rear tail light covers frames RSS Bot Impala Diecast Toys Cars on eBay 0 12-11-2017 09:10 PM
91 92 93 94 95 1996 Impala SS Caprice Front Door Panel Courtesy Light Lens L/R RSS Bot Impala Diecast Toys Cars on eBay 0 08-27-2017 06:40 PM
91 92 93 94 95 96 Chevy Impala SS Caprice Power Window Master Seat Switches L/R RSS Bot Impala Diecast Toys Cars on eBay 0 08-23-2017 03:00 AM
