one long 91 caprice nightmare. - Page 2 - Chevy Impala Forums
post #16 of (permalink) Old 09-01-2011
1969 Impala's Avatar
Hillbillly shop? roflmao Good luck, you're going to need it!
1969 Impala is offline
post #17 of (permalink) Old 09-01-2011 Thread Starter
1991chevybetty's Avatar
I'll take it to the boys from deliverance. Good times.
1991chevybetty is offline
post #18 of (permalink) Old 09-01-2011
Quoted: 6 Post(s)
Then it would never get fixed, Burt Reynolds would show up and shoot one of them with an arrow, then slap you in the face for not having watched every one of his movies.
post #19 of (permalink) Old 09-01-2011 Thread Starter
Ouch. haha. What a bastard
post #20 of (permalink) Old 09-03-2011 Thread Starter
I took my alternator out to test at the parts store and it failed. I have a 5.7 ex-police car. On the stores website the only alternator that said police was 120 amp and non-police were all 100 or 105 amp, but the employee said it doesn't matter.
Whats the differance? Does it matter? How many Amps do i need?
post #21 of (permalink) Old 09-03-2011
Why did you take out the alternator? That isn't necessary.
If the alternator type didn't matter, they wouldn't list two different alternators.
Why did the alternator supposedly fail? What's supposedly wrong with it?
At the rate that you're going, before long you'll have replaced every single part on the car!
post #22 of (permalink) Old 09-04-2011 Thread Starter
It's necessary for me, i don't drive it cause it's not inspected and gotten too many tickets for that, plus it waste alot of fuel to get it going.
I kinda thought something was wrong with it because my car will start up like a normal car and doesn't die after it has been charged. But after that first start it gets difficult again. Also alternator light is on and gauge fluctuates whenever i use blinkers or headlights. i was thinking the regulator.
I dont know why it failed but it didn't pass
post #23 of (permalink) Old 09-04-2011
77Impala's Avatar
Quoted: 16 Post(s)
Since you don't have the police light bar, siren, radios, and flashing strobes you don't really need the higher amp alternator. You can use the standard one.
Since you live in a emission testing county your car can fail just because the Check Engine lamp is on. Which in this case is possible from the alternator not working. Hope that is all your problem is.
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #24 of (permalink) Old 09-04-2011 Thread Starter
Alright thank you.
The 120 amp police alternator and the 100 amp one are the same price both with a lifetime warranty. Which one should i get? Any perfomance difference? Will too many amps fry anything?
post #25 of (permalink) Old 09-04-2011
77Impala's Avatar
Quoted: 16 Post(s)
No the higher amp won't fry anything. If installing a high amp stereo and or multiple dvd displays then go with the higher amp alternator.
77Impala is offline
post #26 of (permalink) Old 09-05-2011
blizzy21's Avatar
hey can someone tell me why when i start up my car it idles at 1000rpm, and after a short while it turns off!! but it happens every once in awhile .. I changed my alternator. still does it....
blizzy21 is offline
post #27 of (permalink) Old 09-05-2011 Thread Starter
I had the same damn problem exept mine idles at 2000 rpm, it's not fixed all the way now but i can get mine to run eventually now by pumping the gas a little while. Did you have any trouble codes? At first i thought mine was a vacuum leak, but it wasnt it. After i changed my fuel pump and retainer i could get it to idle after the engine was warmed up by pumping the gas pedal to keep the engine alive. Also check the fuel filter.
post #28 of (permalink) Old 09-05-2011
Gregg-O's Avatar
What in the world made you think the alt had anything to do with it running like that?
The other thing's could be any number of thing's, how many miles on the car? Has it been taken care of? New fuel filter? ICM's can start to crap out when they get hot. High ldle could be dirty TB, sticky throttle blades, sticky/bad IAC valve, sticky throttle cable, shitty MAF........
Gregg-O is offline
post #29 of (permalink) Old 09-05-2011 Thread Starter
Hey hey hey... let's get back to my car problems.
post #30 of (permalink) Old 09-06-2011
Originally Posted by 1991chevybetty View Post
Alright thank you.
A lifetime warranty many times means cheap, made in China, "quality". Beware!
An alternator will only charge at the rate that is needed. If the battery were almost totally drained, then whatever the maximum charge rate of the alternator, (like 120 or 100 amp), will kick in. If the battery is nearly fully charged, it may only charge at 25 amps.
Caprice impala ss roadmaster 91 92 93 94 95 96 window regulator guides clips RSS Bot Impala Diecast Toys Cars on eBay 0 09-04-2018 10:30 PM
91 96 caprice classic hood ornament emblem lt1 5.7 350 tri y 9c1 RSS Bot Impala Diecast Toys Cars on eBay 0 08-19-2018 03:23 PM
Depo 91 92 93 94-96 chevy impala & caprice smoke rear tail light covers frames RSS Bot Impala Diecast Toys Cars on eBay 0 12-11-2017 09:10 PM
91 92 93 94 95 1996 Impala SS Caprice Front Door Panel Courtesy Light Lens L/R RSS Bot Impala Diecast Toys Cars on eBay 0 08-27-2017 06:40 PM
91 92 93 94 95 96 Chevy Impala SS Caprice Power Window Master Seat Switches L/R RSS Bot Impala Diecast Toys Cars on eBay 0 08-23-2017 03:00 AM
