Electric Fan Problem - Chevy Impala Forums
post #1 of (permalink) Old 07-13-2011 Thread Starter
1995CapriceClassic's Avatar
I have a 1995 Caprice with the 4.3 L99 V8. I seem to have a problem with the electric fans. Whenever they do come on, the Check Engine Light comes on as well. But, recently I had the car start to overheat, and the E-Fans didn't come on. What could be wrong? Any suggestions to fix the problem.
1995CapriceClassic is offline
post #2 of (permalink) Old 07-14-2011
MrBuick (Magnum)'s Avatar
Sounds like the sending unit in the water pump is bad. Replace it. The gauge on the dash uses the one on the passengers side head. The PCM/fans are controlled by the one in the water pump. If it goes into limp mode, and fails to get a reading from that sensor, it will kick the fans on, and the CEL.
MrBuick (Magnum) is offline
post #3 of (permalink) Old 07-15-2011 Thread Starter
Thank you so much! Replacing that sensor did the trick! Much easier than having a mechanic charge 100 dollars/hour to diagnose and fix the problem.
2015 LTZ AC Problem jrnipps Introductions & Welcome Forum 3 05-19-2018 06:38 PM
Shifting problem sinjin Autocare and Maintenance 3 03-05-2018 12:47 PM
HVAC Cruise problem tjharring Chevy Impala 7th Gen Discussion 2 09-23-2017 05:53 PM
Car 12V 16.5A Electric Turbine Turbo Charger Air Intake Fan Bold Line Solid RSS Bot Impala Diecast Toys Cars on eBay 0 08-23-2017 08:20 AM
