Ford 9 Inch Conversion in My 1973 - Chevy Impala Forums
 5Likes
  • 1 Post By DesertXL
  • 2 Post By DesertXL
post #1 of (permalink) Old 03-27-2019 Thread Starter
DesertXL's Avatar
PART I
Hello,
Thought I'd share this painstaking axle conversion in my 1973 Caprice Classic. Let me preface this by saying the only reason I did this is because the GM factory installed some oddball 12 bolt axle that parts are extremely hard to impossible to find. I wanted to install some kind of positraction and a change of gear ratios, both which turned up to be harder than I thought.
GM installed a type "A" axle. This was not a Chevrolet axle. The build sheet even called it out. I finally found out 20 years ago what axle it was. I went to a Chevrolet dealership and went to the parts department and brought the build sheet. It stumped the young lads working there, then they called an older chap to the counter. He looked at the build sheet, raises his head and said that's an Oldsmobile axle. He disappears for several minutes and brings a big Oldsmobile book full of dust to the counter and cracks it open. He points to the exploded view and asks is this it.
I said emphatically it certainly was. They then did a nation wide dealer search on gear sets and differentials. None, nada, nine, nyet. There is also no aftermarket support for this 9-3/8" massive ring gear Oldsmobile passenger car axle.
An axle change was inevitable. This is a long process and I'll break this up into parts as there are loads of pictures.
This is the Olds axle.
The rear brakes are 11" x 2" drums.
The axle solution I had chosen was a Moser Engineering Ford 9 inch custom made to fit the 71-76 B body. It came replete with 31 spline axles.
Here's the axle housing. Now for brakes I wanted OEM brakes and had asked if they could make the bearing flange work for my old drum brakes. Moser said no, they do not make that flange for those big brakes. So I asked if they could make '94-'96 Impala SS (WX3)/Caprice police interceptor (9C1) disc brakes fit. They said yes.
Cool beans.
However, there was a possibility of needing a shim, they supplied the shim, but it was up to me to figure it out if I needed it or not. Well since the shim goes between the axle flange and the bearing, installing a set of bearings is a 50% chance of being right. Not wanting to waste a set of bearings. I modeled up the Ford big axle bearing in 3D CAD and 3D printed one out with reduced outside dia. and increase inside dia for a slip fit. Otherwise the plastic faux bearing was withing a few thousandths of the real one.
Here's the shim. So I did a test fit with the shim and the faux bearing. Turns out I needed the shim.
Since GM discontinued the backing plates for the 94-96 full size rear disc brakes I had to locate a used set. This turned out to be loads harder than I thought. Turns out most of these have been crushed or pillaged for other 5 on 5 rear disc brake conversions. But I got lucky and found a set. Next was cleaning and powder coating them.
Then rebuilding them.
Next problem was the supplied studs. The '73 B body uses 1/2"-20 studs and the '94-'96 are metric. The English/SAE studs wouldn't fit through the rotors on the shoulders.
I downloaded the Dorman catalog but couldn't find anything that really would work well.
I ended up turning down each shoulder on all 10 studs.
Press the studs back in and the bearings on.
To be continued.
Next up will be installing a differential and gears then setting them up in the brand new 3rd member housing.
Cheers
p.s. If you are having trouble viewing the embedded pictures you may want to try a different browser.
DesertXL is offline
post #2 of (permalink) Old 03-28-2019
Quoted: 245 Post(s)
As an FYI to anyone trying to view the photos i found while at work behind a firewall chrome, firefox, and edge failed to view the photos (firefox got close by at least showing a picture should be there but it never loaded it). the tapatalk app was able to view it, but i had to follow the path listed at the top of this page.
Just before i posted this comment I went back and tried Internet Explorer and that loaded the pictures properly...which saddens me deeply that i had to use IE...lol
this was an interesting read, thanks for sharing!
Joes74challenger is offline
post #3 of (permalink) Old 03-28-2019
kbz1960's Avatar
Quoted: 16 Post(s)
Nice job and know how!
kbz1960 is offline
post #4 of (permalink) Old 03-28-2019 Thread Starter
DesertXL's Avatar
Hello Joes74challenger,
I think I may know what's going on with the pictures and not showing in the more mainstream browsers. The problem is most likely this forum is accessed under HTTPS (has the security link layer) certificate and my pictures are from my domain which is only HTTP. This forum when you view it forces your browser to switch to HTTPS then instead of downloading the pictures on its server simply points to my domain that does not have the SSL layer and the browser will not display them.
Two avenues for possible correction are for me to see if it's possible to get an SSL layer certificate from my domain host and or see if this website will upload the pictures and resend them under HTTPS.
It will be a few days before I can see if it's possible to get the SSL. If I can, then the pictures should display for the common browsers. Or if the website changes the way it handles pictures.
We shall see.
Cheers
Joes74challenger and kbz1960 like this.
DesertXL is offline
post #5 of (permalink) Old 03-28-2019 Thread Starter
DesertXL's Avatar
Thank you, most kind indeed.
Cheers
DesertXL is offline
post #6 of (permalink) Old 03-28-2019 Thread Starter
DesertXL's Avatar
Part II
Picking up where I left off. Setting up the third member.
I ended up buying a brand new Eaton True Trac differential and Richmond 3.25:1 gears.
First thing is install the new bearings.
I will say this, not all Ford 9" axles are created equal, neither are the third members. There's a host of different size bearings depending on application. You have to do the research to see what yours takes.
Just for comparison, the used looking bearings were out of a old Ford 9" and those are smaller than the ones I need.
Pressing the new bearings onto the new carrier.
Before placing the ring gear onto the carrier, you want to make sure there are no burrs.
Same with the ring gear.
Chase the threads and clean with parts cleaner.
Clean the threads on the bolts and use Loctite.
New pinion pilot bearing. Again there different sizes depending on the third member housing you bought. Always verify.
Inset the bearing and install the retainer.
In case you're wondering the third member is a brand new nodular iron piece. It's not worth your time and money to try and find one from Ford. Chances are it has seen hard use and they can have cracks in the nose pinion bearing area. I think this case was around 200 dollars brand new. And never trust a used limited slip, more than likely you'll have to rebuild it anyway, by the time you're done dickering with something used and abused, chances are it would be the same price or cheaper just buying something new.
Now after reading about the True Trac, I opted to spend the additional money on it. No clutches to wear out, no additives in the oil needed. Acts like an open differential under normal driving but stomp on the go pedal and it locks both wheels to together, smoothly and without noise. When I called Eaton to ask what their differential could handle as far as a torque differential they said I'd break a set of gears before their diff broke.
I was both impressed and I kind of took that as a challenge
Set the carrier roughly in place.
Prepping the pinion carrier for new races. This is the only piece on the axle (aside from backing plates) that was used. I have a couple Ford galaxie parts cars and nicked this off one of them to save a few bucks. I read no evidence that these suffered from cracking from long term use.
Installing new bearings onto the pinion gear.
Installing the bearing into the pinion carrier. I also use a slight amount of RTV around the perimeter of the seal case to help fight against leaks.
Not less forgetting the new crush sleeve
Ready for tightening down.
This is the shim pack you need to set the gears. Order this from Rock Auto. I think it was around 12 bucks. Some places were charging upwards of 50 dollars for this.
Now the fun easy part. Follow directions on the gears.
Let me interject here and say, if you haven't done this, buy a book for your rear axle type. This book was invaluable.
You do not need fancy tools to properly set up gears, just some patience and the ability to utilize common sense.
There's loads of little tidbits in order to set up a gear set properly. Let me touch on a few. New gears come with dimensions written on them. The idea is you set up the gears to match those dimensions and that will get you really close to the ideal gear tooth pattern. It's to shorten the time spent and make your life easier. Again read the directions.
Something in the book that wasn't on the directions I'll note here. There are hunting, non hunting and semi-hunting gear ratios. This means the same teeth will always mate together all the time, some of the time or it's random. The 3.25 gear set if I remember properly was a semi-hunting set. Usually for non hunting and semi hunting there are timing marks on the gear sets as to how they were machined. It's important to align the timing marks, if present, to keep gear noise reduced.
An example of getting the pinion depth to match what's written on the gear.
Timing mark. The gear set directions didn't even mention this. The book did. Glad I found it.
Once you set the pinion depth to what's hand written on the gears, next you set the backlash.
In this case following the hand written depth and setting back lash led to a near perfect tooth contact pattern.
That was easy. As a side note don't waste your time and money trying to find gear mating paste. Gray anti-seize works just as well.
I did experiment with other shims and it turns out first try (matching the numbers) was the best.
Set the bearing preload on the carrier bearings and lock the rings.
New axle housing gasket, copper washers and lock nuts.
New '94-'96 Chevy full size rear disc brakes hoses and misc.
Everything loosely installed for now. Starting to come together.
In part III I'll cover rough installation, prepping the engine and transmission and how I redesigned the rear controls arms to correct the idiotic propshaft to pinion angle GM bestowed on these cars.
Cheers
DesertXL is offline
post #7 of (permalink) Old 03-28-2019 Thread Starter
DesertXL's Avatar
Part III
Picking up where I left off. There is a design fault of the rear axle pinion angle. It's far greater than 3-4 degrees. It's so prominent that GM had to fit a CV joint at the axle. The further foible of this is they didn't put one on the transmission side which also shares an extreme angle.
Now Moser made their axle to the same specifications as the GM. That means copying the idiot pinion angle.
This is a good comparison of axles. That Oldsmobile 'A' axle is very large. This allegedly was used in GM C body cars such as the Olds 98 and Electra 225.
The big bearing Ford 9" is no feather weight but that damn Olds rear axle must weigh 100 pounds more. I can lift one end of the Ford 9" replete with brakes, I couldn't get one end of the Olds off the ground.
The propshaft Cardan joint angles are optimal when both ends are equal and between 0- 4 degrees.
In order to set the axle pinion angle the engine and transmission mounts need to be in excellent condition. Whilst the transmission mount was acceptable, the engine mounts were obliterated.
The thrust side (drivers side) mount was collapsed.
Changing the mounts was quite the undertaking. I had to enlist the help of a good friend and we wrestled that 900 pound engine for 45 minutes till it finally sat in the mounts.
With the engine mounts replaced I could now focus on the repositioning of the rear axle. But how to make this easy....
I was at the Tractor Supply store (similar to Farm and Fleet) and saw these tractor 3 point hitch arms and had a light bulb moment. I could use these as tools to adjust the rear axle into place and then take measurements.
The lowers were good to go but I had to make a little adapter for the uppers to work.
Installed these and started experimenting with the pinion angles.
Now we're getting somewhere. This is where the pinion should normally reside (pointing slightly up instead of down).
I took loads of measurements and made a spreadsheet. Moser gave me 4 lower control arm attachment holes and so I took measurements in each to see how stable the pinion angle was at different axle ride heights.
Armed with this data and the new fixed angle of the centre line of the engine/transmission I determined I needed to lower the transmission mount about 5/8" of an inch to reach an optimal Cardan joint angle.
There's only one recourse to lower the transmission and that's to lower the mount pad on the cross member. There is quite a bit of wiggle room in this area to alter the engine and trans centre line with respect to chassis. Got to love big cars.
This is a spare cross member. As a side note this car is over built so much. I do love that. People balk in disbelief when I tell them the car has a curb weight of 5000 pounds. Rounded to two significant digits.
The wall thickness of the cross member is nearly 1/4" compressed at the ends it's nearly 1/2" thick steel. This could support a Detroit diesel never mind a Turbo 400 behind a Mark IV 454.
One of the flaws of the GM cross member is that there are no drain holes in the low sections and water just sits and rusts. In fact there is really no way for the rust to even come out. The logical choice is to bore some 1 inch holes in the low spots. Even 1 " holes will not weaken the brace for this application it's so overbuilt.
Just look at all that.
This was about 4 pounds of iron oxide. If a newer car rusted this much it would be a death sentence as chances are structural integrity was lost somewhere critical. Even with this removed, the trans cross brace weighs nearly 50 pounds.
I want to make an note here. Now I don't plan on keeping this Turbo 400. I would like to replace it with an overdrive transmission. A 4l80E to be specific. I will make a new lighter weight and just as strong transmission brace out of 4130 Chromoly when the time comes. But it never hurts to clean and paint this brace up in the meantime.
Further more I did refresh the Turbo 400. It started leaking badly several months ago and when it was cold out, reverse wouldn't engage till it warmed up. All that was fixed. I'll start another post on the refresh of the Turbo 400 if anyone is interested.
Once the transmission was set back in place and my pinion angle finalized next up was to make the set of actual adjustable upper control arms. But first in order to add stability, the lower temporary tractor arms were removed and measured and a temporary set of more stable lower controls were cut and welded to that length and installed to rigidly locate the lower portion of the axle. The arms I used were spares off an old 4th generation Ford galaxie. These were similar enough to use for this purpose.
Now with the new pinion angle the upper mounts on the axle housing needed to be moved inboard a tidge to avoid bind. So they were removed along with the spring perches as they were practically off in another quadrant now.
In the next part I'll cover the making of the rear control arms, misc brackets and adapting the existing GM propshaft to the Ford axle via Lincoln parts.
Hope you enjoyed.
Cheers
p.s. please feel free to ask any questions or voice any concerns.
DesertXL is offline
post #8 of (permalink) Old 03-29-2019 Thread Starter
DesertXL's Avatar
Part IV
Right, moving on. One thing I forgot to mention in the previous post is that along with optimizing pinion angle via the temporary tractor hitch adjustable arms, this was also a good time to put the axle in such a position that the wheel looks aesthetically pleasing fore-aft wise in the rear wheel well.
Because I like a luxury ride, I opted to use the standard GM full size rubber bushings for the rear control arms. This needs to be pointed out and I'm sure I'll repeat this numerous times, but there are loads of substandard, sometimes dangerous replacement parts being made. Just because it's the lower price doesn't mean it's the same quality. Sometimes even the more expensive parts are made so poorly they are only fit for the rubbish bin.
I have here a collection of brand new good and very substandard bushings. The good ones are the Harris branded ones (sold in Moog boxes) and then there is some no name imitation crapola ones. Now I bought the cheap ones because I needed a temporary set to install for locating the sway bar. That's coming up.
The substandard ones are made with such an indifference to quality the inner sleeve is placed almost willy-nilly with respect to the outer shell. Unlike the Harris ones.
Another topic I wish to cover is metallurgy. Do not use ordinary construction grade steel for anything structural or safety related on a vehicle and here's why. Ordinary construction steel is rated around 50-55 ksi. Most of the frames and suspension parts that are steel used on cars are higher carbon and other elements added for resistivity to cracking from flexing and then it's heat treated.
The metal I'm fabricating the rear control arms is 4130 Chromoly, 3/4 hard (tempered) aircraft certified steel. Chromoly is extremely resistant to cracking from continued flexing. Ordinary steel you buy a chain hardware store or even a steel supplier is not. It will crack.
I fellow car chum of mine is a big Oldsmobile fan and he mentioned some of the Oldsmobile clan bought tubular control arms as upgrades to their classic Oldsmobile's and are having cracks develop. The last thing you want is a crack leading to suspension or brake structural failure at high speeds. I need not elaborate further.
My bushing housings start off from a seemless pipe of 4130.
I inside bore with my cheap little lathe for a friction fit of the GM bushing. I even step the inside for the shoulder.
You can just make out the slight shoulder the GM bushings have.
These are the beginnings of the cup of the upper control arms.
I even bought 4130 TIG welding rod with a similar as welded strength as the steel, which is around 140-150,000 ksi. Much stronger than ordinary low carbon steel. The TIG welding rod flows nicely.
Starting to look like a proper adjustable upper control arm.
Finished products. I powder coated these.
Here is the comparison to the GM original upper arm.
After jigging up the axle in the chassis I rewelded the top mount ears back on the axle housing, I also tacked back in the coil spring perches. I don't have any pictures of the jigging process. But if you can imagine angle iron clamped to the secured rotors then using the frame rails as reference points making sure the axle is centred laterally. The temporary Ford lower control arms hold the pivot point steady and just a final check of the pinion angle was made and everything braced in place. Then I welded the upper ears back on.
Another problem with correcting the pinion angle is the shock brackets are at the wrong angle.
Sliced the brackets and using a long bolt as leverage adjusted the shock brace so the bolt was parallel to the natural position of the shock bolt. Then tack welded back in place.
Some of the follwing pictures you may notice to be out of sequence as I was bouncing around from one part of this elaborate axle installing to another. But for the sake of completion of certain parts I will rearrange them to accommodate that goal.
Rear lower control construction. Again it's all 4130 with the same temper used.
Here's a good example of visual metallurgy as well showing how I arched the ends of the lower control arms.
This is all make shift bits and pieces I had laying around. That lower U shaped piece is 1/2" thick plain Jane steel. Look at how it surrendered to the 1/8" Chromoly sheet I was trying to form. I even use an old proudly made in the USA C-clamp and it was splaying at the force it took to bend that. The round pipe is a spare section of the tubing I used for the bushing housings and that's why it barely distorted, but sprung right back when the pressure was released.
Jigging up the control arms.
Tacking everything in place and checking alignment.
Nearly completed first pass of welding.
Completed first round of welding and comparing to the original GM lower control arm. I have now installed the cheap set of lower bushings.
This is the reason why, I wanted a rear sway bar. There aren't many option for '71-'76 B and C body GM cars. This particular sway bar was from my old 1991 Caprice Classic I had for 10 years and 300,000 miles. Even on the later full size models the rear sway bar seemed to be an errant option. My particular 1991 Caprice Classic was an unusual car in that someone had a ball ticking all the options available for that car. It came with all the bells and whistles, even leather interior in a Caprice Classic! But it also had the towing package, hence the rear sway bar. So I thought it would be neat if I could adapt it to my convertible.
The problem became readily apparent in that the 91 sway bar was a bit narrow. The '71-'76 full size Chevrolets were the largest (and heaviest) passenger cars Chevrolet ever built. With that they downsized the full size line in '77 and carried that same chassis till '96. It's akin to putting my '73 chassis on a copier and pressing reduce 10%.
I needed to widen the sway bar just a tidge over an inch. I used a 10 ton ram to spread it past spring point to take permanent set without destroying the temper on the bar. It took just about everything that ram could muster too.
Once I had the location of the sway bar I marked the holes on the lower control arms and added a section of pipe vertically for the bolts to grip onto.
Again another piece of smaller 4130 pipe. The bolts are 9/16" grade 8. You can tighten those bolts to your hearts content and you're not crushing that pipe welded into the control arms.
After another round of welding and grinding, then powder coating. Now the good Harris bushings are used and the cheap ones discarded in the bin. These are stout rear control arms. If it wasn't for the soft bushings you could probably use this as a landing gear strut on a Boeing triple 7.
I had to notch the lower control arm mounting brackets on the axle to clear the sway bar under extreme axle positions.
Control arms and rear sway bar done. Well almost. I must concede I do make mistakes and had to remake the cup of the upper control arms. I transposed the width and height of the cup section. Such is life.
Round 2. I didn't smooth out the welds as no one is going to see them from the outside.
I should also note, anytime you weld, or even grind Chromoly or stainless or any material with chromium, you need to either wear a respirator or be in a booth with clean fresh air hitting you and blowing away from the work. Chromium is part of the hexavalent toxic catagories and you do NOT want to be inhaling that. I rolled my welding table into my foldable paint booth. It does have a 2000 CFM blower extracting air to the outside.
Enough of that, back to the propshaft. Now I originally wanted to rid the CV joint by bringing the Cardan joint angles equal and closer to nominal. However since I plan on replacing the aforementioned Turbo 400 with a 4L80E, I will need a longer propshaft made anyway as the 4L80E is about 2 inches shorter than my TH400.
If I can find a way to make the existing propshaft work for now, it saves me the cost of having another propshaft made unnecessarily.
I stumbled over a '69 Lincoln at the U-Pull and Pay and saw it had this. So I cut the end off its propshaft and brought it home along with the Ford companion flange that was on its 9-3/8" axle. Ug, looks like Ford made a mutant variant of the Oldsmobile axle I'm replacing. Or the other way round. Dunno. The companion flange is the same between a 9" and 9-3/8" Ford axle.
My plan was to see if I can use these parts and integrate them onto my GM propshaft and see if the length is close enough.
The extra length works in favour at this end.
Question is will the Ford CV joint end work on the GM CV joint.
Only one way to find out.
Here's my crusty GM CV flange and the Lincolns.
Fits wonderfully. Even the Cardan joints are the same.
I remove the yoke off and temporarily installed the companion flange.
So far so good.
Under worse case axle movement the propshaft is 3/4" of an inch out from nominal. I can live with that as there is plenty of meat of the slip yoke still in the transmission output shaft and tail housing bushing.
So for now till the 4L80E, of which I have procured one to build up, is installed this propshaft will do.
In part V I'll cover the brakes, both hydraulic and parking on the axle and other misc bits I may have missed.
Cheers
DesertXL is offline
post #9 of (permalink) Old 03-29-2019 Thread Starter
DesertXL's Avatar
Part V
No doubt this seems like loads of work, it was and one thing led to another with refreshing the transmission, the starter, then the complete braking system. This whole process took about 4 months over the winter.
Continuing on with brakes..
I prefer to use OEM designed parts where ever I can. In this case I wanted to use the '73 Chevrolet rear axle brake hose. I made an equivalent to the shouldered bolt GM used as it was all heavily pitted and the hex portion distorted.
Now to attach the GM hose to the Ford axle. I used the old '69 Lincoln hose bracket by grinding off what was left of the old hose and making a little threaded block to weld to the Ford bracket.
Done, all it needs is powder coating in satin black.
Now for the parking brake cables I opted to use the '94-'96 full size Chevy disc brake parking brake cables. So I made some threaded blocks welded to the axle to mount clamps to carefully hold the passenger side long brake cable in place so it doesn't rub on the exhaust.
I routed the cables in a similar fashion to the '96 Impala SS. I used the wifes car as a template. I just tried to route the cables much nicer than GM did.
The '73 Driver side cable mount to the chassis is the same as the '96 so I used that.
I am using the '94-'96 cable adjuster this means I need to modify the '73 front and intermediate cables. I'll cover that in a bit.
Back to the hydraulic lines. In order to make the stainless hard lines first I mold a line from heavy copper wire.
Then I use the wire as a guide to bend the stainless line.
Now the rear axle hard brake lines need to adapt the metric '96 Impala SS rear caliper brake hoses to the English/SAE '73 axle hose.
On this end I made a bubble flare with the metric fitting.
And the other end, good ol English inverted flare fitting. I couldn't find metric stainless tube nuts, but the English ones are all stainless.
completed.
This side is finished. Earlier I made the brackets to hold the Impala SS caliper brake hoses to the axle from scratch.
Repeated for the other side.
The Moser axle never came with the outer axle bump stops or mounts. With that I nicked the rubber stops off my old Olds axle and then make a template of the mount from the Olds and hand made these out of extra 4130 I had left over. I tack welded these in place.
I removed the axle for final welding and paint.
After the axle was painted it was reassembled and installed back in the car.
I stripped all the calipers and prepped them for paint.
This is going to be the new colour of the car so I painted the calipers now that colour.
All calipers have new seals, hardware and pads.
Installed the coil springs and the only thing left to do back here is the vent tube.
Now for the front and intermediate cable.
The top cable is the original '73 cable that I modified (cut down). The one underneath is a brand new Raybestos cable and just see if you can see the manufacturing defect in the brand new cable. If I wasn't going to modify the new cable, this would be useless as a replacement and would have to go in the garbage bin.
If you didn't catch the problem Raybestos put the return spring on the wrong side of the spring stop. <shaking head>
To make my own cable crimps I started with some stainless 304L rod. First centre drill then turn down the outer diameter. Then slice up into little pieces.
To crimp the cables I used a cheap hydraulic electrical crimper. It worked really well.
This is the intermediate cable. Normally it's very long. It's reduced to this little bit.
Now I did make a little guide tube that is bolted to the bottom of the transmission brace. This isn't optimal, the guide tube should go through the brace to raise the cable higher up under the car. But since this is a temporary brace I can live with it till now.
This is the end of the axle install. I have driven the car with the new axle and all new/ refurbished braking system.
Here's how it came out. I am very happy with the way it came out. The car still has a luxury ride but is more flat in turns thanks to the rear sway bar. The Eaton True Trac is an amazing invention. No clutches and nothing to wear out. Floor it off the line and it leaves nice 11's. Thanks to the Richmond 3.25 gears it will do a brake torque and roast them both till it runs out of fuel. The gears are dead silent too. The brakes literally stop that big heavy car on a dime. I'll cover the rest of the brake system in another post.
Thanks for following along.
Cheers
DesertXL is offline
1958-1964 chevrolet impala belair 2 inch drop spindles for disc brake conversion RSS Bot Impala Diecast Toys Cars on eBay 0 09-18-2017 04:10 PM
8000LM 44W H7 Led Headlight Bulbs Conversion kit Canbus 6500K Ford Jeep Off road RSS Bot Impala Diecast Toys Cars on eBay 0 08-30-2017 06:10 PM
1958-1964 chevrolet impala belair 2 inch drop spindles for disc brake conversion RSS Bot Impala Diecast Toys Cars on eBay 0 08-16-2017 01:00 PM
1958-1964 chevrolet impala belair 2 inch drop spindles for disc brake conversion RSS Bot Impala Diecast Toys Cars on eBay 0 08-01-2017 05:00 PM
