backuplights didn't work - 94 Caprice - Chevy Impala Forums
  • 1 Post By 12 lt
post #1 of (permalink) Old 07-18-2018 Thread Starter
German9C1's Avatar
Hey guys,
the backup-lights of my 1994 Caprice didn't work. It is a 9C1, so the wiring unter the dashboard is a mess.
But I tested a bit with the gauge and I don't found 12V at the backup-lights wiring. So I have some questions:
- Is there a fuse for the backup-lights? Didn't find it in the instruction manual.
- There ist a bent white switch towards the base of the steering column on the top. Is that the switch for the backup lights? There are 3 pins but only one light green wire at one of the pins. Mybe there are some wires missing?
- when the ignition is on and the shifter is on "R", should the backup-lights flash up? Or did the backup-lights only flash up when engine is running?
Thanks for your help! :-)
German9C1 is offline
post #2 of (permalink) Old 07-18-2018
Quoted: 223 Post(s)
From everything I have read and heard, the police versions of these cars are often left with wiring disasters/nightmares after they remove the police wiring from the car.
Not 100 percent sure, but the car should have a fuse for reverse lights, and the reverse lights should light up solid while the car is in reverse, not blink or flash.
Honestly think the best thing you could probably do with knowing it is a mess is to get your hands on a full set of wiring schematics. Some manuals like haynes usually will have decent wiring diagram, which would make it easier to trace.
post #3 of (permalink) Old 07-20-2018 Thread Starter
German9C1's Avatar
yes, the wiring was a mess, but not that bad. I repaired much and removed all the useless wiring.
I have the wiring diagramms, but I'm not a professional mechanic. So I need some additional help from you guys. :-)
94 95 96 Chevy Impala SS Gray Door Pull Straps & End Caps 1994 1995 1996 Caprice RSS Bot Impala Diecast Toys Cars on eBay 0 10-31-2018 08:40 PM
1994 1995 1996 Chevy Impala SS Factory 17" Rims Wheels 94 95 96 5x5 Caprice OEM RSS Bot Impala Diecast Toys Cars on eBay 0 09-23-2017 10:10 AM
94 95 96 Factory OEM Chevy Caprice LT1 Impala SS Air Cleaner Intake Resonator RSS Bot Impala Diecast Toys Cars on eBay 0 08-25-2017 07:40 PM
94 95 96 1994 1995 1996 Impala SS Caprice Grey Rear Door Panel Window Switch RSS Bot Impala Diecast Toys Cars on eBay 0 08-25-2017 06:40 PM
94 95 Chevrolet Caprice Tan Console Impala SS Roadmaster RSS Bot Impala Diecast Toys Cars on eBay 0 07-19-2017 08:40 AM
