At slow speed, the engine waves - Chevy Impala Forums
post #1 of (permalink) Old 09-08-2017 Thread Starter
kamol_Poland's Avatar
HI!
In my 305 how does the engine heat up on idle gear the engine starts gently waving ... where should i look for the cause?
Any suggestions and hints?
Chevrolet Caprice Classic Brougham'89, V8 5.0L/TBI
Dodge Grand Caravan'04, V6 3.8L
Jeep Grand Cherokee'94, V8 5.2L
kamol_Poland is offline
post #2 of (permalink) Old 09-08-2017
77Impala's Avatar
Quoted: 16 Post(s)
Not exactly sure of your question here. If your asking about as your engine warms up it is surging on RPM's, that is the idling RPM's go up and down slightly then I would first check that the vacuum lines are intact, then check/verify that the spark plugs are not needing to be changed. Is the fuel fresh? Old fuel can cause this issue as well. Is the "Check Engine" light on and if so have you had the codes read from it? Last thing might be that the ECM may be starting to loose the EPROM chip. Reason I say that is a friend of mine has a TBI GM truck and it had a failing EPROM chip that was causing his to surge while idling, especially as the engine warmed up.
Hope this helps
Kenny
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #3 of (permalink) Old 09-08-2017 Thread Starter
Sorry but I do not speak English well and therefore my question is not clean ... it is that as soon as the engine warms up and works calmly it will feel a gentle ripple.
2012 engine replacement Jaestes Automotive Discussion 6 02-20-2019 05:51 AM
Engine unable to align with frame while replacing engine mount James06 Chevy Impala 8th Gen Discussion 5 12-24-2018 02:06 PM
Red. Engine Pwr/Serv. Stabilitrac- TB, Pedal, Cats, or Speed Sensors Kevin912 8th Gen Engine Performance 4 08-23-2018 10:22 PM
Engine Misfiring Taylor Wilson Autocare and Maintenance 1 06-11-2018 04:17 AM
