1991 Chevy Caprice 4 door sedan - Right front door glass replacement - Chevy Impala Forums
 2Likes
  • 2 Post By WyrTwister
post #1 of (permalink) Old 01-18-2017 Thread Starter
WyrTwister's Avatar
Vandals broke this glass out . Picked up a new replacement glass .
I was expecting the glass to be held by 2 fasteners through 2 holes in the bottom of the glass . Which is what I saw in the bottom of the new glass . When they took it out of the cardboard to show me the glass was in good condition .
Got the door apart . The bottom of the old glass was " glued " to an aluminum strip , with black " rubber adhesive " . Not held in place with 2 fasteners .
The aluminum strip was pop riveted to another aluminum strip . I drilled out the pop rivets . Those I can replace , not woeied about that part .
So , I am confused . Did they sell me the wrong glass . Or am I missing something ?
Thanks , :-)
God bless
Wyr
WyrTwister is offline
post #2 of (permalink) Old 02-01-2017 Thread Starter
WyrTwister's Avatar
Not too professional looking . But I hope it is good enough .
Used 3M Window weld # 06909 urethane adhesive .
Two plastic / nylon screws & hex nuts locate the holes in the glass with the 2 holes in the aluminum strip .
Groove in the strip was about .2" wider than the thickness of the glass . Tried to use Popsicle sticks & wooden kitchen matches for shims , one on either side , to the left & to the right of the screws . No go . Finally settled up on 4 pennies . 2 at each end .
Will probably let it set until after lunch tomorrow .
God bless
Wyr
post #3 of (permalink) Old 02-01-2017 Thread Starter
WyrTwister's Avatar
The adhesive has set up pretty quickly . At least good enough .
Removed the pennies & plastic screws / hex nuts .
Tried to attach photos , but no luck ?
God bless
Wyr
post #4 of (permalink) Old 02-02-2017
Quoted: 380 Post(s)
On the Manage Attachments popup window, after you Browse and select your files/pics to share, make sure you scroll all the way to the right and hit Upload.
post #5 of (permalink) Old 02-02-2017 Thread Starter
WyrTwister's Avatar
Thank you , :-)
Will try when I get off work .
God bless
Wyr
post #6 of (permalink) Old 02-02-2017 Thread Starter
WyrTwister's Avatar
post #7 of (permalink) Old 02-02-2017 Thread Starter
WyrTwister's Avatar
1991 Chevy Caprice RF door glass
With the help of my Wife and several prayers , the glass is in the door . Far as I can tell , still in one piece .
Praise the Lord ! :-)
The aluminum strip the glass is glued to & the strip that the regulator operates ( up & down ) were originally pop riveted together . Could not get a pop rivet tool in position , to operate it .
Considered screws & hex nuts , but could not find my " tray " with assorted sixes & lengths . Ended up using Teak ( hex head self tapping screws ) . My cousin had suggested using LockTite , if I used screws & hex nuts . Excellent suggestion .
I found that a large enough diameter Teak screw , the hex head of the screw wedged inside the " track " , that the plastic glide clip slides in . Tight enough that I do not think it will ever vibrate loose / out . Even w/o LockTite .
Still need to finish assembling the door .
Also attached are photos of front and back side of the arm rest . Made some repairs with E6000 adhesive . Need to cut a piece of plastic , for the broken area of the back side & glue it in . To finish the repair . Pick up some screws and appearance / trim washers . Hopefully at O'Reilly Auto Parts . Then do the same for the driver side arm rest .
God bless
Wyr
ID:	131257   Click image for larger version
ID:	131265   Click image for larger version
ID:	131273   Click image for larger version
post #8 of (permalink) Old 02-07-2017 Thread Starter
WyrTwister's Avatar
My Wife helped me put the door back together , yesterday PM .
God bless
Wyr
ID:	131401   Click image for larger version
plano-doug and retiredpauly like this.
1991 Chevy Caprice Exhaust Heat Shield Chevy Guy Chevy Caprice 2 04-10-2019 09:25 AM
Chevy Impala Caprice Set of 4 UPPER & LOWER Front Ball Joint Suspension K6034 RSS Bot Impala Diecast Toys Cars on eBay 0 12-09-2017 10:40 AM
1991 1992 1993 1994 1995 1996 Chevy Caprice Impala SS Front Armrests Left Right RSS Bot Impala Diecast Toys Cars on eBay 0 08-23-2017 03:21 AM
1991 1992 1993 1994 1995 1996 Chevy Caprice Impala SS Front Armrests Left Right RSS Bot Impala Diecast Toys Cars on eBay 0 08-10-2017 05:11 AM
1991 1992 1993 1994 1995 1996 Chevy Caprice Impala SS Front Armrests Left Right RSS Bot Impala Diecast Toys Cars on eBay 0 08-02-2017 05:10 PM
