Alternator upgrade - Chevy Impala Forums
Chevy Bel Air General and Technical discussion for the B-Body Chevy Bel Air (1958-1975).
post #1 of (permalink) Old 06-12-2019 Thread Starter
Bencoyle78@yahoo.com's Avatar
Alternator upgrade
Before I bought the car 3 yrs ago, it was changed over to an alternator. Now since I've owned it, it has had some modifications ( air ride, retro radio, led lights). Since this I have had battery issues, after about 2 days it's dead. My air ride and radio are hooked up to toggle cut offs. So I be decided to upgrade my alternator to a 105 amp. Is there any thing I need to change or add? Or just replace, plug and go?
post #2 of (permalink) Old 06-12-2019
Quoted: 253 Post(s)
i would strongly suspect the LED's are causing the issue. if you just did a bulb replacement then try putting in some halogens and see if the issue goes away. i say this because a few of the newer generation impalas ran into this exact problem. i think one solution was to go with a reputable brand and or add a resister. i have not messed with them so i'm not a good source for exact answers but i know it has been discussed on these forums frequently under the 8th gen forums. particularly i read about battery drain from the reverse lights a lot.
you could try swapping them out in pairs to see which ones trigger the drain.
hope this help!
Joes74challenger is offline
post #3 of (permalink) Old 06-12-2019 Thread Starter
Thanks, I installed resistors. I am more concerned about the upgrade of the 105 amp alternator. Just curious if I need to do anything extra on it. Like add a diode to the pigtail, run a larger wire for charging the battery.
post #4 of (permalink) Old 06-13-2019
1970cs's Avatar
Quoted: 41 Post(s)
What's the setup? One or two wire? Internally or externally regulated?
Pat
1970cs is offline
post #5 of (permalink) Old 06-13-2019 Thread Starter
3 wire
post #6 of (permalink) Old 06-13-2019 Thread Starter
3 wire internal, just bought it from jb electrical
post #7 of (permalink) Old 06-14-2019
1970cs's Avatar
Quoted: 41 Post(s)
Pictures would help or even a part number of the alternator. I am assuming a 10SI alternator? I would assume that you have a 10ga wire on the battery terminal? You could upgrade to a 4-6ga to help with extra amperage.
Pat
1970cs is offline
post #8 of (permalink) Old 06-16-2019 Thread Starter
Yes, 10si case 105 amp. I am upgrading to a 6awg to battery and better ground.
post #9 of (permalink) Old 06-22-2019 Thread Starter
I installed it, used 4 awg wire. Every thing working good. Thanks for the info guys.
kbz1960 likes this.
