65 bel air, throttle getting stuck at WOT - Chevy Impala Forums
Chevy Bel Air General and Technical discussion for the B-Body Chevy Bel Air (1958-1975).
post #1 of (permalink) Old 02-22-2016 Thread Starter
Andre.servin's Avatar
Hey how's it goin! I recently obtained a 65 bel air. I believe it has a 283 with what would be a power glide automatic?
The car starts fine and all that, while driving if I'm being gentle with the pedal and not laying into it, the car drives fine. I tried to do a burn out and after I let off the gas I noticed the car was still going at WOT so I shut the car off. Put it in park, turned it back on and went on my way.
Got home looked at the carb linkage to gas pedal, everything checked out fine. Put it in park and revved it up good, seeing if I can get the throttle to stick again. Nothing. I thought okay so it seems to only do it while driving. Took it out again and mashed the gas pedal to test my theory (only sticks at WOT). Just as I thought, throttle was stuck.
Once again I shut it off, put it in park, kicked her back on again and went home.
I'm guessing this may have something to do with the kick down?
That's really the only thing I can think of. Carb and pedal linkage look good, carb pump isn't sticking. Won't get stuck in park, which I take it that means it won't get stuck in neutral. Wasn't about to attempt the mashing of the pedal while in reverse. So the only thing I can imagine it could be is that something is sticking while at wot throttle, I know the kickdown engages when you lay into the gas pedal.
Does anyone have any ideas as to what could be the issue?
Thanks!
Andre.servin is offline
post #2 of (permalink) Old 02-23-2016
77Impala's Avatar
Quoted: 16 Post(s)
The kick down cable should not hold the throttle down. The throttle should be able to back off even if the kick down cable hangs momentarily.
Have you lubed the carburetor linkages? GM usually recommended using 30w oil for that, I also try to lube the throttle plate pivot points as well.
Check for vacuum leaks.
Check the kick down linkage both at the carb and tranny for any rough area which might cause it to hang up momentarily.
Last that I can think of is check the tension on the throttle return springs, if not tight enough then the engine running at full throttle may be able to keep the throttle plate at full open.
I hope this helps.
Kenny
1977 Chevrolet Impala Sedan
1989 GMC C1500 Sierra ECSB
77Impala is offline
post #3 of (permalink) Old 02-25-2016
moms66ss's Avatar
It might be a broken engine mount (left side). Chevy had a recall for this. My moms 66 Impala SS (427 BTW) had a cable installed on the left side of the engine to frame to keep the linkage from binding. Try power braking with the hood up and see if the engine is lifting on the left side.
moms66ss is offline
The Following User Says Thank You to moms66ss For This Useful Post:
retiredpauly (03-04-2016)
post #4 of (permalink) Old 03-04-2016
retiredpauly's Avatar
Quoted: 233 Post(s)
I fixed dozens of these back in the day.
The cable was a stop gap fix for a year or so.
They came out with a different style of motor mount that had 2 tabs of metal locking the two mounting plates together.
retiredpauly is offline
Radiator +Shroud Fan +Thermostat for 1963-68 64 65 Chevrolet Bel Air Impala 3Row RSS Bot Impala Diecast Toys Cars on eBay 0 07-12-2018 03:32 AM
3 Row Radiator for 1963-68 64 66 65 67 Chevy Chevrolet Bel Air Impala Chevelle RSS Bot Impala Diecast Toys Cars on eBay 0 07-11-2018 03:00 PM
3 Row Radiator for 1963-68 64 66 65 67 Chevy Chevrolet Bel Air Impala Chevelle RSS Bot Impala Diecast Toys Cars on eBay 0 07-10-2018 08:02 PM
Radiator for 1963-68 64 65 66 67 Chevrolet Bel Air Impala Chevelle Malibu 3 Row RSS Bot Impala Diecast Toys Cars on eBay 0 06-05-2018 11:21 AM
1965 1966 Chevy Impala Bel Air Biscayne Fuel Gas Tank GM37C 20 Gallon 76L 65 66 RSS Bot Impala Diecast Toys Cars on eBay 0 02-10-2018 12:40 PM
