-   Automotive Discussion (https://www.impalaforums.com/automotive-discussion/)
-   -   windshield wiper water does not work anymore (https://www.impalaforums.com/automotive-discussion/278242-windshield-wiper-water-does-not-work-anymore.html)
cl_smooth 03-20-2011 01:01 AM
I have a 2007 chevy impala and the water control does not work anymore so when I try to cleam my windows not water comes out. I made sure that the water was full in the engine bay, but not water. Does anyone out there have any clue of what going on with my windshield wipers and the water that does not shot onto my windshield anymore. What is the problem and is it something that I may be able to fix myself
kingnutin 03-20-2011 01:19 AM
Did you check fuses yet? After that if you still haven't found the problem, try testing the washer motor. Most diagnostics have to be done in steps
cl_smooth 03-20-2011 07:41 AM
would I need to check the fuses under the hood or the fuses in the inside the car
tmusquiez 03-20-2011 07:49 AM
http://www.extendedgmwarranty.com/ow...let-Impala.pdf
Page 402. It's in the Underhood Fuse Block. See page 308 for more info.
There's a WSW (Windshield Wiper) and a WPR (Wiper) fuse.
Not too sure which to check, but check both while you're at it.
WallyLO 03-20-2011 10:31 AM
when i bought mine, there was a little hose unplugged. i noticed it was spraying on the ground in the garage and plugged it back in
thacarter546 03-22-2011 11:44 PM
^thats the most common problem as they dont use hose clamps from the factory.
Alot of times the spray nozzles themselves get clogged up, use a sewing needle to clean the nozzles out.
lawnenforcement 03-07-2019 08:47 AM
quick video on how to replace the pump
