09 Impala key stuck in ignition - Chevy Impala Forums
 3Likes
  • 2 Post By jtrosky
  • 1 Post By jtrosky
post #1 of (permalink) Old 04-27-2019 Thread Starter
dvia's Avatar
I have changed out the wires under the shifter and the car is operating well and shifting out of park etc; however, I am still using the manual release to get the key out of the ignition. The purple wire connection is good. What is the next step with the key?
dvia is offline
post #2 of (permalink) Old 04-27-2019
Quoted: 917 Post(s)
Have you checked the RAP fuse in the passenger footwell fuse compartment? I know from expereince that if the RAP fuse it blown or not fully inserted, that you will not be able to remove the key from the ignition. It's the red 10amp fuse that is up in the corner, kind of hidden by the metal fuses and big relays.
post #3 of (permalink) Old 04-29-2019 Thread Starter
dvia's Avatar
Where would this be located in an 09 Impala - it is not is in the same area?
dvia is offline
post #4 of (permalink) Old 04-29-2019
Quoted: 917 Post(s)
It would be in the exact same place as pictured above.
post #5 of (permalink) Old 04-29-2019 Thread Starter
dvia's Avatar
I found the fuse box under the hood - there is a BCM 10A fuse but it didn't look bad and did not fix the key stuck issue?
dvia is offline
post #6 of (permalink) Old 04-29-2019
Quoted: 917 Post(s)
This fuse is not under the hood. It's above the passenger side floormat on the inside of the car. There is a little plastic "door" that you take off to expose the fuses. Use the picture above to see exactly where the fusebox is.
I'm not guaranteeing that this is your problem, but it's worth checking.
Question about the Key fobs on the 9th gen Impala FAWAZ87 Chevy Impala 9th Gen Discussion 9 05-04-2019 07:58 AM
07 ss no power key stuck mveley62 Mechanical and Electrical Problems 5 09-10-2017 10:26 AM
New original OEM 06 07 08 09 10 11 2012 Chevy HHR / Impala transponder chip key RSS Bot Impala Diecast Toys Cars on eBay 0 08-31-2017 02:50 PM
Ignition switch key hole trim bezel impala malibu grand am RSS Bot Impala Diecast Toys Cars on eBay 0 08-31-2017 09:10 AM
New original OEM 06 07 08 09 10 11 2012 Chevy HHR / Impala transponder chip key RSS Bot Impala Diecast Toys Cars on eBay 0 08-20-2017 02:30 PM
